I have tried to install the program but it always fails. I have included part of the log file:
2013/3/19:07:47:33 lisinski SAC120828C === Setup started on SAC120828C by lisinski === 2013/3/19:07:47:33 lisinski SAC120828C Launch 2013/3/19:07:47:34 lisinski SAC120828C PageOpen LaunchDialog 2013/3/19:08:01:40 lisinski SAC120828C PageOpen LicenseDialog 2013/3/19:08:01:47 lisinski SAC120828C PageOpen ProductInfoDialog 2013/3/19:08:02:12 lisinski SAC120828C PageOpen ProductSelectionDialog2 2013/3/19:08:02:20 lisinski SAC120828C PageOpen FullProgressDialog 2013/3/19:08:02:20 lisinski SAC120828C Installing DirectX Runtime: C:\Autodesk\AutoCAD_MEP_2013_English_Win_64Bit\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/19:08:02:33 lisinski SAC120828C Install DirectX Runtime Succeeded 2013/3/19:08:02:33 lisinski SAC120828C Installing AutoCADĀ® MEP 2013: TRANSFORMS="C:\Autodesk\AutoCAD_MEP_2013_English_Win_64Bit\x64\en-us\MEP\MEP.mst;C:\Users\lisinski\AppData\Local\Temp\_AI9EAC.tmp\x64\MEP\MEP-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_MEP_2013_English_Win_64Bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/19:08:04:18 lisinski SAC120828C Install AutoCADĀ® MEP 2013 Failed Installation aborted, Result=1603 2013/3/19:08:04:18 lisinski SAC120828C Rollback DirectX Runtime Failed Failure is ignored, Result=1619
What could be the problem?
Make sure you don't have another vertical flavor of AutoCAD 2013 already installed.
