Installation & Licensing
Installing Autocad 2013 in Network
1 REPLY 1
271 Views, 1 Reply
Sir,
I want to install Autocad 2013 in a student laboratory with 50 windows 7 computers. I selected one of these (PC1) as a server and install NLS Software . Then installed Autocad. NLS and Autocad works fine in this machine. But ii need install in the otjhers 49 computers all are network conected. Do you know a fast method for install the software in the others PCs? Thanks.
1 REPLY 1
TravisNave
Create a network deployment.  This will make an answer file that will install each client with the information pointing back to your single license server.
Alternately, you can install one computer with the network version, then use a disk imaging software to blast it to the other machines.
Autodesk Forums:
Administrator Productivity
