Hi everyone!
I am trying to install Autocad 2013 for Mac but the installation tells me that i already have an autocad version installed and that i must uninstall it first. I have never installed autocad before so this is very frustrating. what should i do? are there any programs that might be interfering with the installation?
Thanks!
Solved by philip.s. Go to Solution.
Welcome to the community Omer!
Can you specify what version of Mac OS X you're running? This typically occurs when the OS version isn't supported to run the software release.
AutoCAD for Mac System Requirements
The installer for AutoCAD for MAC can also give this message if it detects a windows install of AutoCAD on a Parallels or Bootcamp partition. Could that be the case?
Please accept as a solution if this fully resolves the issue, or reply with additional specifics if the problem persists.
You're welcome Omer and thanks for clarifying!
As mentioned earlier, this typically occurs when the OS version isn't supported to run the software release. In your case, AutoCAD 2013 is not supported to run on 10.5.8 (Leopard) as the requirements list Mac OS X 10.8.0 or later (Mountain Lion), OS X 10.7.2 or later (Lion), or OS X 10.6.8 or later (Snow Leopard).
With that being said, I noticed that this pertains to a free student license and as such can you try downloading / installing AutoCAD for Mac 2012 and let us know if it resolves the issue (accept as a solution)?
