Andi
the path you list has a blank in "program files"
And I have it installed on a D drive, with no problems at all.
Could I share out that drive to others, probably. I have no reason to do
so, so I haven't tried it, but it should work.
Could I install ADLM so that the files are on \machine A, but it runs on
Machine B? Who knows, why would I wannt to do that? It doesn't take a lot
of room.
There is probably a way to install it, and have it run on machine A, but
administer it on machine B. Were my servers more than 3 feet from my desk,
I might look into that.
"Andi Auburger" wrote in message
news:3C60F495.D45A8436@cotec.de...
> dbounds schrieb:
> > Can you install ADLM on a shared network drive? Would this work?
> In my experience: No way!
> FLEXlm: It only runs when installed on drive C: and if there are no
> blanks in the path (why is the default given by the installer
> "C:\program files\Autodesk Licence Manger\"?)
> The ELAN must be installed on a local drive but it doesn't matter wich
> driveletter.
> Best regards
> Andi
> co.Tec Ges. f. Softwaredistr. mbH Traberhofstr.12 D-83026 Rosenheim
> Tel./Fax.: +49 (0) 80 31 / 26 35-0/Fax.:-29 (Mo - Fr 9:00 h bis 18:00 h)
