Installation & Licensing
Active Member
keithcotter
Message 1 of 7 (560 Views)
Installing ACA2011 - It will not start
560 Views, 6 Replies
10-05-2011 03:15 AM
I am using windows 7 64 bit and I have just installed ACA2011 , and it appears to have installed fine.   My problem though is when I double click the icon on desktop to start the application.   The following steps happen 1. The ACA 2011 logo appears (The one with the building image) 2. then the grey design screen appears next 3. The it reverts back to the desktop.  And nothing more happens.   I do not know if this is related to the fact I also have 2012 on the machine too.
Can anyone help me on this
Keith
The resolution to this issue was to install service pack 1 and 2.   Issued solved
Active Member
keithcotter
Message 2 of 7 (558 Views)
Re: Installing ACA2011 - It will not start
10-05-2011 04:05 AM in reply to: keithcotter
A further update on this.  I uninstalled everything again.  that is ACA2011 and ACA2012.  Restarted machine and re-installed ACA 2011.  I left 2012 off this time.  The same issue now still occurs , which is the grey drawing screen appears, and then everthing reverts to the desktop and disappears from task manager
Active Member
keithcotter
Message 3 of 7 (556 Views)
10-05-2011 04:19 AM in reply to: keithcotter
in the ADLM folder the log file shows the following activity
728 2011/10/05 11:59:43 Reason=Fatal error
728 2011/10/05 11:59:43 ComputerName=WATERFALL
728 2011/10/05 11:59:43 OS=6.1.7601.Service Pack 1
728 2011/10/05 11:59:43 File=AdlmIntSATSLicense.cpp,Line=1150
728 2011/10/05 11:59:43 AdlmIntError=38 [Error getting license usage and behavior]
4772 2011/10/05 12:00:07 Reason=Fatal error
4772 2011/10/05 12:00:07 ComputerName=WATERFALL
4772 2011/10/05 12:00:07 OS=6.1.7601.Service Pack 1
4772 2011/10/05 12:00:07 File=AdlmIntSATSLicense.cpp,Line=1150
4772 2011/10/05 12:00:07 AdlmIntError=38 [Error getting license usage and behavior]
Product Support
avto
Message 4 of 7 (545 Views)
10-05-2011 10:41 AM in reply to: keithcotter
Please try the following:
1.Open C:\ProgramData\FLEXnet folder and move adskflex_xxx_tsf.data and adskflex_xxx_tsf.data_backup files you find there to another folder.
2.start ACAD 2011
3.start ACAD 2012
If both products open fine, then delete data files you moved to another folder in step 1.
Avto Chachava
Autodesk Product Support
Active Member
keithcotter
Message 5 of 7 (500 Views)
10-18-2011 02:11 AM in reply to: avto
COUPEDECALE
Message 6 of 7 (323 Views)
Are you referring to Autocad 2011 Update 2?? Because i've...
11-20-2012 01:25 AM in reply to: keithcotter
Are you referring to Autocad 2011 Update 2?? Because i've the same issue and can't understand.
Active Member
keithcotter
Message 7 of 7 (312 Views)
Re: Are you referring to Autocad 2011 Update 2?? Because i've...
11-20-2012 02:25 AM in reply to: COUPEDECALE
