Installation & Licensing
Installing 3ds Max Trial - "Appcrash"
1 REPLY 1
980 Views, 1 Reply
Hello, I am trying to install the trial version of 3ds Max. I am getting the following error:
3ds Max application has stopped woorking. Problem signature: Problem event name: APPCRASH (see photo below).
I am running Windos 7, 64-bit, 12 GB ram.
Contacting customer service is not the easiest. 😕
Has anyone run into this issue?
1 REPLY 1
dembkod
BetDue,
Hello. Search on the failing module- it is a licensing component not working for you: adlmact_libFNP.dll
http://forums.autodesk.com/t5/Installation-Licensing/Activation-error/td-p/3015536
Delete the tsf data file. We are looking for a specific TSF.data file. It will resemble this: ADSKFLEX_NUMBERS_TSF.data. It should be located here:
Windows XP:
Documents and Settings\All Users\Application Data\FLEXnet
Vista/Windows 7:
C:\ProgramData\FLEXnet
Delete them and try to start the program.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
