The only file that downloads is:
Building_Design_Suite_Premium_2014_English_Win_32_64bit_dlm_004_004.sfx.exe
When I run this file, it stalls when trying to extract the zip files.
Bryon Morales, Autodesk Support Team, said that I should downloading four separate files, but there is one file to download as noted above.
Help.
Thanks.
Pete Smith
Solved by philip.s. Go to Solution.
Hi Pete,
Confirming that there should be 4 parts to the BDSP download, as indicated by the download path.
The 004_004 indicates that it's part 4 of 4. More often then not, the other downloads are either going in the background, are waiting for acceptance to initiate, or were automatically stopped by your browser pop up blocker.
In this case the suggested workaround is to simply utilize a different browser. Can you please do so and let me know if you're able to download the other 3 parts?
Yes, I was able to download the other 3 parts. I moved the files from the Download Folder to a new folder and then ran the setup. But I get these error messages - see attached.
Thanks.
Pete Smith
608-846-4171
Thanks for confirming Pete.
So the browser shouldn't have much to do with it as long as you can downloaded the files, however I'm a little confused by your second error which indicates that you're using Install Now and not the Browser Download. Would it be easier to start from scratch / if I supplied you with direct download links for all 4 parts?
I started from scratch and this time it worked. I made sure that each of issues in the attached error message was addressed.
Now for the next issue: I’m unable to Migrate Settings from the Start Menu after rebooting.
Is this version a bit buggy?
Thanks for your help.
Pete Smith
For the migration issue, if it's AutoCAD, please go to AutoCAD forum,you will get more help from there.
