Installation & Licensing
Active Member
prsmith
Message 1 of 7 (583 Views)
Installing 2014 Design Suite Premium
583 Views, 6 Replies
04-24-2013 12:52 PM
The only file that downloads is:
Building_Design_Suite_Premium_2014_English_Win_32_64bit_dlm_004_004.sfx.exe
When I run this file, it stalls when trying to extract the zip files.
Bryon Morales, Autodesk Support Team, said that I should downloading four separate files, but there is one file to download as noted above.
Help.
Thanks.
Pete Smith
Thanks for confirming Pete.
So the browser shouldn't have much to do with it as long as you can downloaded the files, however I'm a little confused by your second error which indicates that you're using Install Now and not the Browser Download. Would it be easier to start from scratch / if I supplied you with direct download links for all 4 parts?
philip.s
Message 2 of 7 (570 Views)
Re: Installing 2014 Design Suite Premium
04-24-2013 02:20 PM in reply to: prsmith
Hi Pete,
Confirming that there should be 4 parts to the BDSP download, as indicated by the download path.
The 004_004 indicates that it's part 4 of 4. More often then not, the other downloads are either going in the background, are waiting for acceptance to initiate, or were automatically stopped by your browser pop up blocker.
In this case the suggested workaround is to simply utilize a different browser. Can you please do so and let me know if you're able to download the other 3 parts?
Philip Schmelzer
Active Member
prsmith
Message 3 of 7 (536 Views)
04-25-2013 08:39 AM in reply to: philip.s
Yes, I was able to download the other 3 parts. I moved the files from the Download Folder to a new folder and then ran the setup. But I get these error messages - see attached.
Thanks.
Pete Smith
608-846-4171
Active Member
prsmith
Message 4 of 7 (524 Views)
04-25-2013 08:49 AM in reply to: prsmith
I am using FireFox - should I be using Explorer?
Thanks.
Pete Smith
philip.s
Message 5 of 7 (489 Views)
04-25-2013 05:37 PM in reply to: prsmith
Philip Schmelzer
Active Member
prsmith
Message 6 of 7 (456 Views)
04-26-2013 03:08 PM in reply to: philip.s
I started from scratch and this time it worked. I made sure that each of issues in the attached error message was addressed.
Now for the next issue:  I’m unable to Migrate Settings from the Start Menu after rebooting.
  • I have both R2012 and R2013 installed on this computer.
  • The Migrate Setting Tool doesn’t think I have a previous release installed – Error Message3.
  • Then when I open R2013 (not R2014) and try it, I get Error Message4.
Is this version a bit buggy?
Thanks for your help.
Pete Smith
Product Support
emily.xu
Message 7 of 7 (439 Views)
04-27-2013 02:41 AM in reply to: prsmith
For the migration issue, if it's AutoCAD, please go to AutoCAD forum,you will get more help from there.
Emily Xu
