I had 2011 inventor simulation suite installed on my computer
The operating system (windows xp) stopped working properly after I shut it down.
I was able to repair it by installing some system 32 file.
When windows started all my program worked ok except the 2011 inventor simulation suite.
I uninstalled the program and installed again.
The installation proceeded ok but the program is not working!!!
What can I do to fix this problem?
Thank you for your assistance
Solved by hashim.mundol. Go to Solution.
Same as this post
marking as solved
