trying to install the revit 2014 version for students. i uninstalled the 2012 version i had..
heres the script
2014/1/30:15:33:40 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:15:33:40 Jenna JENNA-PC Path_Length: 149
2014/1/30:15:33:40 Jenna JENNA-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/30:15:33:40 Jenna JENNA-PC Launch
2014/1/30:15:33:40 Jenna JENNA-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-31253041 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/30:15:33:40 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AIF4FD.tmp
2014/1/30:15:34:44 Jenna JENNA-PC === Setup ended ===
2014/1/30:15:33:43 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:15:33:43 Jenna JENNA-PC Path_Length: 149
2014/1/30:15:33:43 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AIF4FD.tmp
2014/1/30:15:33:43 Jenna JENNA-PC Launch
2014/1/30:15:34:24 Jenna JENNA-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/30:15:34:42 Jenna JENNA-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/30:15:34:42 Jenna JENNA-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jenna\AppData\Local\Temp\_AIF4FD.tmp\Setup\RevitSetup.dll
2014/1/30:15:34:42 Jenna JENNA-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/30:15:34:44 Jenna JENNA-PC PageOpen LaunchDialog
2014/1/30:15:39:10 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:15:45:18 Jenna JENNA-PC PageOpen ProductInfoDialog
2014/1/30:15:45:19 Jenna JENNA-PC PageOpen ProductSelectionDialog2
2014/1/30:15:45:25 Jenna JENNA-PC PageOpen FullProgressDialog
2014/1/30:15:45:26 Jenna JENNA-PC Download Play VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:15:45:28 Jenna JENNA-PC Download Complete VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:15:45:28 Jenna JENNA-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Jenna\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/1/30:15:45:48 Jenna JENNA-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/1/30:15:45:48 Jenna JENNA-PC Download Play DOTNET45 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DOTNET45...
2014/1/30:15:46:38 Jenna JENNA-PC Download Complete DOTNET45 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DOTNET45...
2014/1/30:15:46:38 Jenna JENNA-PC Installing .NET Framework Runtime 4.5: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\NET\45\wcu\dotNetFramework\dotnetfx45_full_x86_x64.exe" /q /norestart
2014/1/30:15:55:19 Jenna JENNA-PC Install .NET Framework Runtime 4.5 Succeeded
2014/1/30:15:55:19 Jenna JENNA-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/30:15:55:22 Jenna JENNA-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/30:15:55:22 Jenna JENNA-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/30:15:57:29 Jenna JENNA-PC Install DirectX® Runtime Succeeded
2014/1/30:15:57:31 Jenna JENNA-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/30:15:58:02 Jenna JENNA-PC Install FaroSDK Succeeded
2014/1/30:15:58:02 Jenna JENNA-PC Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:16:05:22 Jenna JENNA-PC Download Aborted RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:16:05:22 Jenna JENNA-PC Install Autodesk® Revit® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/1/30:16:05:36 Jenna JENNA-PC Rollback FaroSDK Succeeded
2014/1/30:16:05:36 Jenna JENNA-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/30:16:05:36 Jenna JENNA-PC Rollback .NET Framework Runtime 4.5 Failed Installation aborted, Result=1619
2014/1/30:16:05:36 Jenna JENNA-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/1/30:16:05:40 Jenna JENNA-PC PageOpen InstallCompleteDialog
2014/1/30:16:30:35 Jenna JENNA-PC === Setup ended ===
2014/1/30:18:53:16 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:18:53:16 Jenna JENNA-PC Path_Length: 149
2014/1/30:18:53:16 Jenna JENNA-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/30:18:53:16 Jenna JENNA-PC Launch
2014/1/30:18:53:16 Jenna JENNA-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-31253041 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/30:18:53:16 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI191B.tmp
2014/1/30:18:53:21 Jenna JENNA-PC === Setup ended ===
2014/1/30:18:53:17 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:18:53:17 Jenna JENNA-PC Path_Length: 149
2014/1/30:18:53:17 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI191B.tmp
2014/1/30:18:53:17 Jenna JENNA-PC Launch
2014/1/30:18:53:19 Jenna JENNA-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/30:18:53:19 Jenna JENNA-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jenna\AppData\Local\Temp\_AI191B.tmp\Setup\RevitSetup.dll
2014/1/30:18:53:19 Jenna JENNA-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/30:18:53:21 Jenna JENNA-PC PageOpen LaunchDialog
2014/1/30:18:57:22 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:18:57:29 Jenna JENNA-PC PageOpen ProductInfoDialog
2014/1/30:18:57:29 Jenna JENNA-PC PageOpen ProductSelectionDialog2
2014/1/30:18:57:39 Jenna JENNA-PC PageOpen FullProgressDialog
2014/1/30:18:57:56 Jenna JENNA-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/30:18:57:56 Jenna JENNA-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/30:18:58:45 Jenna JENNA-PC Install DirectX® Runtime Succeeded
2014/1/30:18:58:45 Jenna JENNA-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/30:18:59:09 Jenna JENNA-PC Install FaroSDK Succeeded
2014/1/30:18:59:10 Jenna JENNA-PC Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:19:01:09 Jenna JENNA-PC Download Error RVT2014 Decompressing failed http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:19:01:14 Jenna JENNA-PC Download Aborted RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:19:01:14 Jenna JENNA-PC Install Autodesk® Revit® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/1/30:19:01:15 Jenna JENNA-PC Rollback FaroSDK Succeeded
2014/1/30:19:01:15 Jenna JENNA-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/30:19:01:16 Jenna JENNA-PC PageOpen InstallCompleteDialog
2014/1/30:19:01:24 Jenna JENNA-PC === Setup ended ===
2014/1/30:19:01:59 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:19:01:59 Jenna JENNA-PC Path_Length: 149
2014/1/30:19:01:59 Jenna JENNA-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/30:19:01:59 Jenna JENNA-PC Launch
2014/1/30:19:01:59 Jenna JENNA-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-31253041 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/30:19:01:59 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI11DB.tmp
2014/1/30:19:02:02 Jenna JENNA-PC === Setup ended ===
2014/1/30:19:02:00 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:19:02:00 Jenna JENNA-PC Path_Length: 149
2014/1/30:19:02:00 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI11DB.tmp
2014/1/30:19:02:00 Jenna JENNA-PC Launch
2014/1/30:19:02:01 Jenna JENNA-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/30:19:02:01 Jenna JENNA-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jenna\AppData\Local\Temp\_AI11DB.tmp\Setup\RevitSetup.dll
2014/1/30:19:02:01 Jenna JENNA-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/30:19:02:02 Jenna JENNA-PC PageOpen LaunchDialog
2014/1/30:19:04:29 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:19:04:39 Jenna JENNA-PC PageOpen ProductInfoDialog
2014/1/30:19:04:39 Jenna JENNA-PC PageOpen ProductSelectionDialog2
2014/1/30:19:04:41 Jenna JENNA-PC PageOpen FullProgressDialog
2014/1/30:19:04:42 Jenna JENNA-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/30:19:04:42 Jenna JENNA-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/30:19:05:05 Jenna JENNA-PC Install DirectX® Runtime Succeeded
2014/1/30:19:05:05 Jenna JENNA-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/30:19:05:30 Jenna JENNA-PC Install FaroSDK Succeeded
2014/1/30:19:05:30 Jenna JENNA-PC Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:19:10:21 Jenna JENNA-PC Download Aborted RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:19:10:21 Jenna JENNA-PC Install Autodesk® Revit® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/1/30:19:10:30 Jenna JENNA-PC Rollback FaroSDK Succeeded
2014/1/30:19:10:30 Jenna JENNA-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/30:19:10:31 Jenna JENNA-PC PageOpen InstallCompleteDialog
2014/1/30:19:12:35 Jenna JENNA-PC === Setup ended ===
2014/1/30:19:15:11 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:19:15:11 Jenna JENNA-PC Path_Length: 149
2014/1/30:19:15:11 Jenna JENNA-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/30:19:15:11 Jenna JENNA-PC Launch
2014/1/30:19:15:11 Jenna JENNA-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-31253041 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/30:19:15:11 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI2BC1.tmp
2014/1/30:19:15:15 Jenna JENNA-PC === Setup ended ===
2014/1/30:19:15:13 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:19:15:13 Jenna JENNA-PC Path_Length: 149
2014/1/30:19:15:13 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI2BC1.tmp
2014/1/30:19:15:13 Jenna JENNA-PC Launch
2014/1/30:19:15:14 Jenna JENNA-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/30:19:15:15 Jenna JENNA-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jenna\AppData\Local\Temp\_AI2BC1.tmp\Setup\RevitSetup.dll
2014/1/30:19:15:15 Jenna JENNA-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/30:19:15:15 Jenna JENNA-PC PageOpen LaunchDialog
2014/1/30:19:18:06 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:19:19:17 Jenna JENNA-PC PageOpen ProductInfoDialog
2014/1/30:19:19:17 Jenna JENNA-PC PageOpen ProductSelectionDialog2
2014/1/30:19:20:21 Jenna JENNA-PC PageOpen FullProgressDialog
2014/1/30:19:20:22 Jenna JENNA-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/30:19:20:22 Jenna JENNA-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/30:19:21:19 Jenna JENNA-PC Install DirectX® Runtime Succeeded
2014/1/30:19:21:20 Jenna JENNA-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/30:19:21:45 Jenna JENNA-PC Install FaroSDK Succeeded
2014/1/30:19:21:45 Jenna JENNA-PC Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:19:23:44 Jenna JENNA-PC Download Error RVT2014 Decompressing failed http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:19:23:48 Jenna JENNA-PC Download Aborted RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:19:23:48 Jenna JENNA-PC Install Autodesk® Revit® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/1/30:19:23:50 Jenna JENNA-PC Rollback FaroSDK Succeeded
2014/1/30:19:23:50 Jenna JENNA-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/30:19:23:51 Jenna JENNA-PC PageOpen InstallCompleteDialog
2014/1/30:19:24:50 Jenna JENNA-PC === Setup ended ===
2014/1/30:19:32:29 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:19:32:29 Jenna JENNA-PC Path_Length: 149
2014/1/30:19:32:29 Jenna JENNA-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/30:19:32:29 Jenna JENNA-PC Launch
2014/1/30:19:32:29 Jenna JENNA-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/1/30:19:32:29 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI242.tmp
2014/1/30:19:32:47 Jenna JENNA-PC === Setup ended ===
2014/1/30:19:32:30 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:19:32:30 Jenna JENNA-PC Path_Length: 149
2014/1/30:19:32:30 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI242.tmp
2014/1/30:19:32:30 Jenna JENNA-PC Launch
2014/1/30:19:32:31 Jenna JENNA-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/1/30:19:32:46 Jenna JENNA-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/1/30:19:32:46 Jenna JENNA-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jenna\AppData\Local\Temp\_AI242.tmp\Setup\RevitSetup.dll
2014/1/30:19:32:46 Jenna JENNA-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/30:19:32:46 Jenna JENNA-PC PageOpen LaunchDialog
2014/1/30:19:32:52 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:19:32:56 Jenna JENNA-PC PageOpen ProductSelectionDialog2
2014/1/30:19:33:06 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:19:33:07 Jenna JENNA-PC PageOpen LaunchDialog
2014/1/30:19:33:15 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:19:33:18 Jenna JENNA-PC PageOpen ProductInfoDialog
2014/1/30:19:34:24 Jenna JENNA-PC PageOpen ProductSelectionDialog2
2014/1/30:19:34:47 Jenna JENNA-PC PageOpen FullProgressDialog
2014/1/30:19:34:47 Jenna JENNA-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/1/30:19:34:50 Jenna JENNA-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/1/30:19:34:50 Jenna JENNA-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/30:19:35:16 Jenna JENNA-PC Install DirectX® Runtime Succeeded
2014/1/30:19:35:16 Jenna JENNA-PC Download Play FaroSDK http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/FaroSDK_x64....
2014/1/30:19:35:21 Jenna JENNA-PC Download Complete FaroSDK http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/FaroSDK_x64....
2014/1/30:19:35:21 Jenna JENNA-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/30:19:35:34 Jenna JENNA-PC Install FaroSDK Succeeded
2014/1/30:19:35:35 Jenna JENNA-PC Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/1/30:19:39:24 Jenna JENNA-PC Download Complete RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/1/30:19:39:29 Jenna JENNA-PC Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Jenna\AppData\Local\Temp\_AI242.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/30:19:52:13 Jenna JENNA-PC === Setup ended ===
2014/1/30:19:56:40 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:19:56:40 Jenna JENNA-PC Path_Length: 149
2014/1/30:19:56:40 Jenna JENNA-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/30:19:56:40 Jenna JENNA-PC Launch
2014/1/30:19:56:40 Jenna JENNA-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/1/30:19:56:40 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI2608.tmp
2014/1/30:19:56:54 Jenna JENNA-PC === Setup ended ===
2014/1/30:19:56:43 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:19:56:43 Jenna JENNA-PC Path_Length: 149
2014/1/30:19:56:43 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI2608.tmp
2014/1/30:19:56:43 Jenna JENNA-PC Launch
2014/1/30:19:56:52 Jenna JENNA-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/1/30:19:56:53 Jenna JENNA-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jenna\AppData\Local\Temp\_AI2608.tmp\Setup\RevitSetup.dll
2014/1/30:19:56:53 Jenna JENNA-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/30:19:56:54 Jenna JENNA-PC PageOpen LaunchDialog
2014/1/30:19:57:17 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:19:57:21 Jenna JENNA-PC PageOpen ProductInfoDialog
2014/1/30:20:04:52 Jenna JENNA-PC PageOpen ProductSelectionDialog2
2014/1/30:20:10:41 Jenna JENNA-PC PageOpen FullProgressDialog
2014/1/30:20:10:41 Jenna JENNA-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/1/30:20:10:41 Jenna JENNA-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/30:20:11:34 Jenna JENNA-PC Install DirectX® Runtime Succeeded
2014/1/30:20:11:35 Jenna JENNA-PC Download Skipped RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/1/30:20:11:39 Jenna JENNA-PC Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Jenna\AppData\Local\Temp\_AI2608.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/30:20:34:45 Jenna JENNA-PC Install Autodesk® Revit® 2014 Succeeded
2014/1/30:20:34:45 Jenna JENNA-PC Download Play RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64_...
2014/1/30:20:34:58 Jenna JENNA-PC Download Aborted RVT2014_en-us http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64_...
2014/1/30:20:34:58 Jenna JENNA-PC Install Autodesk® Revit® 2014 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/1/30:20:41:40 Jenna JENNA-PC Rollback Autodesk® Revit® 2014 Succeeded
2014/1/30:20:41:40 Jenna JENNA-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/30:20:41:41 Jenna JENNA-PC PageOpen InstallCompleteDialog
2014/1/30:20:50:38 Jenna JENNA-PC === Setup ended ===
2014/1/30:20:52:42 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:20:52:42 Jenna JENNA-PC Path_Length: 149
2014/1/30:20:52:42 Jenna JENNA-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/30:20:52:42 Jenna JENNA-PC Launch
2014/1/30:20:52:42 Jenna JENNA-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-31253041 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/30:20:52:42 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI72B2.tmp
2014/1/30:20:52:53 Jenna JENNA-PC === Setup ended ===
2014/1/30:20:52:44 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:20:52:44 Jenna JENNA-PC Path_Length: 149
2014/1/30:20:52:44 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI72B2.tmp
2014/1/30:20:52:44 Jenna JENNA-PC Launch
2014/1/30:20:52:52 Jenna JENNA-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/30:20:52:52 Jenna JENNA-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jenna\AppData\Local\Temp\_AI72B2.tmp\Setup\RevitSetup.dll
2014/1/30:20:52:52 Jenna JENNA-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/30:20:52:53 Jenna JENNA-PC PageOpen LaunchDialog
2014/1/30:20:54:22 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:20:54:26 Jenna JENNA-PC PageOpen ProductInfoDialog
2014/1/30:20:54:26 Jenna JENNA-PC PageOpen ProductSelectionDialog2
2014/1/30:20:54:34 Jenna JENNA-PC PageOpen FullProgressDialog
2014/1/30:20:54:35 Jenna JENNA-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/30:20:54:35 Jenna JENNA-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/30:20:55:19 Jenna JENNA-PC Install DirectX® Runtime Succeeded
2014/1/30:20:55:19 Jenna JENNA-PC Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:21:01:55 Jenna JENNA-PC Download Aborted RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:21:01:55 Jenna JENNA-PC Install Autodesk® Revit® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/1/30:21:02:01 Jenna JENNA-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/30:21:02:05 Jenna JENNA-PC PageOpen InstallCompleteDialog
2014/1/30:21:06:12 Jenna JENNA-PC === Setup ended ===
2014/1/30:21:07:11 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:21:07:11 Jenna JENNA-PC Path_Length: 149
2014/1/30:21:07:11 Jenna JENNA-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/30:21:07:11 Jenna JENNA-PC Launch
2014/1/30:21:07:11 Jenna JENNA-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-31253041 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/30:21:07:11 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AIB32B.tmp
2014/1/30:21:07:18 Jenna JENNA-PC === Setup ended ===
2014/1/30:21:07:15 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:21:07:15 Jenna JENNA-PC Path_Length: 149
2014/1/30:21:07:15 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AIB32B.tmp
2014/1/30:21:07:15 Jenna JENNA-PC Launch
2014/1/30:21:07:16 Jenna JENNA-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/30:21:07:17 Jenna JENNA-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jenna\AppData\Local\Temp\_AIB32B.tmp\Setup\RevitSetup.dll
2014/1/30:21:07:17 Jenna JENNA-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/30:21:07:18 Jenna JENNA-PC PageOpen LaunchDialog
2014/1/30:21:07:57 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:21:08:02 Jenna JENNA-PC PageOpen ProductSelectionDialog2
2014/1/30:21:08:15 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:21:08:16 Jenna JENNA-PC PageOpen LaunchDialog
2014/1/30:21:10:59 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:21:11:03 Jenna JENNA-PC PageOpen ProductInfoDialog
2014/1/30:21:11:03 Jenna JENNA-PC PageOpen ProductSelectionDialog2
2014/1/30:21:11:33 Jenna JENNA-PC PageOpen FullProgressDialog
2014/1/30:21:11:33 Jenna JENNA-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/30:21:11:33 Jenna JENNA-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/30:21:12:17 Jenna JENNA-PC Install DirectX® Runtime Succeeded
2014/1/30:21:12:18 Jenna JENNA-PC Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:21:14:36 Jenna JENNA-PC Download Error RVT2014 Decompressing failed http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:21:14:40 Jenna JENNA-PC Download Aborted RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:21:14:40 Jenna JENNA-PC Install Autodesk® Revit® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/1/30:21:14:41 Jenna JENNA-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/30:21:14:43 Jenna JENNA-PC PageOpen InstallCompleteDialog
2014/1/30:21:15:58 Jenna JENNA-PC === Setup ended ===
2014/1/30:21:52:35 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:21:52:35 Jenna JENNA-PC Path_Length: 149
2014/1/30:21:52:35 Jenna JENNA-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/30:21:52:35 Jenna JENNA-PC Launch
2014/1/30:21:52:35 Jenna JENNA-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-31253041 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/30:21:52:35 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI4694.tmp
2014/1/30:21:52:40 Jenna JENNA-PC === Setup ended ===
2014/1/30:21:52:38 Jenna JENNA-PC === Setup started on JENNA-PC by Jenna ===
2014/1/30:21:52:38 Jenna JENNA-PC Path_Length: 149
2014/1/30:21:52:38 Jenna JENNA-PC Current Directory C:\Users\Jenna\AppData\Local\Temp\_AI4694.tmp
2014/1/30:21:52:38 Jenna JENNA-PC Launch
2014/1/30:21:52:39 Jenna JENNA-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/30:21:52:39 Jenna JENNA-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Jenna\AppData\Local\Temp\_AI4694.tmp\Setup\RevitSetup.dll
2014/1/30:21:52:39 Jenna JENNA-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/30:21:52:40 Jenna JENNA-PC PageOpen LaunchDialog
2014/1/30:21:55:18 Jenna JENNA-PC PageOpen LicenseDialog
2014/1/30:21:55:25 Jenna JENNA-PC PageOpen ProductInfoDialog
2014/1/30:21:55:25 Jenna JENNA-PC PageOpen ProductSelectionDialog2
2014/1/30:21:55:32 Jenna JENNA-PC PageOpen FullProgressDialog
2014/1/30:21:55:33 Jenna JENNA-PC Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:55:35 Jenna JENNA-PC Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:55:35 Jenna JENNA-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/1/30:21:55:49 Jenna JENNA-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2014/1/30:21:55:49 Jenna JENNA-PC Download Play VCREDIST2008SP1X64_6161 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:55:51 Jenna JENNA-PC Download Complete VCREDIST2008SP1X64_6161 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:55:51 Jenna JENNA-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2014/1/30:21:56:03 Jenna JENNA-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2014/1/30:21:56:03 Jenna JENNA-PC Download Skipped VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:56:03 Jenna JENNA-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Jenna\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/1/30:21:56:11 Jenna JENNA-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/1/30:21:56:12 Jenna JENNA-PC Download Play VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:56:14 Jenna JENNA-PC Download Complete VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:56:14 Jenna JENNA-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Jenna\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/1/30:21:56:26 Jenna JENNA-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/1/30:21:56:26 Jenna JENNA-PC Download Play VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:56:28 Jenna JENNA-PC Download Complete VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:56:28 Jenna JENNA-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/1/30:21:56:32 Jenna JENNA-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/1/30:21:56:33 Jenna JENNA-PC Download Play VCREDIST2008SP1X86_6161 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:56:35 Jenna JENNA-PC Download Complete VCREDIST2008SP1X86_6161 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:56:36 Jenna JENNA-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2014/1/30:21:56:48 Jenna JENNA-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2014/1/30:21:56:48 Jenna JENNA-PC Download Play VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:56:51 Jenna JENNA-PC Download Complete VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:56:51 Jenna JENNA-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/1/30:21:56:57 Jenna JENNA-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2014/1/30:21:56:58 Jenna JENNA-PC Download Play VCREDIST2010SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:57:00 Jenna JENNA-PC Download Complete VCREDIST2010SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:57:00 Jenna JENNA-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2014/1/30:21:57:06 Jenna JENNA-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2014/1/30:21:57:06 Jenna JENNA-PC Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:57:08 Jenna JENNA-PC Download Complete VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:57:08 Jenna JENNA-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Jenna\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/1/30:21:57:24 Jenna JENNA-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/1/30:21:57:24 Jenna JENNA-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:57:26 Jenna JENNA-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/30:21:57:26 Jenna JENNA-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Jenna\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/1/30:21:57:39 Jenna JENNA-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2014/1/30:21:57:39 Jenna JENNA-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/30:21:57:39 Jenna JENNA-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/30:21:58:06 Jenna JENNA-PC Install DirectX® Runtime Succeeded
2014/1/30:21:58:06 Jenna JENNA-PC Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:22:04:26 Jenna JENNA-PC Download Aborted RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/30:22:04:26 Jenna JENNA-PC Install Autodesk® Revit® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/1/30:22:04:27 Jenna JENNA-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/30:22:04:28 Jenna JENNA-PC Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619
2014/1/30:22:04:29 Jenna JENNA-PC Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2014/1/30:22:04:30 Jenna JENNA-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/1/30:22:04:32 Jenna JENNA-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/1/30:22:04:34 Jenna JENNA-PC Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/1/30:22:04:35 Jenna JENNA-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Sorry to hear that you encounter issues installing "Revit 2014".
The installation fails installing the "Microsoft Visual C++" modules, for that reason try to remove the corresponding "Microsoft Visual C++ 2005/2008/2010" modules from "Uninstall or change a program" (assuming you have Win7) and re-attempt the installation.
If it still fails, re-forward the generated log file.
Hope it helps resolve the issue.
Cheers
Your actual failure is not a prerequisite in this case. The failure is here:
I have a KB article about that. You can find the work-around to this issue here:
Good Luck!
Jenna,
The information provided about the .NET is inaccurate. That is not where the problem exists. If you see where I truncated your log, it is a downloading issue. This problem can most likely be readily resolved by downloading the product from the virtual assistant. I provided the instructions in my link above.
Let me know if you have any continued issues.
Good Luck!
