Installation & Licensing
Installation problems
5 REPLIES 5
crioced
1076 Views, 5 Replies
Hi @ all,
i really hope someone can help me.
I'm stucked during the initialization process few second l8r the double clicking of setup.exe
I'm trying to install Acad 12 on a new personal computer in our company but i always get the same error.
"Unable to open the device or the specified file c:\temp\...\.. ..\ads2012\SetupDesignReview2012.msi"
I've tryied reinstalling all .net and visual c++ software but nothing.
I tried also setting the temp dir outside the "user" directory but nothing.
Anyone can help me pls?
Thank you
Bob
5 REPLIES 5
fabiobaldini1259
in reply to: crioced
  I have the same problem on map3d 2013 e autocad LT 2014 downloaded or installed directly from the subscription center.
 Thanks Fabio
TravisNave
If another downloaded copy doesn't work for you, try installing without Design Review checked.
Autodesk Forums:
crioced
in reply to: TravisNave
Thank you for you answer but the error comes out during the inizialization process.
I cant reach the setup menu.
1) i put in the dvd;
2) i wait 5/10 seconds (inizialization)
3) and then comes out the error.
I cant reach the menu where i can choose what i need to install.
Is it possible to force the inizialization process ang start by choosing the product i need?
Thank you
fabiobaldini1259
I solved my problem disabling the antivirus (trendmicro)
crioced
in reply to: fabiobaldini1259
Thank you very much. Tou made my day 😄
Joking a part thank you.
I tried everything but the Trendmicro...
Thank you.
Solved
Administrator Productivity
