When I try to install Inventor 2015, I have this error:
2014/9/9:21:39:55 HP ERIK Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\HP\AppData\Local\Temp\vcredist_x64_2012.log
2014/9/9:21:39:56 HP ERIK Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/9:21:39:56 HP ERIK Download Play CMILL http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/CMILL.ta...
2014/9/9:21:43:57 HP ERIK Download Aborted CMILL http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/CMILL.ta...
2014/9/9:21:43:57 HP ERIK Install Autodesk Material Library 2015 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
I installed another version, I disabled my Fire Wall, I installed Inventor 2015 with another language, I try the installation with the buttons (Install Now and Browser Download) and I erased my temp files.
I don't know what else to try.
I have Windows 8.1 on my computer.
Solved by TravisNave. Go to Solution.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
