Installation & Licensing
Installation problems with Autocad 2013
2 REPLIES 2
327 Views, 2 Replies
I am trying to install Autocad 2013, it is installed in my computer but when I try to open it, I have this message
I went to autodesk help and it says that I need to desable the IP6 and able the IP4, I did all that, but still I can get Autocad to open, and I get this screen when I do everything that it says in microsoft help.
Hopefullly some one can help.
Ricardo
2 REPLIES 2
DarrenP
if you can't ping the server then you have a network communication problem
can you ping by hostname?
do you have an IT person available?
try allowing these firewall ports
The FLEXlm® based version uses the following ports:
TCP ports 2080 (for the adskflex vendor daemon)
TCP ports 27000 to 27009 (for the lmgrd master daemon)
DarrenP
TravisNave
That appears to be a public IP address also.  Typically, those block PING by default.
Autodesk Forums:
Administrator Productivity
