Installation & Licensing
hannaalbag
560 Views, 6 Replies
Installation Problem
I have a new laptop and trying to install a few Autodesk programs (Autocad, 3Max, etc.). However, the installation keeps failing. I've attached the error log. Can anyone help me please?
Thanks in advance,
Hanna
6 REPLIES 6
Otto
in reply to: hannaalbag
Hello hannaalbag and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
hannaalbag
in reply to: Darin.Green
Thanks, David. I'll try what you've suggested and update
hannaalbag
Sorry, Darin (mistakenly wrote David...)
natasha.l
Hello @hannaalbag,
Welcome to the forum, I am glad you posted.
As @Darin.Green mentioned you can download your software via the Autodesk Virtual Agent.
Please proceed as follows:
  • Logon as an Administrator.
  • Empty your TEMP folder.  To open the TEMP folder, type %TEMP% in the address bar of Windows Explorer and hit Enter.
  • Disable your Antivirus software.
  • Disable UAC.
W7: http://windows.microsoft.com/en-ca/windows7/turn-user-account-control-on-or-off
W10: http://winaero.com/blog/how-to-turn-off-and-disable-uac-in-windows-10/
  • Download all of the parts
  • Locate the download folder and extract (double click) part _001_00X.sfx.exe. If you have a permission issue right click and select, Run as administrator.
  • Files will be directed to C:\Autodesk
  • Follow the prompts to install the program
I hope this answered your question or resolved the issue, if so please click Kudos or the "thumbs-up!" Did my response help resolve the issue? Please "Accept As Solution" to help others in the community.
natasha.l
Hello @hannaalbag,
I wanted to check-in with you, I hope you were able to resolve the issues regarding the download & installation of your Autodesk products.
I hope I was able to answer your question or resolved the issue, if so please click
Kudos or the "thumbs-up!" icon.
Thank you.
Administrator Productivity
