After an uninstall of Autodesk Inventor Professional Suite 2010, I am not able to install some of the products on the same computer (Design Review and Mechanical 2010). It doesnot provide any access where can I check the products to be intalled? This problems comes before even the installer asks for serial number and etc.
regards,
saqib
Solved by hashim.mundol. Go to Solution.
Do you get any error ?
Do you see Design review and Mechanical in the Add/remove (programs) list in the control panel.
Uninstalling Inventor Prof. Suite will not uninstall design review and Mechanical.
No I dont see any error message.
I dont see any product being installed in the installer window. I cant check boxes!
regards,
saqib
It could be a corrupt installation. please use the Microsoft online tool to clean the installation
http://support.microsoft.com/mats/Program_Install_and_Uninstall
Im in the same boat with a standalone version of Revit Arch Suite 2011..
New parallels install, with SP3, IE 8.something, 3+ GB RAM, and cannot get check boxes for Revit Architecture, only design review. Ran the uninstall utility just to confirm there was nothing and got the 'nothing to uninstall' message.. any ideas of what might be preventing Revit Arch. from install?
Even though it solved my problem partially, a problem still exists.In the installer window when I try to install service packs, it never gets completed! and continues to download something.... This happens when I try to configure installation paths and etc. and therefoe no installation!
regards and thanks
saqib
Please install without the service pack. Install the service pack later on by manually downloading it.
