I am trying to install Navisworks Freedom 2011 on a PC running Windows 7 Home Premium. I downloaded the file and double clicked to start. A whole bunch of files extract to C:\Autodesk. Then I get a dialog box asking me to install products, read the documentation or change the language. I select install products. Then I get a second dialog asking me what products I want to install. There is only one on the list - Navisworks Freedom 2011 but the check box is greyed out. Below it says "This product cannot be installed on the current operating system"
What can I do?
Solved by DarrenP. Go to Solution.
make you are using the correct version 32 bit for 32 bit os 64 bit for 64 bit os
DarrenP
