having trouble installing revit 2013. as shown in attachment. plz help plz...
Solved by TravisNave. Go to Solution.
Hi pgmistry.1991,
Have a look at this thread and see if the solutions there solve your installation issue please (the products are difrerent but the resolution should be the same).
Let us know!
Your product is probably failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue located in that installation log file and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Excellent. Make sure you mark the thread as an accepted solution to close it out. Thanks!
