Installation & Licensing
New Member
manfredi
Message 1 of 12 (19,237 Views)
Installation problem - Installation aborted, Result=1619
19237 Views, 11 Replies
06-01-2012 08:53 AM
Hi. I have an installation problem.
I am trying to install AutoCad 2012 on my MacBook Air (Windows 7 OS).
This is the install log:
2012/6/1:17:41:22	Manfredi	MANFREDI-AIR	=== Setup started on MANFREDI-AIR by Manfredi ===
2012/6/1:17:41:22	Manfredi	MANFREDI-AIR	Launch
2012/6/1:17:41:32	Manfredi	MANFREDI-AIR	=== Setup ended ===
2012/6/1:17:41:32	Manfredi	MANFREDI-AIR	PageOpen	LaunchDialog
2012/6/1:17:41:45	Manfredi	MANFREDI-AIR	PageOpen	LicenseDialog
2012/6/1:17:41:45	Manfredi	MANFREDI-AIR	PageOpen	ProductSelectionDialog2
2012/6/1:17:41:57	Manfredi	MANFREDI-AIR	PageOpen	LicenseDialog
2012/6/1:17:41:57	Manfredi	MANFREDI-AIR	PageOpen	LaunchDialog
2012/6/1:17:42:07	Manfredi	MANFREDI-AIR	PageOpen	LicenseDialog
2012/6/1:17:42:17	Manfredi	MANFREDI-AIR	PageOpen	ProductInfoDialog
2012/6/1:17:42:43	Manfredi	MANFREDI-AIR	PageOpen	ProductSelectionDialog2
2012/6/1:17:43:16	Manfredi	MANFREDI-AIR	PageOpen	FullProgressDialog
2012/6/1:17:43:16	Manfredi	MANFREDI-AIR	Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1040.exe /q
2012/6/1:17:44:03	Manfredi	MANFREDI-AIR	Install	.NET Framework Runtime 4.0 Language Pack	Succeeded
2012/6/1:17:44:03	Manfredi	MANFREDI-AIR	Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/6/1:17:44:21	Manfredi	MANFREDI-AIR	Install	DirectX Runtime	Succeeded
2012/6/1:17:44:21	Manfredi	MANFREDI-AIR	Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/6/1:17:44:27	Manfredi	MANFREDI-AIR	Install	FaroSDK	Succeeded
2012/6/1:17:44:27	Manfredi	MANFREDI-AIR	Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/6/1:17:44:40	Manfredi	MANFREDI-AIR	Install	Autodesk Material Library 2012	Succeeded
2012/6/1:17:44:40	Manfredi	MANFREDI-AIR	Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/6/1:17:45:03	Manfredi	MANFREDI-AIR	Install	Autodesk Material Library 2012 - Low Resolution	Succeeded
2012/6/1:17:45:03	Manfredi	MANFREDI-AIR	Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v R:\Temp\vcredist_x86_2005.log"" "
2012/6/1:17:45:04	Manfredi	MANFREDI-AIR	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1603
2012/6/1:17:45:19	Manfredi	MANFREDI-AIR	Rollback	Autodesk Material Library 2012 - Low Resolution	Succeeded
2012/6/1:17:45:32	Manfredi	MANFREDI-AIR	Rollback	Autodesk Material Library 2012	Succeeded
2012/6/1:17:45:33	Manfredi	MANFREDI-AIR	Rollback	FaroSDK	Succeeded
2012/6/1:17:45:33	Manfredi	MANFREDI-AIR	Rollback	DirectX Runtime	Failed	Failure is ignored, Result=1619
2012/6/1:17:45:33	Manfredi	MANFREDI-AIR	Rollback	.NET Framework Runtime 4.0 Language Pack	Failed	Installation aborted, Result=1619
Can you please help me? I think that I should do something with .NET Framework.
Install Autodesk® Maya LT™ 2015 Failed Download Failed, Installation aborted, Result=1603
 I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-re-download-software.html
TravisNave
Message 2 of 12 (19,233 Views)
Re: Installation problem - Installation aborted, Result=1619
06-01-2012 09:01 AM in reply to: manfredi
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
New Member
manfredi
Message 3 of 12 (19,225 Views)
06-01-2012 10:50 AM in reply to: TravisNave
Thanks for the answer. I spent my day tring to unistall and install again all the C++ and similar Microsoft packages to install Autocad. I unistalled all the stuff like .NET FrameWork, C++, languages pack, everything. I have also done more than one reboot. The only result I got is that now my copy of MatLab is now not working.
I tried to read your blog and the forum discussion but I found no useful tip for my needs.
This is the last log that I got a few minutes ago after antoher installation fail:
2012/6/1:19:37:14	Manfredi	MANFREDI-AIR	=== Setup started on MANFREDI-AIR by Manfredi ===
2012/6/1:19:37:14	Manfredi	MANFREDI-AIR	Launch
2012/6/1:19:37:20	Manfredi	MANFREDI-AIR	=== Setup ended ===
2012/6/1:19:37:15	Manfredi	MANFREDI-AIR	=== Setup started on MANFREDI-AIR by Manfredi ===
2012/6/1:19:37:15	Manfredi	MANFREDI-AIR	Launch
2012/6/1:19:37:20	Manfredi	MANFREDI-AIR	PageOpen	LaunchDialog
2012/6/1:19:37:33	Manfredi	MANFREDI-AIR	PageOpen	LicenseDialog
2012/6/1:19:37:36	Manfredi	MANFREDI-AIR	PageOpen	ProductInfoDialog
2012/6/1:19:38:02	Manfredi	MANFREDI-AIR	PageOpen	ProductSelectionDialog2
2012/6/1:19:38:05	Manfredi	MANFREDI-AIR	PageOpen	FullProgressDialog
2012/6/1:19:38:05	Manfredi	MANFREDI-AIR	Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/6/1:19:42:01	Manfredi	MANFREDI-AIR	Install	.NET Framework Runtime 4.0	Succeeded
2012/6/1:19:42:01	Manfredi	MANFREDI-AIR	Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1040.exe /q
2012/6/1:19:42:41	Manfredi	MANFREDI-AIR	Install	.NET Framework Runtime 4.0 Language Pack	Succeeded
2012/6/1:19:42:41	Manfredi	MANFREDI-AIR	Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/6/1:19:42:47	Manfredi	MANFREDI-AIR	Install	Microsoft Visual C++ 2008 SP1 Redistributable (x86)	Succeeded
2012/6/1:19:42:47	Manfredi	MANFREDI-AIR	Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2012/6/1:19:42:52	Manfredi	MANFREDI-AIR	Install	Microsoft Visual C++ 2008 SP1 Redistributable (x64)	Succeeded
2012/6/1:19:42:52	Manfredi	MANFREDI-AIR	Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/6/1:19:43:08	Manfredi	MANFREDI-AIR	Install	DirectX Runtime	Succeeded
2012/6/1:19:43:08	Manfredi	MANFREDI-AIR	Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/6/1:19:43:12	Manfredi	MANFREDI-AIR	Install	FaroSDK	Succeeded
2012/6/1:19:43:12	Manfredi	MANFREDI-AIR	Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/6/1:19:43:22	Manfredi	MANFREDI-AIR	Install	Autodesk Material Library 2012	Succeeded
2012/6/1:19:43:22	Manfredi	MANFREDI-AIR	Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/6/1:19:43:49	Manfredi	MANFREDI-AIR	Install	Autodesk Material Library 2012 - Low Resolution	Succeeded
2012/6/1:19:43:49	Manfredi	MANFREDI-AIR	Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v R:\Temp\vcredist_x86_2005.log"" "
2012/6/1:19:43:49	Manfredi	MANFREDI-AIR	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1603
2012/6/1:19:44:05	Manfredi	MANFREDI-AIR	Rollback	Autodesk Material Library 2012 - Low Resolution	Succeeded
2012/6/1:19:44:20	Manfredi	MANFREDI-AIR	Rollback	Autodesk Material Library 2012	Succeeded
2012/6/1:19:44:21	Manfredi	MANFREDI-AIR	Rollback	FaroSDK	Succeeded
2012/6/1:19:44:21	Manfredi	MANFREDI-AIR	Rollback	DirectX Runtime	Failed	Failure is ignored, Result=1619
2012/6/1:19:44:21	Manfredi	MANFREDI-AIR	Rollback	.NET Framework Runtime 4.0 Language Pack	Failed	Installation aborted, Result=1619
2012/6/1:19:44:21	Manfredi	MANFREDI-AIR	Rollback	.NET Framework Runtime 4.0	Failed	Installation aborted, Result=1619
I would really like to have some help, thanks.
TravisNave
Message 4 of 12 (19,223 Views)
06-01-2012 11:00 AM in reply to: manfredi
Same failure.  Make sure that there are no Microsoft Visual C++ Redistributable versions in your Add/Remove Programs in Control Panel.
New Member
LucianNovo
Message 5 of 12 (17,779 Views)
10-10-2012 10:46 PM in reply to: manfredi
Hello there,
    thank you for responding to this thread. I am having a similar problem only it reads "installation aborted, Result=1603". Do you have any suggestions? The entire transcript is provided below. I greately appreciate the help that you've already given the forum.
2012/10/11:05:18:11 LucianNov LUCIANNOV-PC === Setup started on LUCIANNOV-PC by LucianNov === 2012/10/11:05:18:11 LucianNov LUCIANNOV-PC Launch 2012/10/11:05:18:20 LucianNov LUCIANNOV-PC === Setup ended ===
2012/10/11:05:18:11 LucianNov LUCIANNOV-PC === Setup started on LUCIANNOV-PC by LucianNov === 2012/10/11:05:18:11 LucianNov LUCIANNOV-PC Launch 2012/10/11:05:18:15 LucianNov LUCIANNOV-PC Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message: 2012/10/11:05:18:15 LucianNov LUCIANNOV-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2012/10/11:05:18:15 LucianNov LUCIANNOV-PC Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2012/10/11:05:18:20 LucianNov LUCIANNOV-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2012/10/11:05:18:20 LucianNov LUCIANNOV-PC PageOpen LaunchDialog   2012/10/11:05:18:28 LucianNov LUCIANNOV-PC Inventorui== Parameter: Prereq_13 SetupMode:4 InstallState:2 InstallAction:11 Message: 2012/10/11:05:18:28 LucianNov LUCIANNOV-PC Inventorui== Parameter: Prereq_14 SetupMode:4 InstallState:2 InstallAction:11 Message: 2012/10/11:05:18:32 LucianNov LUCIANNOV-PC You are creating a 64-bit deployment for Autodesk Inventor 2012. To create a 32-bit deployment for Autodesk Inventor 2012 please insert the 32-bit disc or download the 32-bit installer for Autodesk Inventor 2012. 2012/10/11:05:18:41 LucianNov LUCIANNOV-PC PageOpen BeginDeploymentDialog   2012/10/11:05:18:58 LucianNov LUCIANNOV-PC PageOpen LaunchDialog   2012/10/11:05:19:13 LucianNov LUCIANNOV-PC PageOpen LicenseDialog   2012/10/11:05:20:20 LucianNov LUCIANNOV-PC PageOpen ProductInfoDialog   2012/10/11:05:23:14 LucianNov LUCIANNOV-PC PageOpen InventorFlavorSelectionDialog   2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==DefaultLanguage: en-us    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==InstallName: INVENTOR    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==ProductName: Autodesk Inventor 2012    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==DisplayName: Autodesk® Inventor® 2012    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==DeploymentName:     2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==SetupTitle: Autodesk Inventor 2012    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==ConfigTransform:     2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==ExeParams:     2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==ProductCode: {7F4DD591-1664-0409-0000-7107D70F3DB4}    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==SupportLink:     2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==InfotainmentLink:     2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==MsiFileName: inventor.msi    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==AdminImageConfigName: AdminImagex64    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==AdminImageRoot: AdminImage    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==GetBaseDeploymentName:     2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==DeploymentLocation:     2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==InstallDeploymentShortcut:     2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==ModifyDeploymentShortcut:     2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==SetupLockType: 2    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==SetupNetworkType:  0    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==SystemLocale: 1033    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==EvalMsiFilePath: C:\Users\LUCIAN~1\AppData\Local\Temp\_AI36FB.tmp\SetupRes\eval.msi    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==EulaPath: C:\Users\LUCIAN~1\AppData\Local\Temp\_AI36FB.tmp\EULA    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==InstallLogPath: C:\Users\LUCIAN~1\AppData\Local\Temp\Inventor2012Install.log    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==ConfigFile: C:\Users\LUCIAN~1\AppData\Local\Temp\_AI36FB.tmp\Setup.ini    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==SetupPath: C:\Users\LucianNov\Desktop\    2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==NetworkLogPath:     2012/10/11:05:23:14 LucianNov LUCIANNOV-PC Inventorui==SourceRoot: C:\Users\LucianNov\Desktop\    2012/10/11:05:23:16 LucianNov LUCIANNOV-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2012/10/11:05:23:16 LucianNov LUCIANNOV-PC PageOpen ProductSelectionDialog2   2012/10/11:05:24:00 LucianNov LUCIANNOV-PC PageOpen FullProgressDialog   2012/10/11:05:24:00 LucianNov LUCIANNOV-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Users\LucianNov\Desktop\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\LUCIAN~1\AppData\Local\Temp\vcredist_x86_2010.log 2012/10/11:05:24:04 LucianNov LUCIANNOV-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
TravisNave
Message 6 of 12 (17,741 Views)
10-11-2012 07:02 AM in reply to: LucianNovo
Failing for the same reason as the original post.
Good Luck!
New Member
ibeysie
Message 7 of 12 (15,816 Views)
12-07-2012 07:46 AM in reply to: manfredi
2012/12/7:23:16:05 -bhey- NHAY-HP === Setup started on NHAY-HP by -bhey- ===
2012/12/7:23:16:05 -bhey- NHAY-HP Launch
2012/12/7:23:17:44 -bhey- NHAY-HP === Setup ended ===
2012/12/7:23:16:08 -bhey- NHAY-HP === Setup started on NHAY-HP by -bhey- ===
2012/12/7:23:16:08 -bhey- NHAY-HP Launch
2012/12/7:23:17:52 -bhey- NHAY-HP PageOpen LaunchDialog
2012/12/7:23:20:36 -bhey- NHAY-HP PageOpen LicenseDialog
2012/12/7:23:21:56 -bhey- NHAY-HP PageOpen ProductInfoDialog
2012/12/7:23:25:38 -bhey- NHAY-HP PageOpen ProductSelectionDialog2
2012/12/7:23:25:48 -bhey- NHAY-HP PageOpen FullProgressDialog
2012/12/7:23:25:49 -bhey- NHAY-HP Installing DirectX Runtime: C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/7:23:27:55 -bhey- NHAY-HP Install DirectX Runtime Succeeded
2012/12/7:23:27:55 -bhey- NHAY-HP Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/7:23:28:30 -bhey- NHAY-HP Install FaroSDK Succeeded
2012/12/7:23:28:30 -bhey- NHAY-HP Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/7:23:30:12 -bhey- NHAY-HP Install Autodesk Material Library 2012 Succeeded
2012/12/7:23:30:13 -bhey- NHAY-HP Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/7:23:32:43 -bhey- NHAY-HP Install Autodesk Material Library 2012 - Low Resolution Succeeded
2012/12/7:23:32:43 -bhey- NHAY-HP Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/7:23:33:41 -bhey- NHAY-HP Install Autodesk Content Service Succeeded
2012/12/7:23:33:51 -bhey- NHAY-HP Installing AutoCAD® Architecture 2012: TRANSFORMS="C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\x64\en-us\ACA\ACA.mst;C:\Users\-bhey-.nhay-HP\AppData\Local\Temp\_AI8A63.tmp\x64\ACA\ACA-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Architecture 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/7:23:34:09 -bhey- NHAY-HP Install AutoCAD® Architecture 2012 Failed Installation aborted, Result=1603
2012/12/7:23:35:03 -bhey- NHAY-HP Rollback Autodesk Content Service Succeeded
2012/12/7:23:37:04 -bhey- NHAY-HP Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2012/12/7:23:38:37 -bhey- NHAY-HP Rollback Autodesk Material Library 2012 Succeeded
2012/12/7:23:39:18 -bhey- NHAY-HP Rollback FaroSDK Succeeded
2012/12/7:23:39:20 -bhey- NHAY-HP Rollback DirectX Runtime Failed Failure is ignored, Result=1619
ehto po sakin...ndi ko lam kung bakit...phelp nman po...
Product Support
dembkod
Message 8 of 12 (15,673 Views)
12-10-2012 09:03 AM in reply to: manfredi
If uninstalling the C++ redistributables did not help, we need to take a different look at the machine. Have you tried to install via a different user account? This could be a permissions based issue. It would be good try another account on the system.
Also, if you look in the folders of the installer, you can find the c++ installers that are trying to be installed. You can manually try to install these as well. Just double-click on the C++ installed. Installing these prior to the main install may help.
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
New Member
apartridge
Message 9 of 12 (3,405 Views)
05-05-2014 08:35 PM in reply to: dembkod
typical Autodesk crap installations -  Failed Installation aborted, Result=1619
New Member
mloftis3
Message 10 of 12 (1,369 Views)
09-22-2014 02:50 PM in reply to: apartridge
After removing the 'Microsoft Visual C++ 2012 Redis. (x64) and (x86)' I attempted to install again both Maya LT 2015 and Softimage 2015. The downloads installed a new copy of the aforementioned items and still failed to install with both the 1603 and 1619 failures for the C++ 2012 versions.
I also attempted to change the .ini file as mentioned in an older post for this same issue. However, when I attempted to initiate the .exe file, the install would not initiate.
This comes on the heals of already installing Mudbox 2015 earlier today. Which installed without any issues.
Any help that would actually fix this for me would be awesome, thanks.
