Installation & Licensing
Installation problem for 3d max 2013 educaton version in Win 8
1 REPLY 1
thomastong0211
272 Views, 1 Reply
I cannot install the education version of 3d max 2010,2013 and 2014 in win 8. when all the files have been extracted, a window pop out and saying that  " AppData\Local\Temp\_AlAF75.tmp\/SecondRun / lang en-us / FirstRun Threadld 3284" in 3d max 2013, " Autodesk\autodesk_3dsmax_2010_English_32_64bit\?secondRun/ SMS" in 3d max 2010.
I have tried to install it in win 7, it works, and the computer in school is using win 8 which is also works with 3d max 2013, but they had been installed as a design suit with a proper license.
So right now, I am hestitating to reinstall the window from 8 to 7 to solve the problem in quickest way.
Any comment?
Cheers,
Thomas
1 REPLY 1
TravisNave
in reply to: thomastong0211
The 2010 version is definitely not supported in Windows 8.  Other than that, make sure your newer supported versions are installing 64-bit on 64-bit and vice versa for 32-bit.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
