I have a popup that doesn't allow me to install the student trial of Inventor 2015. My system is windows 7 64 bit.
I have attached a photo of the pop up. I have tried the suggestions.
Thank you.
Solved by jeffrey.sin. Go to Solution.
I had the same problem and tried switching to firefox which seems to have fixed it.
Hi Jose,
Check out this Autodesk Solution and try out the suggestion there. Alternatively, you can also download the installer from our Virtual Agent. Let us know how it goes.
Best Regards,
Hi @alrightalright,
Apologies that the problem continues. Please take these steps before your next download attempt:
Be sure to let me know how it goes and if you run across any other issues or please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer. Thank you!
Hi @alrightalright,
There should also be an option to activate, please see these steps on how to activate your Autodesk product and let me know which part was skipped. It's also possible that your product automatically activated during installation. You'll be able to tell by closing the product and then opening it again and if you are prompted with the trial you'll need to activate using the provided instructions. But if it goes straight into the product launch screen you're all good to go. Please let me know how it goes.
Thank you,
"And it still won't", could you please elaborate on exactly what you're seeing or provide screenshots?
And here is the solution on how to manually activate using an activation code. Please let me know if this helps, thanks!
Sorry for the late response, was away for vacation. Here are 2 screenshots. It doesn't activate with the serial I got emailed.
Thank you.
Thanks for the screenshots!
Please try disconnecting from the internet and begin the activation process again. This should generate a request code for you to manually activate your product. Please let me know how it goes. Thanks!
Hi @alrightalright,
We've updated some information on your user account and re-synched the information in our database. Can you try activating the Inventor Professional 2015 once again? Let us know how it goes.
