Installation & Licensing
Installation Problem Autodesk Inventor 2014
3 REPLIES 3
2940 Views, 3 Replies
Hey,
i tried to install the Autodesk Inventor 2014 several times. Always the same problem.
This is an excerpt of the Logfile. The complete logfile is attached.
2013/12/18:16:20:43    Mario    EBBE    Install    Autodesk Material Library 2014 - Low Image Library    Failed    Download Failed, Installation aborted, Result=1603
2013/12/18:16:20:44    Mario    EBBE    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
I don´t know how i can fix the problem. I checked several communities but i can´t find a solution.
I would be happy i someone can help me.
Best regards,
Ebbe
3 REPLIES 3
jessica.t
Hi Mario and welcome to the Autodesk Community!
We have some great existing solutions that should be very helpful:
Solution One
Solution Two
Solution Three
Solution Four
I hope this helps resolves your issue. If you have any other questions or concerns please reply to this post. Or if you need additional assistance please do not hesitate to ask.
Thank you!
Jessica Thrasher
TravisNave
As your log indicates, the material library is failing to download.  Others are having this problem currently.  Makes me wonder if the problem is on the Autodesk server end.
Download	Aborted	CMILL	http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{B9510038-243B-480F-B5FC-E0F475093CA5}/CMILL.ta...
What your might try is downloading from the virtual assistant instead.  Sometimes it just works better than other distributions.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Hey Travis and Jessica,
thank you for your posts.  Your ideas solves my problem. I`ve downloaded the Installation File.
After installing the Service Pack 1 on my Win8.1 Notebook, the Inventor starts without problems.
Best regards,
Mario
Administrator Productivity
