Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Installation problem, autocad 2014 not available in installation config
8 REPLIES 8
Message 1 of 9
988 Views, 8 Replies
How can I resolve this problem by the installation of autocad 2014 student?? I'm using Windows 8 64bits.
Thanks !
Paul
8 REPLIES 8
Message 2 of 9
DarrenP
did you hover your mouse over the  icon?
it will tell you what the problem is
DarrenP
Message 3 of 9
Darin.Green
I think you have a corrupted download or thumb drive. Try download a new copy of AutoCAD 2014 using the following link:
AutoCAD 64bit:
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
AutoCAD 32bit:
If this information was helpful, please consider using the Accept Solution
Message 4 of 9
DarrenP
in reply to: Darin.Green
what was the problem?
DarrenP
Message 5 of 9
Darin.Green
Paul,
It would be best to notify everyone of the issue as well as what solved it. Please post.
Darin
Message 6 of 9
autocad 2013 was already installed, I had to uninstall it and reinstal 2014
Message 7 of 9
I uninstalled autocad 2013 and launched the installation of autocad 2014 but my internet connection broke during the installation so I tried a new installation but now I have the problem again .. I followed the procedure of this link http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617 but it doesn't resolve my problem
Paul
Message 8 of 9
Darin.Green
Paul,
Do you have any Autodesk products still installed? If so, uninstall everything and delete the following directories:
  • C:\Program Files\Autodesk
  • C:\Program Files\Common Files\Autodesk Shared
  • C:\Program Files (x86)\Autodesk
  • C:\Program Files (x86)\Common Files\Autodesk Shared
From the registry editor, delete the following:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk
Once you've done the items above, reboot the machine and download the media using the links in my earlier post and run the installation again.
For best practic, its recommended to install in the order of the product version (2013 --> 2014)
Message 9 of 9
dembkod
paul.vdh93  ,
Hello. IN cases like this I usually recommend tke Microsoft Uninstall tool. It will clean out most corrupted installations.
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
