Installation & Licensing
neilyj666
351 Views, 4 Replies
Installation on new PC
My PC is being upgraded and I need to reinstall (standalone) Civil 3D - do I just install as normal and email for an activation Code?
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
4 REPLIES 4
TravisNave
in reply to: neilyj666
Yep, you should be good to go.
If it doesn't activate automagically, then you can contact Activations for a manual code:
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and the request code.
Autodesk Forums:
neilyj666
in reply to: TravisNave
Thanks for this but it didn't work as I have reached the authorization limit...!!!!
As there is no method of migrating settings, I need to run one version as unregistered until I'm happy that is set up correctly but then how do I activate it.
Do I need to uninstall from the original PC which presumably would release the licence??
TravisNave
No, it won't.  But if you call Autodesk Activations at that number, they can give you an activation code that you can manually paste in.
Autodesk Forums:
neilyj666
Got an activation code via email so up and running againSmiley Happy
Administrator Productivity
