i've got a small problem with the installation of the german country kit in civil 2014.
Usually you install the country kit over the control panel.
My AutoCAD was installed with a special software, so I can't activate the AutoCAD installation in the control panel even with admin privileges.
Is there any was to extract and paste the files manually?
Sorry, no, it's not just a template file, there are many files and settings that have to be installed in many folders, creating a seperate profile, using toolpalettes and much more.
What software does that type of installation? Is it just a permission issue that you are not seeing the content in the control panel? If so ask your admin to login to your system and let him open the control panel.
Anyway, the option to run a repair install or add/remove feature (for admins) is really important. So I would avoid to use any software that creates installations of software-packages which are at the end not listed in control panel. Or you can give me some reasons I don't think about?
The best will be to contact your admin and ask him to get access to the add/remove features for Civil 3D
Sorry to not have a positive answer, good luck, - alfred -
