Installation & Licensing
Installation of Inventor 2011 while working in 2009 Inventor?
1 REPLY 1
donwilliams
187 Views, 1 Reply
I am currently installing Inventor 2011. Can I continue working on the same computer in Inventor 2009
while downloading 2011?
How long will the download take?
donwilliams@Macelroy.com
1 REPLY 1
TravisNave
in reply to: donwilliams
This shouldn't be a problem. In fact, you can have both installed if you wish. But keep in mind that Inventor is not backwards compatible, so any files you migrate or create in 2011 cannot be used in 2009. As for the download time, it varies but should take just a few minutes less than forever. Good luck!
Autodesk Forums:
Administrator Productivity
