Installation & Licensing
Active Member
0 Kudos
Post 12 of 16
Re: Installation of AutoCAD Electrical 2013
05-22-2012 09:43 AM in reply to: servicesmgr
Here is the temp log file. Full file is too large to attach.
*Expert Elite*
904 Kudos
Post 13 of 16
05-22-2012 09:46 AM in reply to: servicesmgr
Locate file, (typically in file://%TEMP% ) Right-Click and choose Send To > Compressed (zipped) Folder.
Active Member
0 Kudos
Post 14 of 16
05-22-2012 09:47 AM in reply to: servicesmgr
Here is the end of install log file. The full file is too large to attach.
1 Kudo
Post 15 of 16
05-23-2012 07:59 PM in reply to: TravisNave
Hi servicesmgr;
   Sorry to hear that you are having more issues. The Log file you sent in doesn't have any failure codes that will help. Can you try to zip up the log file so I can have a look? If they don't get smaller than say 5 - 8 mb I'll log a new case for you and get the files
dwayne
Dwayne Poot
Support Specialist
Product Support
Autodesk, Inc.
31 Kudos
Post 16 of 16
07-04-2012 07:45 AM in reply to: TravisNave
I have just had exactly the same issue on one machine, all other machines have installed AutoCAD Electrical (Part of Product Design Suite) without an issue.
This is the first time I have tried the install on this machine, and it did appear to hang on the AutoCAD Electrical Language Pack, however if you check the default_cat.mdb and footprint_lookup.mdb sizes in C:\Users\USERNAME\Documents\Acade 2013\AeData\Catalogs it does go up, just very slowly. Then every half hour or so you get the message about resource exceeded, OK it and it carrys on, very slowly (this install took nearly 24 hours).
Eventually after the default_cat.mdb got to the correct size (around 390-395mb), with all Manufacturers on IEC standard, the next piece of software in the Product Design Suite started its installation.
I searched the net for this error and anything to do with cdb performance, but came up empty. Why is it doing this on particular setups? Any help would be great for the next time!
Laptop running Windows 7 64 Bit, Intel i7 Q840, 16Gb RAM and Nvidia Quadro FX 2800M. Has Office 2010 installed, but not Access.
Autodesk Technical Consultant @ Majenta Solutions, UK
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
