Installation & Licensing
Installation of AutoCAD Electrical 2013 - Failed to install numerous times
14 REPLIES 14
Message 2 of 15
4274 Views, 14 Replies
I am trying to install a standalone ACE 2013 on a win 7 pro, sp1, 64 bit, core i7-2760qm 2.4 ghz, 4gb ram.
During the first install, it halted at the language pack. Had to use task manager to end the process.
Tried a "reinstall" via control panel/programs and features.
ACE 2013 would not start.
Did a complete unistall of all AC programs
2nd install, had much the same issues but also came up with error window "cdb system resourse exceded"
Tried a "repair" via control panel/programs and features.
Said program install was successfull.
When trying to start ACE get the following error window:
Problem signature:
Problem Event Name: APPCRASH
Application Name: acad.exe
Application Version: 25.0.55.0
Application Timestamp: 4f309abd
Fault Module Name: accore.dll
Fault Module Version: 19.0.55.0
Fault Module Timestamp: 4f309bcf
Exception Code: c0000005
Exception Offset: 00000000000bddf0
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: d357
Additional Information 2: d3571c485c0fb56bb09815278810e62e
Additional Information 3: 7f49
Additional Information 4: 7f4939330ead794509f64ae160c1f509
Did complete uninstall.
3rd Install.
had much the same issues but also came up with error window "cdb system resourse exceded" again.
This time I ok'ed through the errors, which took about 12hrs.
Program said it was a successfull install.
got same error as above when trying to start the program.
Did repair and still no start.
Uninstall all AC components again.
Tried 4th time.
All the same issues.
Program will still not start.
I think I have attached the latest log.
14 REPLIES 14
Message 1 of 15
I am also having the same issue with ACE 2013 install.
Much the same issues as was described in the beginning of the thread.
I am on 5th time trying to install.
See attached log.
Tks,
Lyndon.
Message 3 of 15
Dwayne.Poot
Hi lmcdonald;
   The log files do not show error messages, actually shows that Electrical was successfully installed? If this installation is taking too long have you tried to simply install the core application, say Electrical and then install the remaining applications? This should break up the installation and speed things up
dwayne
Dwayne Poot
Support Specialist
Product Support
Autodesk, Inc.
Message 4 of 15
in reply to: Dwayne.Poot
Thanks Dwayne. See screen shot of when I try to open ACE Yes, I tried what you suggested. This is what I end up after an install, whether it's the complete package or just ACE core. Lyndon McDonald xxx.xxx.xxxx (cell) Description: cid:image004.jpg@01CCF24C.2AEEC870 Carmichael Engineering Ltd. 10 Morris Drive, Dartmouth, Nova Scotia, Canada, B3B 1K8 T
Edited by
Discussion_Admin
Message 5 of 15
Dwayne.Poot
Hi lmcdonald;
   Can you re-send the screen shot, it didn't come through
dwayne
Dwayne Poot
Support Specialist
Product Support
Autodesk, Inc.
Message 6 of 15
It took 3 shots to get the complete message. Lyndon McDonald xxx.xxx.xxxx (cell) Description: cid:image004.jpg@01CCF24C.2AEEC870 Carmichael Engineering Ltd. 10 Morris Drive, Dartmouth, Nova Scotia, Canada, B3B 1K8
Edited by
Discussion_Admin
Message 7 of 15
Dwayne.Poot
Sorry but they are not coming through.
Dwayne
Dwayne Poot
Support Specialist
Product Support
Autodesk, Inc.
Message 8 of 15
The detials in the error are as follows:
Problem signature:
Locale ID: 1033
Message 9 of 15
After my 5th time uninstalling everything (including MS Visual stuff), cleaning the registry, etc.
The sixth install with the core ACE 2013 only with no bells or whistles or extras chosen, it worked.
This issue has shown up in many other threads, with no solution provided yet.
Can you provide an answer as to why this happens, and what the fix is. I have lost about 12hrs of my life installing this....which seems a bit excessive.
Thanks for your assistance, but I really would like to know the cause and the fix.
Lyndon.
Message 10 of 15
Issues was resoled without help from tech support.
Message 11 of 15
MTimmis_ADSK
Would it be possible to let us know what you did to resolve? As it would be useful for others, including myself 🙂
Manufacturing Consultant @ Excitech UK
Message 12 of 15
I have tryed to install AutoCAD Electrical 2013 several times, but I can't figure out why it doesn't work. I use windows 8, and got this installation log file.
Thanks for anyone who can help me.
Message 13 of 15
Could you please explain how you fixed the problem. I'm having the identical problem (same fault module, application etc.) with Autocad 2015. It was working one day and then a few weeks later it stopped.
thanks.
Message 14 of 15
i have some issue in autocad 2013 while closing the software
i am showing the screen shot please help me.
Message 15 of 15
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
For the future please do not hi-jack other posting that have nothing to do with your problem.  This original posting was about an installation issue of AutoCAD Electrical 2013.
Now to your problem.  Most times this issue is related to have a corrupt C++ installation on your machine.  However do this first..
1.  Close AutoCAD if open and clean out your personal temp (%temp%) folder.  Delete as many files and folders as possible.  You will not be able to delete every file/folder that is there, but clean out as must as possible.  Launch AutoCAD and see if that resolves the issue.  If not go to step #2.
2.  Follow the steps in this article.
Mark Lancaster
Administrator Productivity
