Installation & Licensing
Installation of ACAD 2007 in Windows 7
1 REPLY 1
203 Views, 1 Reply
I recently had problems with Windows 7 and replaced it with Windows XP. All I got was a new set of problems, so I had a consultant install the seller's copy of Windows 7. Sure enough, another new set of problems emerged. I spent a couple of hours getting the apparent problems worked out, but I didn't try to run ACAD. I tried to run ACAD, and nothing happened. No errors. The little circling arrow came on and then disappeared. I've tried reinstalling ACAD twice, without any change. I also find that Autodesk doesn't even list 2007 as a supported product.
Has anybody else had any problem like this?
1 REPLY 1
TravisNave
Generally speaking, the licensing system does not play well on Windows 7, so therefore the applications usually fail to launch.  You need to be running 2010 products or later for Win 7, as the architecture and default folder locations changed a lot between XP and 7.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
