My 3D CIVIL STARTED TO MIS-BEHAVE SO I DE-IINSTALLED AND HAVE BEEN TRYING TO RE-INSTALL. WHEN THE DIALOUGE BOX COMES UP THE OPTIONS UNDER THE INSTALLATION BOX ARE ALL "GREYED" OUT EXCEPT THE "DATA MANAGEMENT-SEVER" OPTION.
ON THE ASSUMPTION I HAVE DONE SOMETHING WRONG, CAN SOMEONE SUGGEST A SOLUTION, I HAVE AN EXPENSIVE BIT OF SOFTWARE THAT WONT WORK AND THE AUTODESK DEALER (S) WILL NOT HELP.
THANKS IN ADVANCE FOR TYHE ANSWER.
It appears that the installer still thinks the software is installed. You might have to use the Windows Installer Clean-up Utility to remove it successfully before you can reinstall.
You might also want to read this Knowledge Base document: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9902506&linkID=9240697
Allen
Allen Jessup
CAD Manager - Designer
