Installation & Licensing
installation of 3dcivil 2008
3 REPLIES 3
bill
343 Views, 3 Replies
My 3D CIVIL STARTED TO MIS-BEHAVE SO I DE-IINSTALLED AND HAVE BEEN TRYING TO RE-INSTALL. WHEN THE DIALOUGE BOX COMES UP THE OPTIONS UNDER THE INSTALLATION BOX ARE ALL "GREYED" OUT EXCEPT THE "DATA MANAGEMENT-SEVER" OPTION.
ON THE ASSUMPTION I HAVE DONE SOMETHING WRONG, CAN SOMEONE SUGGEST A SOLUTION, I HAVE AN EXPENSIVE BIT OF SOFTWARE THAT WONT WORK AND THE AUTODESK DEALER (S) WILL NOT HELP.
THANKS IN ADVANCE FOR TYHE ANSWER.
3 REPLIES 3
TravisNave
in reply to: bill
It appears that the installer still thinks the software is installed.  You might have to use the Windows Installer Clean-up Utility to remove it successfully before you can reinstall.
Autodesk Forums:
bill
in reply to: bill
Thanks for that, i will try it as soon as im back in the office.
AllenJessup
in reply to: bill
You might also want to read this Knowledge Base document: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9902506&linkID=9240697
Allen
Allen Jessup
CAD Manager - Designer
Administrator Productivity
