Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Installation of 2011 inventor simulation suit not working
2 REPLIES 2
534 Views, 2 Replies
I had 2011 inventor simulation suite installed on my computer
The operating system (windows xp) stopped working properly after I shut it down.
I was able to repair it by installing some system 32 files.
When windows started all my programs worked ok except the 2011 inventor simulation suite.
I uninstalled the program and installed again.
The installation proceeded ok  but the program is not working!!!
What can I do to fix this problem?
Thank you for your assistance
2 REPLIES 2
hashim.mundol
This is typical issue with .Net Framework . Clean installation of .Net Framework should fix this issue on Windows XP
this link shows how to do it manually.
http://usa.autodesk.com/getdoc/id=TS14863971
If this doesn't help, please try the same procedure in Windows Diagnostics mode with Installer service running.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
in reply to: hashim.mundol
Problem solved!
Thank you for the solution!
Administrator Productivity
