I had 2011 inventor simulation suite installed on my computer
The operating system (windows xp) stopped working properly after I shut it down.
I was able to repair it by installing some system 32 files.
When windows started all my programs worked ok except the 2011 inventor simulation suite.
I uninstalled the program and installed again.
The installation proceeded ok but the program is not working!!!
What can I do to fix this problem?
Thank you for your assistance
Solved by hashim.mundol. Go to Solution.
This is typical issue with .Net Framework . Clean installation of .Net Framework should fix this issue on Windows XP
this link shows how to do it manually.
http://usa.autodesk.com/getdoc/id=TS14863971
If this doesn't help, please try the same procedure in Windows Diagnostics mode with Installer service running.
