Installation & Licensing
Installation keeps failing
7 REPLIES 7
Message 1 of 8
3476 Views, 7 Replies
I've been trying to install Autocad 2011 on my desktop which runs on windows 7
then whenever i log in, and click onto the design software, it keeps prompting me to log in which i have already done
i have tried multiple times and it's happening again and again so i wonder what's wrong?
thanks for the help!
Tags (1)
7 REPLIES 7
Message 2 of 8
hashim.mundol
not sure what logon screen it is , could you post the screen shot please.
Did you install the software as administrator ?
please try to turn off UAC
http://windows.microsoft.com/en-US/windows-vista/Turn-User-Account-Control-on-or-off
or try a clean install in diagnostics mode
http://usa.autodesk.com/getdoc/id=TS75218
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 3 of 8
TravisNave
Is your network restricted by your IT Manager via proxy server or similar?  You may not have full access to the Internet or a network resource that AutoCAD is trying to reach.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 4 of 8
SenorSabor
Hello, i am trying to install Inventor pro 2012. It downloads successfully, i type in my product information, it accepts the info then moves to the page where i select my downloads, it continus to the install window for about three seconds then jump out saying the all of the products failed to intall. Help?
Message 5 of 8
SenorSabor
in reply to: SenorSabor
Umm, does anyone even know whats causing this? Because i would kinda like to get this software working on my computer before my spring break ends. Its been a couple of days now...
Message 6 of 8
jessica.t
Thank you for the screenshots! Could you try this solution and let me know if it resolves the issue? Thanks!
Jessica Thrasher
Message 7 of 8
SenorSabor
in reply to: jessica.t
Hooray! It installed perfectly and works great. Thanks a ton
Message 8 of 8
jessica.t
You're welcome! Smiley Happy
Jessica Thrasher
Administrator Productivity
