Hi
I'm trying to install Autodesk Inventor 2014 and I'm getting the error message in the attached file. Any idea on how can I rectify this issue?
Mohammed
Solved by frederic.bernabo. Go to Solution.
Thank you for taking part in our community!
When installing your product turn off UAC and disable your antivirus and of course admin right.
Log into the client machine as a local administrator or administrative priviledge
-Antivirus should be turned off
-Windows UAC should be turned off http://support.microsoft.com/kb/975787
I hope this helps
Hi Frederic,
I have followed the steps and it worked perfectly! Thank you very much for your promptness and great support.
Mohammed
