Installation & Licensing
Member
0 Kudos
Post 1 of 6
Installation issues on Mac for Maya
1331 Views, 5 Replies
03-19-2011 04:54 PM
Hi there I have Mac OSX 10.6.4 and plenty of free space so I am confused to be getting on the install screen for Maya a message saying Install failed on exit Could anyone help me out here?
BTW I am using the student licensing version.
Cheers
You can ignore this error on Mac/Linux.
please read about direct connect here
http://usa.autodesk.com/getdoc/id=DL15012100
Member
0 Kudos
Post 2 of 6
Re: Installation issues on Mac for Maya
03-19-2011 05:45 PM in reply to: nealescullion
Ok I have managed to install by removing the Directconnect options as that was what was failing to install.
How will this affect my program? and how can I get around this issue?
Again thanks.
Product Support
52 Kudos
Post 3 of 6
03-21-2011 01:31 AM in reply to: nealescullion
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Member
0 Kudos
Post 4 of 6
03-21-2011 04:25 AM in reply to: nealescullion
Thanks very much that clears things up.
Member
0 Kudos
Post 5 of 6
04-01-2011 07:30 PM in reply to: nealescullion
How did you uninstall the DirectConnect option?
Member
0 Kudos
Post 6 of 6
04-01-2011 07:43 PM in reply to: nicoley
I tried deleting the Maya folder and re-installing the software without the two Direct Connect items. I put my license number and product code in the installation dialog. This time I didn't get the installation failed message, but it still didn't work. When I started up Maya, I got a long error message that said:
License was not obtained
Tried Maya 2011 (657C1 2011.0.0.F), error 20
License method:
environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:
environment variable MAYA_LICENSE='unlimited'
License file override:
environment variable MAYA_ALT_EN is not set
What should I try next?
