Hi there I have Mac OSX 10.6.4 and plenty of free space so I am confused to be getting on the install screen for Maya a message saying Install failed on exit Could anyone help me out here?
BTW I am using the student licensing version.
Cheers
Solved by hashim.mundol. Go to Solution.
Ok I have managed to install by removing the Directconnect options as that was what was failing to install.
How will this affect my program? and how can I get around this issue?
Again thanks.
You can ignore this error on Mac/Linux.
please read about direct connect here
http://usa.autodesk.com/getdoc/id=DL15012100
I tried deleting the Maya folder and re-installing the software without the two Direct Connect items. I put my license number and product code in the installation dialog. This time I didn't get the installation failed message, but it still didn't work. When I started up Maya, I got a long error message that said:
License was not obtained
Tried Maya 2011 (657C1 2011.0.0.F), error 20
License method:
environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:
environment variable MAYA_LICENSE='unlimited'
License file override:
environment variable MAYA_ALT_EN is not set
What should I try next?
