I have no idea what to do, I've tried to install DirectX but it said it was up to date. I have also tried to install a C++ file that was recommended but I'm still having the problems. Attached is what comes up after the program is "finished" installing. I also copy and pasted the log below. I hope that helps and I can get this resolved to get back to working.
2013/8/26:00:18:33 Mario MARIO-PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2014" SETUP_PACKAGECODE={5783F2D7-D004-0000-0002-0060B0CE6BBA} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Architecture 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/26:00:19:15 Mario MARIO-PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/8/26:00:19:16 Mario MARIO-PC Download Play CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:00:20:39 Mario MARIO-PC Download Complete CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:00:20:39 Mario MARIO-PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2014" SETUP_PACKAGECODE={5783F2D7-D004-0000-0002-0060B0CE6BBA} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Architecture 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/26:00:22:20 Mario MARIO-PC Install Autodesk Material Library 2014 Succeeded
2013/8/26:00:22:22 Mario MARIO-PC Download Play CMLIB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:00:24:26 Mario MARIO-PC Download Complete CMLIB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:00:24:26 Mario MARIO-PC Installing Autodesk Material Library 2014 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2014" SETUP_PACKAGECODE={5783F2D7-D004-0000-0002-0060B0CE6BBA} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Architecture 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/26:00:26:24 Mario MARIO-PC Install Autodesk Material Library 2014 - Low Resolution Succeeded
2013/8/26:00:26:26 Mario MARIO-PC Download Play ACA http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:00:42:08 Mario MARIO-PC Download Aborted ACA http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:00:42:08 Mario MARIO-PC Install Autodesk® AutoCAD® Architecture 2014 Failed Download Failed, Installation aborted, Result=1603
2013/8/26:00:42:27 Mario MARIO-PC Rollback Autodesk Material Library 2014 - Low Resolution Succeeded
2013/8/26:00:44:49 Mario MARIO-PC Rollback Autodesk Material Library 2014 Succeeded
2013/8/26:00:44:52 Mario MARIO-PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/8/26:00:44:52 Mario MARIO-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/8/26:00:44:55 Mario MARIO-PC PageOpen InstallCompleteDialog
2013/8/26:00:45:32 Mario MARIO-PC === Setup ended ===
2013/8/26:00:55:41 Mario MARIO-PC === Setup started on MARIO-PC by Mario ===
2013/8/26:00:55:41 Mario MARIO-PC Path_Length: 155
2013/8/26:00:55:41 Mario MARIO-PC Current Directory C:\Autodesk\AutoCAD_Architecture_2014_English_Win_32_64bit_wi_en-us
2013/8/26:00:55:41 Mario MARIO-PC Launch
2013/8/26:00:55:41 Mario MARIO-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/AutoCAD_Architecture_2014_English_Wi... /SN 900-25231292 /PK 185F1 /student /skipEULA /akamai /auth /sid
2013/8/26:00:55:41 Mario MARIO-PC Current Directory C:\Users\Mario\AppData\Local\Temp\_AI9021.tmp
2013/8/26:00:55:50 Mario MARIO-PC === Setup ended ===
2013/8/26:00:55:44 Mario MARIO-PC === Setup started on MARIO-PC by Mario ===
2013/8/26:00:55:44 Mario MARIO-PC Path_Length: 155
2013/8/26:00:55:44 Mario MARIO-PC Current Directory C:\Users\Mario\AppData\Local\Temp\_AI9021.tmp
2013/8/26:00:55:44 Mario MARIO-PC Launch
2013/8/26:00:55:48 Mario MARIO-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:00:55:49 Mario MARIO-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mario\AppData\Local\Temp\_AI9021.tmp\Setup\AcSetup.dll
2013/8/26:00:55:49 Mario MARIO-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/26:00:55:50 Mario MARIO-PC PageOpen LaunchDialog
2013/8/26:00:56:13 Mario MARIO-PC PageOpen LicenseDialog
2013/8/26:00:56:14 Mario MARIO-PC PageOpen ProductInfoDialog
2013/8/26:00:56:14 Mario MARIO-PC PageOpen ProductSelectionDialog2
2013/8/26:00:57:32 Mario MARIO-PC PageOpen FullProgressDialog
2013/8/26:00:57:33 Mario MARIO-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:00:57:33 Mario MARIO-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD Architecture 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/8/26:00:58:59 Mario MARIO-PC Install DirectX Runtime Succeeded
2013/8/26:00:58:59 Mario MARIO-PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2014" SETUP_PACKAGECODE={5783F2D7-D004-0000-0002-0060B0CE6BBA} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Architecture 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/26:00:59:38 Mario MARIO-PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/8/26:00:59:39 Mario MARIO-PC Download Skipped CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:00:59:39 Mario MARIO-PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2014" SETUP_PACKAGECODE={5783F2D7-D004-0000-0002-0060B0CE6BBA} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Architecture 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/26:01:00:52 Mario MARIO-PC Install Autodesk Material Library 2014 Succeeded
2013/8/26:01:00:53 Mario MARIO-PC Download Skipped CMLIB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:01:00:53 Mario MARIO-PC Installing Autodesk Material Library 2014 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2014" SETUP_PACKAGECODE={5783F2D7-D004-0000-0002-0060B0CE6BBA} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Architecture 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/26:01:02:28 Mario MARIO-PC Install Autodesk Material Library 2014 - Low Resolution Succeeded
2013/8/26:01:02:28 Mario MARIO-PC Download Play ACA http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:01:17:53 Mario MARIO-PC Download Aborted ACA http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:01:17:53 Mario MARIO-PC Install Autodesk® AutoCAD® Architecture 2014 Failed Download Failed, Installation aborted, Result=1603
2013/8/26:01:18:06 Mario MARIO-PC Rollback Autodesk Material Library 2014 - Low Resolution Succeeded
2013/8/26:01:19:46 Mario MARIO-PC Rollback Autodesk Material Library 2014 Succeeded
2013/8/26:01:19:49 Mario MARIO-PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/8/26:01:19:49 Mario MARIO-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/8/26:01:19:50 Mario MARIO-PC PageOpen InstallCompleteDialog
2013/8/26:01:26:51 Mario MARIO-PC === Setup ended ===
2013/8/26:10:37:05 Mario MARIO-PC === Setup started on MARIO-PC by Mario ===
2013/8/26:10:37:05 Mario MARIO-PC Path_Length: 155
2013/8/26:10:37:05 Mario MARIO-PC Current Directory C:\Autodesk\AutoCAD_Architecture_2014_English_Win_32_64bit_wi_en-us
2013/8/26:10:37:05 Mario MARIO-PC Launch
2013/8/26:10:37:05 Mario MARIO-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/AutoCAD_Architecture_2014_English_Wi... /SN 900-25231292 /PK 185F1 /student /skipEULA /akamai /auth /sid
2013/8/26:10:37:05 Mario MARIO-PC Current Directory C:\Users\Mario\AppData\Local\Temp\_AIB6D0.tmp
2013/8/26:10:37:18 Mario MARIO-PC === Setup ended ===
2013/8/26:10:37:09 Mario MARIO-PC === Setup started on MARIO-PC by Mario ===
2013/8/26:10:37:09 Mario MARIO-PC Path_Length: 155
2013/8/26:10:37:09 Mario MARIO-PC Current Directory C:\Users\Mario\AppData\Local\Temp\_AIB6D0.tmp
2013/8/26:10:37:09 Mario MARIO-PC Launch
2013/8/26:10:37:13 Mario MARIO-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:10:37:16 Mario MARIO-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mario\AppData\Local\Temp\_AIB6D0.tmp\Setup\AcSetup.dll
2013/8/26:10:37:16 Mario MARIO-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/26:10:37:18 Mario MARIO-PC PageOpen LaunchDialog
2013/8/26:10:37:26 Mario MARIO-PC PageOpen LicenseDialog
2013/8/26:10:37:26 Mario MARIO-PC PageOpen ProductSelectionDialog2
2013/8/26:10:37:44 Mario MARIO-PC PageOpen LicenseDialog
2013/8/26:10:37:44 Mario MARIO-PC PageOpen LaunchDialog
2013/8/26:10:38:01 Mario MARIO-PC PageOpen LicenseDialog
2013/8/26:10:38:01 Mario MARIO-PC PageOpen ProductInfoDialog
2013/8/26:10:38:01 Mario MARIO-PC PageOpen ProductSelectionDialog2
2013/8/26:10:40:35 Mario MARIO-PC PageOpen FullProgressDialog
2013/8/26:10:40:36 Mario MARIO-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:10:40:36 Mario MARIO-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD Architecture 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/8/26:10:42:35 Mario MARIO-PC Install DirectX Runtime Succeeded
2013/8/26:10:42:35 Mario MARIO-PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2014" SETUP_PACKAGECODE={5783F2D7-D004-0000-0002-0060B0CE6BBA} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Architecture 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/26:10:43:22 Mario MARIO-PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/8/26:10:43:22 Mario MARIO-PC Download Skipped CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:10:43:22 Mario MARIO-PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2014" SETUP_PACKAGECODE={5783F2D7-D004-0000-0002-0060B0CE6BBA} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Architecture 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/26:10:44:46 Mario MARIO-PC Install Autodesk Material Library 2014 Succeeded
2013/8/26:10:44:47 Mario MARIO-PC Download Skipped CMLIB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:10:44:47 Mario MARIO-PC Installing Autodesk Material Library 2014 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2014" SETUP_PACKAGECODE={5783F2D7-D004-0000-0002-0060B0CE6BBA} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Architecture 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/26:10:47:16 Mario MARIO-PC Install Autodesk Material Library 2014 - Low Resolution Succeeded
2013/8/26:10:47:18 Mario MARIO-PC Download Play ACA http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:10:57:27 Mario MARIO-PC Download Aborted ACA http://studentsdownload.autodesk.com/SWDLDNET3/2014/ARCHDESK/WI/{1CBBC3A4-2A4D-47DC-8157-16C2AB235DC...
2013/8/26:10:57:28 Mario MARIO-PC Install Autodesk® AutoCAD® Architecture 2014 Failed Download Failed, Installation aborted, Result=1603
2013/8/26:10:57:44 Mario MARIO-PC Rollback Autodesk Material Library 2014 - Low Resolution Succeeded
2013/8/26:11:01:26 Mario MARIO-PC Rollback Autodesk Material Library 2014 Succeeded
2013/8/26:11:01:37 Mario MARIO-PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/8/26:11:01:37 Mario MARIO-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Try a browser download of the software. Check out this post for details:
http://forums.autodesk.com/t5/Installation-Licensing/inventor-installation-failure/td-p/4379926
