I'm trying to install autodesk maya 2014, yet while I install it, it says that theres a decompression failure, then it says that the overall installation has failed. I click on the installation log file and it says:
2013/6/23:14:54:24 James JAMES-2010 === Setup started on JAMES-2010 by James ===
2013/6/23:14:54:24 James JAMES-2010 Path_Length: 151
2013/6/23:14:54:24 James JAMES-2010 Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2013/6/23:14:54:24 James JAMES-2010 Launch
2013/6/23:14:54:24 James JAMES-2010 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-21576417 /PK 657F1 /student /skipEULA /akamai /auth /sid
2013/6/23:14:54:24 James JAMES-2010 Current Directory C:\Users\JAMES~1.NEP\AppData\Local\Temp\_AIF884.tmp
2013/6/23:14:54:31 James JAMES-2010 === Setup ended ===
2013/6/23:14:54:25 James JAMES-2010 === Setup started on JAMES-2010 by James ===
2013/6/23:14:54:25 James JAMES-2010 Path_Length: 151
2013/6/23:14:54:25 James JAMES-2010 Current Directory C:\Users\JAMES~1.NEP\AppData\Local\Temp\_AIF884.tmp
2013/6/23:14:54:25 James JAMES-2010 Launch
2013/6/23:14:54:30 James JAMES-2010 Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/S...
2013/6/23:14:54:31 James JAMES-2010 PageOpen LaunchDialog
2013/6/23:14:54:37 James JAMES-2010 PageOpen LicenseDialog
2013/6/23:14:54:37 James JAMES-2010 PageOpen ProductInfoDialog
2013/6/23:14:54:37 James JAMES-2010 PageOpen ProductSelectionDialog2
2013/6/23:14:54:54 James JAMES-2010 PageOpen FullProgressDialog
2013/6/23:14:54:55 James JAMES-2010 Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/D...
2013/6/23:14:54:58 James JAMES-2010 Download Error DIRECTX Decompressing failed http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/D...
2013/6/23:14:54:59 James JAMES-2010 Download Aborted DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/D...
2013/6/23:14:54:59 James JAMES-2010 Install DirectX® Runtime Failed Download Failed, Installation aborted, Result=1603
2013/6/23:14:54:59 James JAMES-2010 Download Play Maya http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/M...
2013/6/23:14:55:03 James JAMES-2010 Download Error Maya Decompressing failed http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/M...
2013/6/23:14:55:05 James JAMES-2010 Download Aborted Maya http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/M...
2013/6/23:14:55:05 James JAMES-2010 Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
It says right there at the end that this is a 1603, so what am I supposed to do?
Thank you
Welcome to the forums!
It appears that the download and extraction is failing. You might try downloading by a different method, on another computer, or downloading the trial version.
Problems downloading the Autodesk software and/or CRC errors may be avoided by using another web browser, or using the alternate browser download method.
For more detailed information on this process, please see the following blog post tip here:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
Hi there,
I too have problems installing Maya 2014. I have tried 2015, downloaded numerous times and tried reinstalling. Both Maya 2014 and 2015 fail to install just a few seconds after installation starts. Please help!
Log file for Maya 2014:
2014/5/17:21:48:14 Kylie KYLIE-PC === Setup started on KYLIE-PC by Kylie ===
2014/5/17:21:48:14 Kylie KYLIE-PC Path_Length: 151
2014/5/17:21:48:14 Kylie KYLIE-PC Current Directory C:\Users\Kylie\AppData\Local\Temp\_AI8BEF.tmp
2014/5/17:21:48:14 Kylie KYLIE-PC Launch
2014/5/17:21:48:18 Kylie KYLIE-PC PageOpen LaunchDialog
2014/5/17:21:48:21 Kylie KYLIE-PC PageOpen LicenseDialog
2014/5/17:21:48:06 Kylie KYLIE-PC === Setup started on KYLIE-PC by Kylie ===
2014/5/17:21:48:06 Kylie KYLIE-PC Path_Length: 151
2014/5/17:21:48:06 Kylie KYLIE-PC Current Directory C:\AUTODESK MAYA 2014\Autodesk_Maya_2014_dlm
2014/5/17:21:48:06 Kylie KYLIE-PC Launch
2014/5/17:21:48:06 Kylie KYLIE-PC CommandLine
2014/5/17:21:48:06 Kylie KYLIE-PC Current Directory C:\Users\Kylie\AppData\Local\Temp\_AI8BEF.tmp
2014/5/17:21:48:26 Kylie KYLIE-PC === Setup ended ===
2014/5/17:21:48:28 Kylie KYLIE-PC PageOpen ProductInfoDialog
2014/5/17:21:49:25 Kylie KYLIE-PC PageOpen ProductSelectionDialog2
2014/5/17:21:51:21 Kylie KYLIE-PC PageOpen FullProgressDialog
2014/5/17:21:51:21 Kylie KYLIE-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\AUTODESK MAYA 2014\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kylie\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/5/17:21:51:37 Kylie KYLIE-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2014/5/17:21:51:39 Kylie KYLIE-PC PageOpen InstallCompleteDialog
2014/5/17:21:51:51 Kylie KYLIE-PC === Setup ended ===
2014/5/18:11:22:36 Kylie KYLIE-PC === Setup started on KYLIE-PC by Kylie ===
2014/5/18:11:22:36 Kylie KYLIE-PC Path_Length: 151
2014/5/18:11:22:36 Kylie KYLIE-PC Current Directory C:\AUTODESK MAYA 2014\Autodesk_Maya_2014_dlm
2014/5/18:11:22:36 Kylie KYLIE-PC Launch
2014/5/18:11:22:36 Kylie KYLIE-PC CommandLine
2014/5/18:11:22:36 Kylie KYLIE-PC Current Directory C:\Users\Kylie\AppData\Local\Temp\_AIE256.tmp
2014/5/18:11:22:58 Kylie KYLIE-PC === Setup ended ===
2014/5/18:11:22:40 Kylie KYLIE-PC === Setup started on KYLIE-PC by Kylie ===
2014/5/18:11:22:40 Kylie KYLIE-PC Path_Length: 151
2014/5/18:11:22:40 Kylie KYLIE-PC Current Directory C:\Users\Kylie\AppData\Local\Temp\_AIE256.tmp
2014/5/18:11:22:40 Kylie KYLIE-PC Launch
2014/5/18:11:22:58 Kylie KYLIE-PC PageOpen LaunchDialog
2014/5/18:11:23:54 Kylie KYLIE-PC PageOpen LicenseDialog
2014/5/18:11:23:58 Kylie KYLIE-PC PageOpen ProductInfoDialog
2014/5/18:11:24:03 Kylie KYLIE-PC PageOpen ProductSelectionDialog2
2014/5/18:11:24:07 Kylie KYLIE-PC PageOpen FullProgressDialog
2014/5/18:11:24:07 Kylie KYLIE-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\AUTODESK MAYA 2014\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kylie\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/5/18:11:24:17 Kylie KYLIE-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
***ALSO AUTODESK DIRECT CONNECT:
