Installation & Licensing
Installation failure with Autodesk Maya 2014
4 REPLIES 4
3766 Views, 4 Replies
I'm trying to install autodesk maya 2014, yet while I install it, it says that theres a decompression failure, then it says that the overall installation has failed. I click on the installation log file and it says:
2013/6/23:14:54:24    James    JAMES-2010    === Setup started on JAMES-2010 by James ===
2013/6/23:14:54:24    James    JAMES-2010    Path_Length: 151
2013/6/23:14:54:24    James    JAMES-2010    Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2013/6/23:14:54:24    James    JAMES-2010    Launch
2013/6/23:14:54:24    James    JAMES-2010    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-21576417 /PK 657F1 /student /skipEULA /akamai /auth  /sid
2013/6/23:14:54:24    James    JAMES-2010    Current Directory C:\Users\JAMES~1.NEP\AppData\Local\Temp\_AIF884.tmp
2013/6/23:14:54:31    James    JAMES-2010    === Setup ended ===
2013/6/23:14:54:25    James    JAMES-2010    === Setup started on JAMES-2010 by James ===
2013/6/23:14:54:25    James    JAMES-2010    Path_Length: 151
2013/6/23:14:54:25    James    JAMES-2010    Current Directory C:\Users\JAMES~1.NEP\AppData\Local\Temp\_AIF884.tmp
2013/6/23:14:54:25    James    JAMES-2010    Launch
2013/6/23:14:54:30    James    JAMES-2010    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/S...
2013/6/23:14:54:31    James    JAMES-2010    PageOpen    LaunchDialog
2013/6/23:14:54:37    James    JAMES-2010    PageOpen    LicenseDialog
2013/6/23:14:54:37    James    JAMES-2010    PageOpen    ProductInfoDialog
2013/6/23:14:54:37    James    JAMES-2010    PageOpen    ProductSelectionDialog2
2013/6/23:14:54:54    James    JAMES-2010    PageOpen    FullProgressDialog
2013/6/23:14:54:55    James    JAMES-2010    Download    Play    DIRECTX    http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/D...
2013/6/23:14:54:58    James    JAMES-2010    Download Error    DIRECTX    Decompressing failed    http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/D...
2013/6/23:14:54:59    James    JAMES-2010    Download    Aborted    DIRECTX    http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/D...
2013/6/23:14:54:59    James    JAMES-2010    Install    DirectX® Runtime    Failed    Download Failed, Installation aborted, Result=1603
2013/6/23:14:54:59    James    JAMES-2010    Download    Play    Maya    http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/M...
2013/6/23:14:55:03    James    JAMES-2010    Download Error    Maya    Decompressing failed    http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/M...
2013/6/23:14:55:05    James    JAMES-2010    Download    Aborted    Maya    http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/M...
2013/6/23:14:55:05    James    JAMES-2010    Install    Autodesk® Maya® 2014    Failed    Download Failed, Installation aborted, Result=1603
It says right there at the end that this is a 1603, so what am I supposed to do?
Thank you
4 REPLIES 4
TravisNave
Welcome to the forums!
It appears that the download and extraction is failing.  You might try downloading by a different method, on another computer, or downloading the trial version.
Problems downloading the Autodesk software and/or CRC errors may be avoided by using another web browser, or using the alternate browser download method.
For more detailed information on this process, please see the following blog post tip here:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
Autodesk Forums:
Hi there,
I too have problems installing Maya 2014. I have tried 2015, downloaded numerous times and tried reinstalling. Both Maya 2014 and 2015 fail to install just a few seconds after installation starts.  Please help!
Log file for Maya 2014:
2014/5/17:21:48:14    Kylie    KYLIE-PC    === Setup started on KYLIE-PC by Kylie ===
2014/5/17:21:48:14    Kylie    KYLIE-PC    Path_Length: 151
2014/5/17:21:48:14    Kylie    KYLIE-PC    Current Directory C:\Users\Kylie\AppData\Local\Temp\_AI8BEF.tmp
2014/5/17:21:48:14    Kylie    KYLIE-PC    Launch
2014/5/17:21:48:18    Kylie    KYLIE-PC    PageOpen    LaunchDialog
2014/5/17:21:48:21    Kylie    KYLIE-PC    PageOpen    LicenseDialog
2014/5/17:21:48:06    Kylie    KYLIE-PC    === Setup started on KYLIE-PC by Kylie ===
2014/5/17:21:48:06    Kylie    KYLIE-PC    Path_Length: 151
2014/5/17:21:48:06    Kylie    KYLIE-PC    Current Directory C:\AUTODESK MAYA 2014\Autodesk_Maya_2014_dlm
2014/5/17:21:48:06    Kylie    KYLIE-PC    Launch
2014/5/17:21:48:06    Kylie    KYLIE-PC    CommandLine
2014/5/17:21:48:06    Kylie    KYLIE-PC    Current Directory C:\Users\Kylie\AppData\Local\Temp\_AI8BEF.tmp
2014/5/17:21:48:26    Kylie    KYLIE-PC    === Setup ended ===
2014/5/17:21:48:28    Kylie    KYLIE-PC    PageOpen    ProductInfoDialog
2014/5/17:21:49:25    Kylie    KYLIE-PC    PageOpen    ProductSelectionDialog2
2014/5/17:21:51:21    Kylie    KYLIE-PC    PageOpen    FullProgressDialog
2014/5/17:21:51:21    Kylie    KYLIE-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\AUTODESK MAYA 2014\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kylie\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/5/17:21:51:37    Kylie    KYLIE-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
2014/5/17:21:51:39    Kylie    KYLIE-PC    PageOpen    InstallCompleteDialog
2014/5/17:21:51:51    Kylie    KYLIE-PC    === Setup ended ===
2014/5/18:11:22:36    Kylie    KYLIE-PC    === Setup started on KYLIE-PC by Kylie ===
2014/5/18:11:22:36    Kylie    KYLIE-PC    Path_Length: 151
2014/5/18:11:22:36    Kylie    KYLIE-PC    Current Directory C:\AUTODESK MAYA 2014\Autodesk_Maya_2014_dlm
2014/5/18:11:22:36    Kylie    KYLIE-PC    Launch
2014/5/18:11:22:36    Kylie    KYLIE-PC    CommandLine
2014/5/18:11:22:36    Kylie    KYLIE-PC    Current Directory C:\Users\Kylie\AppData\Local\Temp\_AIE256.tmp
2014/5/18:11:22:58    Kylie    KYLIE-PC    === Setup ended ===
2014/5/18:11:22:40    Kylie    KYLIE-PC    === Setup started on KYLIE-PC by Kylie ===
2014/5/18:11:22:40    Kylie    KYLIE-PC    Path_Length: 151
2014/5/18:11:22:40    Kylie    KYLIE-PC    Current Directory C:\Users\Kylie\AppData\Local\Temp\_AIE256.tmp
2014/5/18:11:22:40    Kylie    KYLIE-PC    Launch
2014/5/18:11:22:58    Kylie    KYLIE-PC    PageOpen    LaunchDialog
2014/5/18:11:23:54    Kylie    KYLIE-PC    PageOpen    LicenseDialog
2014/5/18:11:23:58    Kylie    KYLIE-PC    PageOpen    ProductInfoDialog
2014/5/18:11:24:03    Kylie    KYLIE-PC    PageOpen    ProductSelectionDialog2
2014/5/18:11:24:07    Kylie    KYLIE-PC    PageOpen    FullProgressDialog
2014/5/18:11:24:07    Kylie    KYLIE-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\AUTODESK MAYA 2014\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kylie\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/5/18:11:24:17    Kylie    KYLIE-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
***ALSO AUTODESK DIRECT CONNECT:
Sheenu
I'm having the same exact problem.
Sheenu
in reply to: TravisNave
Tried that and it still didn't work.
Administrator Productivity
