Installation & Licensing
Installation Failure AutoCad LT 2013
6 REPLIES 6
cec
585 Views, 6 Replies
Here is my log.
2013/2/25:09:40:50 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:09:40:50 ce1 CE001 Launch
2013/2/25:09:41:54 ce1 CE001 === Setup ended ===
2013/2/25:09:41:06 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:09:41:06 ce1 CE001 Launch
2013/2/25:09:41:53 ce1 CE001 PageOpen LaunchDialog
2013/2/25:09:42:22 ce1 CE001 PageOpen LicenseDialog
2013/2/25:09:42:32 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:09:44:37 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:09:44:47 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:09:44:47 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:09:44:56 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:09:45:13 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:09:45:41 ce1 CE001 === Setup ended ===
2013/2/25:09:46:08 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:09:46:08 ce1 CE001 Launch
2013/2/25:09:46:10 ce1 CE001 === Setup ended ===
2013/2/25:09:46:09 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:09:46:09 ce1 CE001 Launch
2013/2/25:09:46:10 ce1 CE001 PageOpen LaunchDialog
2013/2/25:09:46:14 ce1 CE001 PageOpen LicenseDialog
2013/2/25:09:46:17 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:09:46:40 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:09:47:07 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:09:47:07 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:09:47:11 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:09:47:11 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:09:48:38 ce1 CE001 === Setup ended ===
2013/2/25:10:41:43 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:10:41:43 ce1 CE001 Launch
2013/2/25:10:42:30 ce1 CE001 === Setup ended ===
2013/2/25:10:41:53 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:10:41:53 ce1 CE001 Launch
2013/2/25:10:42:30 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:01:14 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:01:18 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:01:46 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:01:48 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:01:48 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:01:56 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:02:05 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:11:02:44 ce1 CE001 === Setup ended ===
2013/2/25:11:30:34 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:30:34 ce1 CE001 Launch
2013/2/25:11:30:36 ce1 CE001 === Setup ended ===
2013/2/25:11:30:35 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:30:35 ce1 CE001 Launch
2013/2/25:11:30:36 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:30:38 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:30:41 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:31:05 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:31:09 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:31:09 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:31:14 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:31:14 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:11:31:21 ce1 CE001 === Setup ended ===
2013/2/25:11:32:04 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:32:04 ce1 CE001 Launch
2013/2/25:11:32:06 ce1 CE001 === Setup ended ===
2013/2/25:11:32:05 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:32:05 ce1 CE001 Launch
2013/2/25:11:32:06 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:32:08 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:32:13 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:32:19 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:32:19 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:32:34 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:32:34 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:32:37 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:32:41 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:32:56 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:34:23 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:34:23 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:34:29 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:34:30 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:11:37:46 ce1 CE001 === Setup ended ===
2013/2/25:11:48:00 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:48:00 ce1 CE001 Launch
2013/2/25:11:48:47 ce1 CE001 === Setup ended ===
2013/2/25:11:48:10 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:48:10 ce1 CE001 Launch
2013/2/25:11:48:47 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:48:50 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:48:52 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:49:08 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:49:13 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:49:13 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:49:18 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:49:27 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:11:49:32 ce1 CE001 === Setup ended ===
2013/2/25:11:50:04 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:50:04 ce1 CE001 Launch
2013/2/25:11:50:06 ce1 CE001 === Setup ended ===
2013/2/25:11:50:05 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:50:05 ce1 CE001 Launch
2013/2/25:11:50:06 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:50:10 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:50:12 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:50:14 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:50:16 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:50:16 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:50:20 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:50:20 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:11:50:24 ce1 CE001 === Setup ended ===
2013/2/25:11:51:31 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:51:31 ce1 CE001 Launch
2013/2/25:11:52:23 ce1 CE001 === Setup ended ===
2013/2/25:11:51:40 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:51:40 ce1 CE001 Launch
2013/2/25:11:52:23 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:52:27 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:52:29 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:52:31 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:52:37 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:52:37 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:52:41 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:52:50 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:11:55:00 ce1 CE001 === Setup ended ===
2013/2/25:11:56:16 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:56:16 ce1 CE001 Launch
2013/2/25:11:56:18 ce1 CE001 === Setup ended ===
2013/2/25:11:56:17 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:56:17 ce1 CE001 Launch
2013/2/25:11:56:18 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:56:21 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:56:23 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:56:27 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:56:28 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:56:28 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:56:32 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:56:32 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:12:01:40 ce1 CE001 === Setup ended ===
2013/2/25:12:32:47 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:12:32:47 ce1 CE001 Launch
2013/2/25:12:33:38 ce1 CE001 === Setup ended ===
2013/2/25:12:32:56 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:12:32:56 ce1 CE001 Launch
2013/2/25:12:33:38 ce1 CE001 PageOpen LaunchDialog
2013/2/25:12:46:53 ce1 CE001 PageOpen LicenseDialog
2013/2/25:12:46:57 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:12:46:59 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:12:47:01 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:12:47:20 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:12:47:27 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
Thank You!
Mike
6 REPLIES 6
philip.s
in reply to: cec
Hi john,
This is most likely failing because the prerequisite already installed on the workstation is newer than the one supplied by the Autodesk installer.  Because Windows will not allow an older version of the prerequisite to be installed, the installation aborts with a 1603 error in the installation log file.
A typical workaround is to uinstall the prerequisite (Microsoft Visual C++ 2008 SP1 Redistributable) via the Control Panel (add / remove programs), and then reinstall the software.
For additional 1603 error causes and corresponding solutions, click here.
Please accept as a solution if this fully resolves the issue, or reply with specifics if the problem still persists.
cec
in reply to: philip.s
Still not working and coming up with the same error, I uninstalled all the visuals and then tryied to reinstall AutoCAD it made it throught the visual 84 install but failed at the visual 64 install.
cec
here is my new log
2013/2/25:12:47:36 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:12:48:09 ce1 CE001 === Setup ended ===
2013/2/27:09:48:45 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:09:48:45 ce1 CE001 Launch
2013/2/27:09:49:35 ce1 CE001 === Setup ended ===
2013/2/27:09:48:54 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:09:48:54 ce1 CE001 Launch
2013/2/27:09:49:35 ce1 CE001 PageOpen LaunchDialog
2013/2/27:09:49:38 ce1 CE001 PageOpen LicenseDialog
2013/2/27:09:49:41 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:09:49:54 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:09:49:56 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:09:49:56 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:09:50:02 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/27:09:50:12 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/27:09:50:15 ce1 CE001 === Setup ended ===
2013/2/27:09:52:22 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:09:52:22 ce1 CE001 Launch
2013/2/27:09:52:24 ce1 CE001 === Setup ended ===
2013/2/27:09:52:23 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:09:52:23 ce1 CE001 Launch
2013/2/27:09:52:24 ce1 CE001 PageOpen LaunchDialog
2013/2/27:09:52:25 ce1 CE001 PageOpen LicenseDialog
2013/2/27:09:52:27 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:09:52:30 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:09:52:32 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:09:52:32 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/27:09:52:36 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/2/27:09:52:36 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:09:52:40 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/27:09:52:40 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/27:09:53:06 ce1 CE001 === Setup ended ===
2013/2/27:09:59:07 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:09:59:07 ce1 CE001 Launch
2013/2/27:09:59:09 ce1 CE001 === Setup ended ===
2013/2/27:09:59:08 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:09:59:08 ce1 CE001 Launch
2013/2/27:09:59:09 ce1 CE001 PageOpen LaunchDialog
2013/2/27:09:59:10 ce1 CE001 PageOpen LicenseDialog
2013/2/27:09:59:13 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:09:59:15 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:09:59:18 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:09:59:18 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/27:09:59:20 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/2/27:09:59:20 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:09:59:25 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/27:09:59:25 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/27:09:59:52 ce1 CE001 === Setup ended ===
2013/2/27:10:00:12 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:00:12 ce1 CE001 Launch
2013/2/27:10:00:15 ce1 CE001 === Setup ended ===
2013/2/27:10:00:14 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:00:14 ce1 CE001 Launch
2013/2/27:10:00:15 ce1 CE001 PageOpen LaunchDialog
2013/2/27:10:00:16 ce1 CE001 PageOpen LicenseDialog
2013/2/27:10:00:17 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:10:00:20 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:10:00:22 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:10:00:22 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:10:00:26 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/27:10:00:26 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/27:10:00:34 ce1 CE001 === Setup ended ===
2013/2/27:10:15:43 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:15:43 ce1 CE001 Launch
2013/2/27:10:16:26 ce1 CE001 === Setup ended ===
2013/2/27:10:15:49 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:15:49 ce1 CE001 Launch
2013/2/27:10:16:26 ce1 CE001 PageOpen LaunchDialog
2013/2/27:10:16:28 ce1 CE001 PageOpen LicenseDialog
2013/2/27:10:16:30 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:10:16:33 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:10:16:34 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:10:16:35 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/27:10:16:38 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/2/27:10:16:38 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:10:16:42 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/27:10:16:52 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/27:10:20:06 ce1 CE001 === Setup ended ===
2013/2/27:10:29:08 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:29:08 ce1 CE001 Launch
2013/2/27:10:29:10 ce1 CE001 === Setup ended ===
2013/2/27:10:29:09 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:29:09 ce1 CE001 Launch
2013/2/27:10:29:10 ce1 CE001 PageOpen LaunchDialog
2013/2/27:10:29:11 ce1 CE001 PageOpen LicenseDialog
2013/2/27:10:29:13 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:10:29:16 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:10:29:18 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:10:29:18 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:10:29:21 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/27:10:29:22 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/27:10:29:43 ce1 CE001 === Setup ended ===
2013/2/27:10:46:19 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:46:19 ce1 CE001 Launch
2013/2/27:10:46:21 ce1 CE001 === Setup ended ===
2013/2/27:10:46:20 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:46:20 ce1 CE001 Launch
2013/2/27:10:46:21 ce1 CE001 PageOpen LaunchDialog
2013/2/27:10:46:22 ce1 CE001 PageOpen LicenseDialog
2013/2/27:10:46:24 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:10:46:27 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:10:48:24 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:10:48:24 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/27:10:48:26 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/2/27:10:48:26 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:10:48:29 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
TravisNave
in reply to: cec
See if you can install this prerequisite manually from Microsoft direct.
http://www.microsoft.com/en-us/download/details.aspx?id=2092
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. If it is already installed, uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
cec
in reply to: TravisNave
Yes i was able to install it directly from the link but it still fails with the same error, I also read through your other post and nothing from there has worked either. I have completly uninstalled visual from the computer and nothing has worked.
TravisNave
in reply to: cec
Your only recourse will be to install directly from the link, then modify the setup.ini file to exclude the requirement check for the prerequisite.  This is a very difficult task.  I do have instructions on how to do that in the follow-up to the link I provided.
Autodesk Forums:
Administrator Productivity
