Installation & Licensing
Installation Failure AutoCAD 2013
37 REPLIES 37
Message 1 of 38
39276 Views, 37 Replies
I have tried numerous times to install AutoCAD 2013 and it gets to the end it says INSTALLATION COMPLETE SOME PRODUCTS FAILED TO INSTALL and NOTHING has installed.PLEASE HELP I have homework due!
37 REPLIES 37
Message 21 of 38
TravisNave
@Anonymous wrote:
Hello and thank you for your answer. 😧 is my windows drive, and I let the program to install in his default location but unfortunately with no result. Can you please help me with further information?
Thank you for your time and support.
Best regards,
Ionut Manea
Need the log file, Ionut.  Every installation failure is unique.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 22 of 38
in reply to: TravisNave
Hello and thank you so much for your answer. Here is my log file... thank you again for your help.
Message 23 of 38
TravisNave
Unfortunately, your 1603 error is not really yielding any particular reason for the failure.
Autodesk Forums:
Message 24 of 38
help me....this is my log file...window 8 single language.
Message 25 of 38
TravisNave
AutoCAD 2013 is not supported on Windows 8.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
Your only recourse to get it to work on Windows 8 is to remove the prerequisite check for .NET Framework from within the setup.ini.  See my follow up here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
Message 26 of 38
problem solved...tq
Message 27 of 38
I am having a simliar issue; I have tried to install following the .NET framework cleanup utility (followed with a reboot) to no avail.
Below are the logs:
2013/4/16:12:50:32 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/16:12:50:32 ckortright SWHITTLE Launch
2013/4/16:12:51:16 ckortright SWHITTLE === Setup ended ===
2013/4/16:12:50:33 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/16:12:50:33 ckortright SWHITTLE Launch
2013/4/16:12:51:16 ckortright SWHITTLE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/4/16:12:51:16 ckortright SWHITTLE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/4/16:12:51:16 ckortright SWHITTLE PageOpen LaunchDialog
2013/4/16:12:51:19 ckortright SWHITTLE PageOpen LicenseDialog
2013/4/16:12:51:22 ckortright SWHITTLE PageOpen ProductInfoDialog
2013/4/16:13:01:08 ckortright SWHITTLE PageOpen ProductSelectionDialog2
2013/4/16:13:01:17 ckortright SWHITTLE PageOpen FullProgressDialog
2013/4/16:13:01:17 ckortright SWHITTLE Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/16:13:01:53 ckortright SWHITTLE Install DirectX® Runtime Succeeded
2013/4/16:13:01:53 ckortright SWHITTLE Installing FaroSDK: H:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
2013/4/16:13:01:58 ckortright SWHITTLE Install FaroSDK Succeeded
2013/4/16:13:01:59 ckortright SWHITTLE Installing AutoCAD® 2013: TRANSFORMS="H:\x64\en-us\acad\acad.mst;C:\Users\CKORTR~1\AppData\Local\Temp\_AI6BF0.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:13:03:34 ckortright SWHITTLE Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2013/4/16:13:03:34 ckortright SWHITTLE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/4/16:13:03:36 ckortright SWHITTLE PageOpen InstallCompleteDialog
2013/4/16:13:08:53 ckortright SWHITTLE === Setup ended ===
2013/4/16:13:11:48 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/16:13:11:48 ckortright SWHITTLE Launch
2013/4/16:13:12:33 ckortright SWHITTLE === Setup ended ===
2013/4/16:13:11:49 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/16:13:11:49 ckortright SWHITTLE Launch
2013/4/16:13:12:32 ckortright SWHITTLE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/4/16:13:12:32 ckortright SWHITTLE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/4/16:13:12:33 ckortright SWHITTLE PageOpen LaunchDialog
2013/4/16:13:12:37 ckortright SWHITTLE PageOpen LicenseDialog
2013/4/16:13:12:43 ckortright SWHITTLE PageOpen ProductInfoDialog
2013/4/16:13:13:08 ckortright SWHITTLE PageOpen ProductSelectionDialog2
2013/4/16:13:13:41 ckortright SWHITTLE PageOpen FullProgressDialog
2013/4/16:13:13:41 ckortright SWHITTLE Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): H:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/4/16:13:13:46 ckortright SWHITTLE Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/4/16:13:13:46 ckortright SWHITTLE Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): H:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/4/16:13:13:50 ckortright SWHITTLE Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2013/4/16:13:13:50 ckortright SWHITTLE Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): H:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86_2010sp1.exe /q /norestart
2013/4/16:13:14:03 ckortright SWHITTLE Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/4/16:13:14:03 ckortright SWHITTLE Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): H:\3rdParty\x64\VCRedist\2010SP1\vcredist_x64_2010sp1.exe /q /norestart
2013/4/16:13:14:10 ckortright SWHITTLE Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/4/16:13:14:10 ckortright SWHITTLE Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/16:13:14:45 ckortright SWHITTLE Install DirectX® Runtime Succeeded
2013/4/16:13:14:45 ckortright SWHITTLE Installing FaroSDK: H:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
2013/4/16:13:14:52 ckortright SWHITTLE Install FaroSDK Succeeded
2013/4/16:13:14:52 ckortright SWHITTLE Installing AutoCAD® 2013: TRANSFORMS="H:\x64\en-us\acad\acad.mst;C:\Users\CKORTR~1\AppData\Local\Temp\_AIE6BB.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:13:16:30 ckortright SWHITTLE Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2013/4/16:13:16:30 ckortright SWHITTLE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/4/16:13:16:32 ckortright SWHITTLE PageOpen InstallCompleteDialog
2013/4/16:13:17:55 ckortright SWHITTLE === Setup ended ===
2013/4/16:13:17:59 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/16:13:17:59 ckortright SWHITTLE Launch
2013/4/16:13:18:44 ckortright SWHITTLE === Setup ended ===
2013/4/16:13:18:01 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/16:13:18:01 ckortright SWHITTLE Launch
2013/4/16:13:18:44 ckortright SWHITTLE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/4/16:13:18:44 ckortright SWHITTLE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/4/16:13:18:44 ckortright SWHITTLE PageOpen LaunchDialog
2013/4/16:13:18:58 ckortright SWHITTLE PageOpen LicenseDialog
2013/4/16:13:19:02 ckortright SWHITTLE PageOpen ProductInfoDialog
2013/4/16:13:19:22 ckortright SWHITTLE PageOpen ProductSelectionDialog2
2013/4/16:13:19:29 ckortright SWHITTLE PageOpen FullProgressDialog
2013/4/16:13:19:29 ckortright SWHITTLE Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/16:13:20:07 ckortright SWHITTLE Install DirectX® Runtime Succeeded
2013/4/16:13:20:07 ckortright SWHITTLE Installing Autodesk® Navisworks® Manage 2013: TRANSFORMS="H:\x64\en-us\NAVMAN\roamer.mst;C:\Users\CKORTR~1\AppData\Local\Temp\_AI9091.tmp\x64\NAVMAN\roamer-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\Navisworks Manage 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:13:24:37 ckortright SWHITTLE Install Autodesk® Navisworks® Manage 2013 Succeeded
2013/4/16:13:24:38 ckortright SWHITTLE Installing Autodesk® Navisworks® Manage 2013 Language Pack: TRANSFORMS="C:\Users\CKORTR~1\AppData\Local\Temp\_AI9091.tmp\_laA30D.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\Navisworks Manage 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:13:24:45 ckortright SWHITTLE Install Autodesk® Navisworks® Manage 2013 Language Pack Succeeded
2013/4/16:13:24:45 ckortright SWHITTLE Installing Navisworks® Manage 2013 - 2013 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:13:25:26 ckortright SWHITTLE Install Navisworks® Manage 2013 - 2013 DWG File Reader Succeeded
2013/4/16:13:25:26 ckortright SWHITTLE Installing Navisworks® Manage 2013 - 2012 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:13:25:51 ckortright SWHITTLE Install Navisworks® Manage 2013 - 2012 DWG File Reader Succeeded
2013/4/16:13:25:51 ckortright SWHITTLE Installing Navisworks® Manage 2013 - 2011 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:13:26:17 ckortright SWHITTLE Install Navisworks® Manage 2013 - 2011 DWG File Reader Succeeded
2013/4/16:13:26:17 ckortright SWHITTLE Installing Navisworks® Manage 2013 - 2010 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:13:26:43 ckortright SWHITTLE Install Navisworks® Manage 2013 - 2010 DWG File Reader Succeeded
2013/4/16:13:26:43 ckortright SWHITTLE Installing Navisworks® Manage 2013 - 2009 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:13:27:02 ckortright SWHITTLE Install Navisworks® Manage 2013 - 2009 DWG File Reader Succeeded
2013/4/16:13:27:02 ckortright SWHITTLE Installing Navisworks® Manage 2013 - 2008 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:13:27:16 ckortright SWHITTLE Install Navisworks® Manage 2013 - 2008 DWG File Reader Succeeded
2013/4/16:13:27:17 ckortright SWHITTLE PageOpen InstallCompleteDialog
2013/4/16:13:27:26 ckortright SWHITTLE === Setup ended ===
2013/4/16:13:29:00 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/16:13:29:00 ckortright SWHITTLE Launch
2013/4/16:13:30:30 ckortright SWHITTLE === Setup ended ===
2013/4/16:13:29:05 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/16:13:29:05 ckortright SWHITTLE Launch
2013/4/16:13:30:29 ckortright SWHITTLE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/4/16:13:30:29 ckortright SWHITTLE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/4/16:13:30:30 ckortright SWHITTLE PageOpen LaunchDialog
2013/4/16:13:30:32 ckortright SWHITTLE PageOpen LicenseDialog
2013/4/16:13:30:35 ckortright SWHITTLE PageOpen ProductInfoDialog
2013/4/16:13:31:34 ckortright SWHITTLE PageOpen ProductSelectionDialog2
2013/4/16:13:31:44 ckortright SWHITTLE PageOpen FullProgressDialog
2013/4/16:13:31:44 ckortright SWHITTLE Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/16:13:33:07 ckortright SWHITTLE Install DirectX® Runtime Succeeded
2013/4/16:13:33:07 ckortright SWHITTLE Installing FaroSDK: H:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
2013/4/16:13:33:13 ckortright SWHITTLE Install FaroSDK Succeeded
2013/4/16:13:33:14 ckortright SWHITTLE Installing AutoCAD® 2013: TRANSFORMS="H:\x64\en-us\acad\acad.mst;C:\Users\CKORTR~1\AppData\Local\Temp\_AIA346.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:13:35:06 ckortright SWHITTLE Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2013/4/16:13:35:06 ckortright SWHITTLE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/4/16:13:35:07 ckortright SWHITTLE PageOpen InstallCompleteDialog
2013/4/16:13:45:28 ckortright SWHITTLE === Setup ended ===
2013/4/16:13:45:44 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/16:13:45:44 ckortright SWHITTLE Launch
2013/4/16:13:46:49 ckortright SWHITTLE === Setup ended ===
2013/4/16:13:45:48 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/16:13:45:48 ckortright SWHITTLE Launch
2013/4/16:13:46:48 ckortright SWHITTLE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/4/16:13:46:48 ckortright SWHITTLE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/4/16:13:46:49 ckortright SWHITTLE PageOpen LaunchDialog
2013/4/16:13:46:51 ckortright SWHITTLE PageOpen LicenseDialog
2013/4/16:13:46:53 ckortright SWHITTLE PageOpen ProductInfoDialog
2013/4/16:13:47:14 ckortright SWHITTLE PageOpen ProductSelectionDialog2
2013/4/16:13:47:24 ckortright SWHITTLE PageOpen FullProgressDialog
2013/4/16:13:47:25 ckortright SWHITTLE Installing .NET Framework Runtime 4.0: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/4/16:13:48:31 ckortright SWHITTLE Install .NET Framework Runtime 4.0 Succeeded
2013/4/16:13:48:31 ckortright SWHITTLE Installing .NET Framework Runtime 4.0 KB2468871: H:\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/4/16:13:50:15 ckortright SWHITTLE Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/4/16:13:50:15 ckortright SWHITTLE Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/16:13:51:10 ckortright SWHITTLE Install DirectX® Runtime Succeeded
2013/4/16:13:51:10 ckortright SWHITTLE Installing FaroSDK: H:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
2013/4/16:13:51:15 ckortright SWHITTLE Install FaroSDK Succeeded
2013/4/16:13:51:16 ckortright SWHITTLE Installing AutoCAD® 2013: TRANSFORMS="H:\x64\en-us\acad\acad.mst;C:\Users\CKORTR~1\AppData\Local\Temp\_AIF7BC.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:13:53:06 ckortright SWHITTLE Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2013/4/16:13:53:06 ckortright SWHITTLE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/4/16:13:53:06 ckortright SWHITTLE Rollback .NET Framework Runtime 4.0 KB2468871 Failed Failure is ignored, Result=1619
2013/4/16:13:53:06 ckortright SWHITTLE Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
2013/4/16:13:53:08 ckortright SWHITTLE PageOpen InstallCompleteDialog
2013/4/16:13:54:03 ckortright SWHITTLE === Setup ended ===
2013/4/16:13:54:11 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/16:13:54:11 ckortright SWHITTLE Launch
2013/4/16:13:55:17 ckortright SWHITTLE === Setup ended ===
2013/4/16:13:54:15 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/16:13:54:15 ckortright SWHITTLE Launch
2013/4/16:13:55:16 ckortright SWHITTLE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/4/16:13:55:16 ckortright SWHITTLE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/4/16:13:55:17 ckortright SWHITTLE PageOpen LaunchDialog
2013/4/16:13:56:55 ckortright SWHITTLE PageOpen LicenseDialog
2013/4/16:13:56:59 ckortright SWHITTLE PageOpen ProductInfoDialog
2013/4/16:13:57:16 ckortright SWHITTLE PageOpen ProductSelectionDialog2
2013/4/16:13:57:24 ckortright SWHITTLE PageOpen FullProgressDialog
2013/4/16:13:57:24 ckortright SWHITTLE Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/16:13:58:15 ckortright SWHITTLE Install DirectX® Runtime Succeeded
2013/4/16:13:58:15 ckortright SWHITTLE Installing FaroSDK: H:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
2013/4/16:13:58:23 ckortright SWHITTLE Install FaroSDK Succeeded
2013/4/16:13:58:23 ckortright SWHITTLE Installing AutoCAD® 2013: TRANSFORMS="H:\x64\en-us\acad\acad.mst;C:\Users\CKORTR~1\AppData\Local\Temp\_AIB283.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/16:14:00:03 ckortright SWHITTLE Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2013/4/16:14:00:03 ckortright SWHITTLE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/4/16:14:00:04 ckortright SWHITTLE PageOpen InstallCompleteDialog
2013/4/16:14:00:52 ckortright SWHITTLE === Setup ended ===
2013/4/17:10:16:51 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/17:10:16:51 ckortright SWHITTLE Launch
2013/4/17:10:18:23 ckortright SWHITTLE === Setup ended ===
2013/4/17:10:16:56 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/17:10:16:56 ckortright SWHITTLE Launch
2013/4/17:10:18:22 ckortright SWHITTLE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/4/17:10:18:22 ckortright SWHITTLE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/4/17:10:18:23 ckortright SWHITTLE PageOpen LaunchDialog
2013/4/17:10:18:27 ckortright SWHITTLE PageOpen LicenseDialog
2013/4/17:10:18:32 ckortright SWHITTLE PageOpen ProductInfoDialog
2013/4/17:10:19:21 ckortright SWHITTLE PageOpen ProductSelectionDialog2
2013/4/17:10:20:23 ckortright SWHITTLE PageOpen FullProgressDialog
2013/4/17:10:20:23 ckortright SWHITTLE Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/17:10:21:56 ckortright SWHITTLE Install DirectX® Runtime Succeeded
2013/4/17:10:21:56 ckortright SWHITTLE Installing FaroSDK: H:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
2013/4/17:10:22:02 ckortright SWHITTLE Install FaroSDK Succeeded
2013/4/17:10:22:02 ckortright SWHITTLE Installing AutoCAD® 2013: TRANSFORMS="H:\x64\en-us\acad\acad.mst;C:\Users\CKORTR~1\AppData\Local\Temp\_AI37E4.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/17:10:23:55 ckortright SWHITTLE Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2013/4/17:10:23:55 ckortright SWHITTLE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/4/17:10:23:56 ckortright SWHITTLE PageOpen InstallCompleteDialog
2013/4/17:10:35:18 ckortright SWHITTLE === Setup ended ===
2013/4/17:10:35:41 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/17:10:35:41 ckortright SWHITTLE Launch
2013/4/17:10:36:27 ckortright SWHITTLE === Setup ended ===
2013/4/17:10:35:42 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/17:10:35:42 ckortright SWHITTLE Launch
2013/4/17:10:36:27 ckortright SWHITTLE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/4/17:10:36:27 ckortright SWHITTLE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/4/17:10:36:27 ckortright SWHITTLE PageOpen LaunchDialog
2013/4/17:10:36:34 ckortright SWHITTLE PageOpen LicenseDialog
2013/4/17:10:36:42 ckortright SWHITTLE PageOpen ProductInfoDialog
2013/4/17:10:37:04 ckortright SWHITTLE PageOpen ProductSelectionDialog2
2013/4/17:10:37:20 ckortright SWHITTLE PageOpen FullProgressDialog
2013/4/17:10:37:20 ckortright SWHITTLE Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/17:10:38:00 ckortright SWHITTLE Install DirectX® Runtime Succeeded
2013/4/17:10:38:00 ckortright SWHITTLE Installing FaroSDK: H:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
2013/4/17:10:38:04 ckortright SWHITTLE Install FaroSDK Succeeded
2013/4/17:10:38:05 ckortright SWHITTLE Installing AutoCAD® 2013: TRANSFORMS="H:\x64\en-us\acad\acad.mst;C:\Users\CKORTR~1\AppData\Local\Temp\_AI75AF.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/17:10:39:41 ckortright SWHITTLE Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2013/4/17:10:39:41 ckortright SWHITTLE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/4/17:10:39:42 ckortright SWHITTLE PageOpen InstallCompleteDialog
2013/4/17:10:45:26 ckortright SWHITTLE === Setup ended ===
2013/4/17:10:48:37 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/17:10:48:37 ckortright SWHITTLE Launch
2013/4/17:10:49:23 ckortright SWHITTLE === Setup ended ===
2013/4/17:10:48:38 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/17:10:48:38 ckortright SWHITTLE Launch
2013/4/17:10:49:22 ckortright SWHITTLE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/4/17:10:49:22 ckortright SWHITTLE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/4/17:10:49:22 ckortright SWHITTLE PageOpen LaunchDialog
2013/4/17:10:50:37 ckortright SWHITTLE PageOpen LicenseDialog
2013/4/17:10:50:50 ckortright SWHITTLE PageOpen ProductInfoDialog
2013/4/17:10:50:57 ckortright SWHITTLE PageOpen ProductSelectionDialog2
2013/4/17:10:58:10 ckortright SWHITTLE === Setup ended ===
2013/4/17:11:04:28 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/17:11:04:28 ckortright SWHITTLE Launch
2013/4/17:11:06:00 ckortright SWHITTLE === Setup ended ===
2013/4/17:11:04:34 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/17:11:04:34 ckortright SWHITTLE Launch
2013/4/17:11:05:59 ckortright SWHITTLE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/4/17:11:05:59 ckortright SWHITTLE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/4/17:11:06:00 ckortright SWHITTLE PageOpen LaunchDialog
2013/4/17:11:06:03 ckortright SWHITTLE PageOpen LicenseDialog
2013/4/17:11:06:10 ckortright SWHITTLE PageOpen ProductInfoDialog
2013/4/17:11:07:16 ckortright SWHITTLE PageOpen ProductSelectionDialog2
2013/4/17:11:07:30 ckortright SWHITTLE PageOpen FullProgressDialog
2013/4/17:11:07:30 ckortright SWHITTLE Installing .NET Framework Runtime 4.0: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/4/17:11:09:38 ckortright SWHITTLE Install .NET Framework Runtime 4.0 Succeeded
2013/4/17:11:09:38 ckortright SWHITTLE Installing .NET Framework Runtime 4.0 KB2468871: H:\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/4/17:11:11:38 ckortright SWHITTLE Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/4/17:11:11:38 ckortright SWHITTLE Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/17:11:13:08 ckortright SWHITTLE Install DirectX® Runtime Succeeded
2013/4/17:11:13:08 ckortright SWHITTLE Installing FaroSDK: H:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
2013/4/17:11:13:14 ckortright SWHITTLE Install FaroSDK Succeeded
2013/4/17:11:13:14 ckortright SWHITTLE Installing AutoCAD® 2013: TRANSFORMS="H:\x64\en-us\acad\acad.mst;C:\Users\CKORTR~1\AppData\Local\Temp\_AI61FD.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/17:11:15:10 ckortright SWHITTLE Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2013/4/17:11:15:10 ckortright SWHITTLE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/4/17:11:15:10 ckortright SWHITTLE Rollback .NET Framework Runtime 4.0 KB2468871 Failed Failure is ignored, Result=1619
2013/4/17:11:15:10 ckortright SWHITTLE Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
2013/4/17:11:15:11 ckortright SWHITTLE PageOpen InstallCompleteDialog
2013/4/17:11:19:53 ckortright SWHITTLE === Setup ended ===
2013/4/17:11:19:58 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/17:11:19:58 ckortright SWHITTLE Launch
2013/4/17:11:20:44 ckortright SWHITTLE === Setup ended ===
2013/4/17:11:19:59 ckortright SWHITTLE === Setup started on SWHITTLE by ckortright ===
2013/4/17:11:19:59 ckortright SWHITTLE Launch
2013/4/17:11:20:43 ckortright SWHITTLE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/4/17:11:20:43 ckortright SWHITTLE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/4/17:11:20:43 ckortright SWHITTLE PageOpen LaunchDialog
2013/4/17:11:21:05 ckortright SWHITTLE PageOpen LicenseDialog
2013/4/17:11:21:12 ckortright SWHITTLE PageOpen ProductInfoDialog
2013/4/17:11:21:19 ckortright SWHITTLE PageOpen ProductSelectionDialog2
2013/4/17:11:22:07 ckortright SWHITTLE PageOpen FullProgressDialog
2013/4/17:11:22:08 ckortright SWHITTLE Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/17:11:22:43 ckortright SWHITTLE Install DirectX® Runtime Succeeded
2013/4/17:11:22:43 ckortright SWHITTLE Installing FaroSDK: H:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
2013/4/17:11:22:53 ckortright SWHITTLE Install FaroSDK Succeeded
2013/4/17:11:22:53 ckortright SWHITTLE Installing AutoCAD® 2013: TRANSFORMS="H:\x64\en-us\acad\acad.mst;C:\Users\CKORTR~1\AppData\Local\Temp\_AI906C.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/4/17:11:24:27 ckortright SWHITTLE Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2013/4/17:11:24:27 ckortright SWHITTLE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Message 28 of 38
TravisNave
See my 1603 error link.
Autodesk Forums:
Message 29 of 38
christjackson67
hello everyone..
I have tried couple of times installing this package (Autocad 2013) on my laptop loaded with windows 7 x64 bit operating system. The installer stopped during .net installer framework 4.0 and eventually showed up a screen with product failed to install, some how i tried to install .net framework 4.0 from the  microsoft website and ended up with same problem. it showed " installer stopped working".
Any help would be greatly appreciated.
Here is the log file generated :
2013/7/7:10:44:12 ASRA ASRA-PC === Setup started on ASRA-PC by ASRA ===
2013/7/7:10:44:12 ASRA ASRA-PC Launch
2013/7/7:10:45:12 ASRA ASRA-PC === Setup ended ===
2013/7/7:10:44:37 ASRA ASRA-PC === Setup started on ASRA-PC by ASRA ===
2013/7/7:10:44:37 ASRA ASRA-PC Launch
2013/7/7:10:45:08 ASRA ASRA-PC PageOpen LaunchDialog
2013/7/7:10:45:11 ASRA ASRA-PC PageOpen LicenseDialog
2013/7/7:10:45:14 ASRA ASRA-PC PageOpen ProductInfoDialog
2013/7/7:10:45:52 ASRA ASRA-PC PageOpen ProductSelectionDialog2
2013/7/7:10:46:03 ASRA ASRA-PC PageOpen FullProgressDialog
2013/7/7:10:46:04 ASRA ASRA-PC Installing .NET Framework Runtime 4.0: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/7/7:10:46:40 ASRA ASRA-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2013/7/7:10:47:12 ASRA ASRA-PC PageOpen InstallCompleteDialog
2013/7/7:10:47:25 ASRA ASRA-PC === Setup ended ===
2013/7/7:11:16:47 ASRA ASRA-PC === Setup started on ASRA-PC by ASRA ===
2013/7/7:11:16:47 ASRA ASRA-PC Launch
2013/7/7:11:17:51 ASRA ASRA-PC === Setup ended ===
2013/7/7:11:17:16 ASRA ASRA-PC === Setup started on ASRA-PC by ASRA ===
2013/7/7:11:17:16 ASRA ASRA-PC Launch
2013/7/7:11:17:47 ASRA ASRA-PC PageOpen LaunchDialog
2013/7/7:11:20:02 ASRA ASRA-PC PageOpen LicenseDialog
2013/7/7:11:20:04 ASRA ASRA-PC PageOpen ProductInfoDialog
2013/7/7:11:20:51 ASRA ASRA-PC PageOpen ProductSelectionDialog2
2013/7/7:11:20:55 ASRA ASRA-PC PageOpen FullProgressDialog
2013/7/7:11:20:55 ASRA ASRA-PC Installing .NET Framework Runtime 4.0: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/7/7:11:21:24 ASRA ASRA-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
thanx
Message 30 of 38
Welcome Chris.
You might need to try the .NET Cleanup tool for this, since the problem is with your Microsoft OS and not the Autodesk software.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Autodesk Forums:
Message 31 of 38
in reply to: Terenceng
I am having problem with Autocad as well.
After a windows update last week, Autocad seems to be missing and asked to be reinstall.
But i keep having this problem with microsoft Visual C++ 2010, below is my log.
Please help.
2013/11/18:08:30:39    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:08:30:39    achua    JASGPC014    Launch
2013/11/18:08:31:59    achua    JASGPC014    === Setup ended ===
2013/11/18:08:52:32    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:08:52:32    achua    JASGPC014    Launch
2013/11/18:08:52:44    achua    JASGPC014    === Setup ended ===
2013/11/18:09:05:40    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:09:05:40    achua    JASGPC014    Launch
2013/11/18:09:05:46    achua    JASGPC014    === Setup ended ===
2013/11/18:09:05:43    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:09:05:43    achua    JASGPC014    Launch
2013/11/18:09:05:46    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:09:05:48    achua    JASGPC014    PageOpen    LicenseDialog
2013/11/18:09:05:59    achua    JASGPC014    PageOpen    ProductInfoDialog
2013/11/18:09:07:09    achua    JASGPC014    PageOpen    ProductSelectionDialog2
2013/11/18:09:08:15    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:09:08:15    achua    JASGPC014    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\ACHUA~1.JEN\AppData\Local\Temp\vcredist_x86_2010.log
2013/11/18:09:08:26    achua    JASGPC014    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/11/18:09:08:42    achua    JASGPC014    PageOpen    InstallCompleteDialog
2013/11/18:09:15:48    achua    JASGPC014    === Setup ended ===
2013/11/18:09:21:11    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:09:21:11    achua    JASGPC014    Launch
2013/11/18:09:21:17    achua    JASGPC014    === Setup ended ===
2013/11/18:09:21:12    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:09:21:12    achua    JASGPC014    Launch
2013/11/18:09:21:14    achua    JASGPC014    PageOpen    MaintenanceDialog
2013/11/18:09:21:19    achua    JASGPC014    PageOpen    RepairDialog
2013/11/18:09:21:22    achua    JASGPC014    PageOpen    MaintVerifyReadyDialog
2013/11/18:09:21:22    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:09:21:22    achua    JASGPC014    Installing AutoCAD LT® 2013:  ADSK_LAUNCH_MODE="STANDALONE" ADSK_RUNNING_FROM_ADMIN="FALSE" REINSTALL="" REINSTALLMODE="ocum" REMOVE=""  FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/18:09:21:22    achua    JASGPC014    GetMUIDefaultLanguage()    AutoCAD LT® 2013    Error    MsiOpenProduct failed.
2013/11/18:09:21:24    achua    JASGPC014    Reinstall    AutoCAD LT® 2013    Failed    Installation aborted, Result=1605
2013/11/18:09:21:24    achua    JASGPC014    PageOpen    MaintFailedDialog
2013/11/18:09:21:28    achua    JASGPC014    === Setup ended ===
2013/11/18:09:21:33    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:09:21:33    achua    JASGPC014    Launch
2013/11/18:09:21:34    achua    JASGPC014    === Setup ended ===
2013/11/18:09:21:34    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:09:21:34    achua    JASGPC014    Launch
2013/11/18:09:21:34    achua    JASGPC014    PageOpen    MaintenanceDialog
2013/11/18:09:21:36    achua    JASGPC014    PageOpen    MaintVerifyReadyDialog
2013/11/18:09:21:38    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:09:21:38    achua    JASGPC014    Installing AutoCAD LT® 2013:  REMOVE=ALL FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/18:09:21:38    achua    JASGPC014    GetMUIDefaultLanguage()    AutoCAD LT® 2013    Error    MsiOpenProduct failed.
2013/11/18:09:21:40    achua    JASGPC014    Uninstall    AutoCAD LT® 2013    Failed    Installation aborted, Result=1605
2013/11/18:09:21:40    achua    JASGPC014    PageOpen    MaintFailedDialog
2013/11/18:09:21:45    achua    JASGPC014    === Setup ended ===
2013/11/18:09:24:23    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:09:24:23    achua    JASGPC014    Launch
2013/11/18:09:25:50    achua    JASGPC014    === Setup ended ===
2013/11/18:09:24:33    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:09:24:33    achua    JASGPC014    Launch
2013/11/18:09:25:50    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:09:26:01    achua    JASGPC014    PageOpen    LicenseDialog
2013/11/18:09:26:04    achua    JASGPC014    PageOpen    ProductInfoDialog
2013/11/18:09:26:28    achua    JASGPC014    PageOpen    ProductSelectionDialog2
2013/11/18:09:26:33    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:09:26:33    achua    JASGPC014    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/11/18:09:30:11    achua    JASGPC014    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/11/18:09:30:32    achua    JASGPC014    PageOpen    InstallCompleteDialog
2013/11/18:09:31:07    achua    JASGPC014    === Setup ended ===
2013/11/18:09:31:36    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:09:31:36    achua    JASGPC014    Launch
2013/11/18:09:31:41    achua    JASGPC014    === Setup ended ===
2013/11/18:09:31:38    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:09:31:38    achua    JASGPC014    Launch
2013/11/18:09:31:41    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:09:31:42    achua    JASGPC014    PageOpen    LicenseDialog
2013/11/18:09:31:44    achua    JASGPC014    PageOpen    ProductInfoDialog
2013/11/18:09:31:59    achua    JASGPC014    PageOpen    ProductSelectionDialog2
2013/11/18:09:32:05    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:09:32:05    achua    JASGPC014    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\ACHUA~1.JEN\AppData\Local\Temp\vcredist_x86_2010.log
2013/11/18:09:32:12    achua    JASGPC014    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/11/18:09:32:13    achua    JASGPC014    PageOpen    InstallCompleteDialog
2013/11/18:09:37:19    achua    JASGPC014    === Setup ended ===
2013/11/18:09:37:32    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:09:37:32    achua    JASGPC014    Launch
2013/11/18:09:37:38    achua    JASGPC014    === Setup ended ===
2013/11/18:09:37:35    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:09:37:35    achua    JASGPC014    Launch
2013/11/18:09:37:37    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:09:37:39    achua    JASGPC014    PageOpen    LicenseDialog
2013/11/18:09:37:41    achua    JASGPC014    PageOpen    ProductInfoDialog
2013/11/18:09:37:59    achua    JASGPC014    PageOpen    ProductSelectionDialog2
2013/11/18:09:38:02    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:09:38:02    achua    JASGPC014    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\ACHUA~1.JEN\AppData\Local\Temp\vcredist_x86_2010.log
2013/11/18:09:38:09    achua    JASGPC014    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/11/18:09:38:11    achua    JASGPC014    PageOpen    InstallCompleteDialog
2013/11/18:09:39:24    achua    JASGPC014    === Setup ended ===
2013/11/18:11:25:06    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:11:25:06    achua    JASGPC014    Launch
2013/11/18:11:25:20    achua    JASGPC014    === Setup ended ===
2013/11/18:11:25:12    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:11:25:12    achua    JASGPC014    Launch
2013/11/18:11:25:20    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:11:25:48    achua    JASGPC014    PageOpen    LicenseDialog
2013/11/18:11:25:48    achua    JASGPC014    PageOpen    ProductSelectionDialog2
2013/11/18:11:25:55    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:11:25:55    achua    JASGPC014    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\ACHUA~1.JEN\AppData\Local\Temp\vcredist_x86_2010.log
2013/11/18:11:26:02    achua    JASGPC014    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/11/18:11:26:04    achua    JASGPC014    PageOpen    InstallCompleteDialog
2013/11/18:11:27:40    achua    JASGPC014    === Setup ended ===
2013/11/18:11:31:56    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:11:31:56    achua    JASGPC014    Launch
2013/11/18:11:32:08    achua    JASGPC014    === Setup ended ===
2013/11/18:11:32:02    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:11:32:02    achua    JASGPC014    Launch
2013/11/18:11:32:08    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:11:32:11    achua    JASGPC014    PageOpen    LicenseDialog
2013/11/18:11:32:14    achua    JASGPC014    PageOpen    ProductInfoDialog
2013/11/18:11:32:33    achua    JASGPC014    PageOpen    ProductSelectionDialog2
2013/11/18:11:32:35    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:11:32:35    achua    JASGPC014    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/11/18:11:34:43    achua    JASGPC014    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/11/18:11:34:57    achua    JASGPC014    PageOpen    InstallCompleteDialog
2013/11/18:11:38:25    achua    JASGPC014    === Setup ended ===
2013/11/18:11:38:23    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:11:38:23    achua    JASGPC014    Launch
2013/11/18:11:38:28    achua    JASGPC014    === Setup ended ===
2013/11/18:11:38:25    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:11:38:25    achua    JASGPC014    Launch
2013/11/18:11:38:28    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:11:39:59    achua    JASGPC014    === Setup ended ===
2013/11/18:11:52:47    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:11:52:47    achua    JASGPC014    Launch
2013/11/18:11:52:56    achua    JASGPC014    === Setup ended ===
2013/11/18:11:52:53    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:11:52:53    achua    JASGPC014    Launch
2013/11/18:11:52:56    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:11:52:58    achua    JASGPC014    PageOpen    LicenseDialog
2013/11/18:11:53:01    achua    JASGPC014    PageOpen    ProductInfoDialog
2013/11/18:11:53:18    achua    JASGPC014    PageOpen    ProductSelectionDialog2
2013/11/18:11:53:20    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:11:53:20    achua    JASGPC014    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/11/18:11:54:44    achua    JASGPC014    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/11/18:11:55:09    achua    JASGPC014    PageOpen    InstallCompleteDialog
2013/11/18:11:55:29    achua    JASGPC014    === Setup ended ===
2013/11/18:11:55:38    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:11:55:38    achua    JASGPC014    Launch
2013/11/18:11:55:48    achua    JASGPC014    === Setup ended ===
2013/11/18:11:55:44    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:11:55:44    achua    JASGPC014    Launch
2013/11/18:11:55:48    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:11:55:49    achua    JASGPC014    PageOpen    LicenseDialog
2013/11/18:11:55:51    achua    JASGPC014    PageOpen    ProductInfoDialog
2013/11/18:11:56:09    achua    JASGPC014    PageOpen    ProductSelectionDialog2
2013/11/18:11:56:11    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:11:56:11    achua    JASGPC014    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/11/18:11:58:53    achua    JASGPC014    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2013/11/18:11:58:53    achua    JASGPC014    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): E:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/11/18:11:59:20    achua    JASGPC014    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x64)    Succeeded
2013/11/18:11:59:20    achua    JASGPC014    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\ACHUA~1.JEN\AppData\Local\Temp\vcredist_x86_2010.log
2013/11/18:11:59:25    achua    JASGPC014    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/11/18:11:59:36    achua    JASGPC014    PageOpen    InstallCompleteDialog
2013/11/18:12:51:40    achua    JASGPC014    === Setup ended ===
2013/11/18:12:53:23    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:12:53:23    achua    JASGPC014    Launch
2013/11/18:12:53:36    achua    JASGPC014    === Setup ended ===
2013/11/18:12:53:29    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:12:53:29    achua    JASGPC014    Launch
2013/11/18:12:53:36    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:12:53:59    achua    JASGPC014    PageOpen    LicenseDialog
2013/11/18:12:53:59    achua    JASGPC014    PageOpen    ProductSelectionDialog2
2013/11/18:12:54:02    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:12:54:02    achua    JASGPC014    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\ACHUA~1.JEN\AppData\Local\Temp\vcredist_x86_2010.log
2013/11/18:12:54:08    achua    JASGPC014    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/11/18:13:08:38    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:13:08:38    achua    JASGPC014    Launch
2013/11/18:13:10:12    achua    JASGPC014    === Setup ended ===
2013/11/18:13:08:51    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:13:08:51    achua    JASGPC014    Launch
2013/11/18:13:10:12    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:13:10:54    achua    JASGPC014    PageOpen    LicenseDialog
2013/11/18:13:10:54    achua    JASGPC014    PageOpen    ProductSelectionDialog2
2013/11/18:13:11:07    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:13:11:07    achua    JASGPC014    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\ACHUA~1.JEN\AppData\Local\Temp\vcredist_x86_2010.log
2013/11/18:13:11:15    achua    JASGPC014    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/11/18:13:11:17    achua    JASGPC014    PageOpen    InstallCompleteDialog
2013/11/18:13:20:57    achua    JASGPC014    === Setup ended ===
2013/11/18:13:21:18    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:13:21:18    achua    JASGPC014    Launch
2013/11/18:13:21:29    achua    JASGPC014    === Setup ended ===
2013/11/18:13:21:24    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:13:21:24    achua    JASGPC014    Launch
2013/11/18:13:21:29    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:13:21:38    achua    JASGPC014    PageOpen    LicenseDialog
2013/11/18:13:21:40    achua    JASGPC014    PageOpen    ProductInfoDialog
2013/11/18:13:22:10    achua    JASGPC014    PageOpen    ProductSelectionDialog2
2013/11/18:13:22:13    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:13:22:13    achua    JASGPC014    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\ACHUA~1.JEN\AppData\Local\Temp\vcredist_x86_2010.log
2013/11/18:13:22:20    achua    JASGPC014    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/11/18:13:22:27    achua    JASGPC014    PageOpen    InstallCompleteDialog
2013/11/18:13:24:35    achua    JASGPC014    === Setup ended ===
2013/11/18:13:27:58    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:13:27:58    achua    JASGPC014    Launch
2013/11/18:13:28:02    achua    JASGPC014    === Setup ended ===
2013/11/18:13:27:59    achua    JASGPC014    === Setup started on JASGPC014 by achua ===
2013/11/18:13:27:59    achua    JASGPC014    Launch
2013/11/18:13:28:02    achua    JASGPC014    PageOpen    LaunchDialog
2013/11/18:13:29:02    achua    JASGPC014    PageOpen    LicenseDialog
2013/11/18:13:29:04    achua    JASGPC014    PageOpen    ProductInfoDialog
2013/11/18:13:29:08    achua    JASGPC014    PageOpen    ProductSelectionDialog2
2013/11/18:13:29:10    achua    JASGPC014    PageOpen    FullProgressDialog
2013/11/18:13:29:10    achua    JASGPC014    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\ACHUA~1.JEN\AppData\Local\Temp\vcredist_x86_2010.log
2013/11/18:13:29:22    achua    JASGPC014    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
Message 32 of 38
Can't install on windows 7. Here is the log. thank you
Message 33 of 38
diego.ledesma9
Hi. I'm having serious trouble. I already uninstalled Windows C++ several times and cleaned my temp folder and nothing. Still failing. 2014/2/26:18:12:18 Diego DIEGOS === Setup started on DIEGOS by Diego === 2014/2/26:18:12:18 Diego DIEGOS Path_Length: 155 2014/2/26:18:12:18 Diego DIEGOS Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us 2014/2/26:18:12:18 Diego DIEGOS Launch 2014/2/26:18:12:18 Diego DIEGOS CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-37725081 /PK 001F1 /student /akamai /auth authparam /sid SESSION_ID 2014/2/26:18:12:18 Diego DIEGOS Path_Length: 155 2014/2/26:18:12:18 Diego DIEGOS Current Directory C:\Users\Diego\AppData\Local\Temp\_AI26FF.tmp 2014/2/26:18:13:06 Diego DIEGOS === Setup ended === 2014/2/26:18:12:19 Diego DIEGOS === Setup started on DIEGOS by Diego === 2014/2/26:18:12:19 Diego DIEGOS Path_Length: 155 2014/2/26:18:12:19 Diego DIEGOS Current Directory C:\Users\Diego\AppData\Local\Temp\_AI26FF.tmp 2014/2/26:18:12:19 Diego DIEGOS Launch 2014/2/26:18:12:20 Diego DIEGOS Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6... 2014/2/26:18:13:06 Diego DIEGOS Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6... 2014/2/26:18:13:06 Diego DIEGOS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Diego\AppData\Local\Temp\_AI26FF.tmp\Setup\AcSetup.dll 2014/2/26:18:13:06 Diego DIEGOS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/2/26:18:13:06 Diego DIEGOS PageOpen LaunchDialog 2014/2/26:18:14:22 Diego DIEGOS PageOpen LicenseDialog 2014/2/26:18:14:25 Diego DIEGOS PageOpen ProductInfoDialog 2014/2/26:18:14:25 Diego DIEGOS PageOpen ProductSelectionDialog2 2014/2/26:18:14:28 Diego DIEGOS PageOpen FullProgressDialog 2014/2/26:18:14:29 Diego DIEGOS Download Play VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST... 2014/2/26:18:14:31 Diego DIEGOS Download Complete VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST... 2014/2/26:18:14:31 Diego DIEGOS Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q 2014/2/26:18:14:39 Diego DIEGOS Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2014/2/26:18:14:40 Diego DIEGOS Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST... 2014/2/26:18:14:42 Diego DIEGOS Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST... 2014/2/26:18:14:42 Diego DIEGOS Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q 2014/2/26:18:14:48 Diego DIEGOS Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2014/2/26:18:14:48 Diego DIEGOS Download Play VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST... 2014/2/26:18:14:51 Diego DIEGOS Download Complete VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST... 2014/2/26:18:14:51 Diego DIEGOS Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\Diego\AppData\Local\Temp\vcredist_x86_2010.log 2014/2/26:18:14:56 Diego DIEGOS Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2014/2/26:18:14:56 Diego DIEGOS Download Play VCREDIST2010SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST... 2014/2/26:18:14:59 Diego DIEGOS Download Complete VCREDIST2010SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST... 2014/2/26:18:14:59 Diego DIEGOS Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\Diego\AppData\Local\Temp\vcredist_x64_2010.log 2014/2/26:18:15:05 Diego DIEGOS Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2014/2/26:18:15:05 Diego DIEGOS Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DIRECTX.... 2014/2/26:18:15:11 Diego DIEGOS Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DIRECTX.... 2014/2/26:18:15:11 Diego DIEGOS Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent 2014/2/26:18:15:20 Diego DIEGOS Install DirectX Runtime Succeeded 2014/2/26:18:15:20 Diego DIEGOS Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/2/26:18:15:25 Diego DIEGOS Install FARO LS 5.1.0.30630 (64bit) Succeeded 2014/2/26:18:15:26 Diego DIEGOS Download Play CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CM.tar.l... 2014/2/26:18:15:48 Diego DIEGOS Download Complete CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CM.tar.l... 2014/2/26:18:15:48 Diego DIEGOS Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/2/26:18:16:01 Diego DIEGOS Install Autodesk Material Library 2014 Succeeded 2014/2/26:18:16:02 Diego DIEGOS Download Play CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CMILB.ta... 2014/2/26:18:16:35 Diego DIEGOS Download Complete CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CMILB.ta... 2014/2/26:18:16:35 Diego DIEGOS Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/2/26:18:16:45 Diego DIEGOS Install Autodesk Material Library 2014 - Base Image Library Succeeded 2014/2/26:18:16:45 Diego DIEGOS Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/2/26:18:16:51 Diego DIEGOS Install Autodesk Content Service Succeeded 2014/2/26:18:16:51 Diego DIEGOS Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/2/26:18:16:54 Diego DIEGOS Install Autodesk Content Service Language Pack Succeeded 2014/2/26:18:16:54 Diego DIEGOS Download Play ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64... 2014/2/26:18:20:31 Diego DIEGOS Download Complete ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64... 2014/2/26:18:20:32 Diego DIEGOS Installing Autodesk® AutoCAD® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Diego\AppData\Local\Temp\_AI26FF.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/2/26:18:22:06 Diego DIEGOS Install Autodesk® AutoCAD® 2014 Succeeded 2014/2/26:18:22:06 Diego DIEGOS Download Play ACAD_en-us http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64... 2014/2/26:18:22:50 Diego DIEGOS Download Complete ACAD_en-us http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64... 2014/2/26:18:22:50 Diego DIEGOS Installing AutoCAD® 2014 Language Pack: TRANSFORMS="C:\Users\Diego\AppData\Local\Temp\_AI26FF.tmp\_laCB0F.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/2/26:18:23:12 Diego DIEGOS Install AutoCAD® 2014 Language Pack Succeeded 2014/2/26:18:23:12 Diego DIEGOS Download Skipped ACAD_PSPACK http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64... 2014/2/26:18:23:12 Diego DIEGOS Installing AutoCAD® 2014 Product Specific Pack: INSTALLSHORTCUTS=0 TRANSFORMS="C:\Users\Diego\AppData\Local\Temp\_AI26FF.tmp\_laCB0F.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/2/26:18:23:27 Diego DIEGOS Install AutoCAD® 2014 Product Specific Pack Succeeded 2014/2/26:18:23:27 Diego DIEGOS Download Play ADSYNC http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ADSYNC_x... 2014/2/26:18:25:21 Diego DIEGOS Download Complete ADSYNC http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ADSYNC_x... 2014/2/26:18:25:21 Diego DIEGOS Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/2/26:18:25:57 Diego DIEGOS Install Autodesk Cloud sync Succeeded 2014/2/26:18:25:57 Diego DIEGOS Installing SketchUp Import plug-in: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/2/26:18:26:00 Diego DIEGOS Install SketchUp Import plug-in Succeeded 2014/2/26:18:26:01 Diego DIEGOS Download Play VCREDIST2008SP1X86_6161 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST... 2014/2/26:18:26:03 Diego DIEGOS Download Complete VCREDIST2008SP1X86_6161 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST... 2014/2/26:18:26:03 Diego DIEGOS Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q 2014/2/26:18:26:12 Diego DIEGOS Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Failed Installation aborted, Result=1603 2014/2/26:18:26:13 Diego DIEGOS Rollback SketchUp Import plug-in Succeeded 2014/2/26:18:26:30 Diego DIEGOS Rollback Autodesk Cloud sync Succeeded 2014/2/26:18:26:36 Diego DIEGOS Rollback AutoCAD® 2014 Product Specific Pack Succeeded 2014/2/26:18:26:49 Diego DIEGOS Rollback AutoCAD® 2014 Language Pack Succeeded 2014/2/26:18:27:45 Diego DIEGOS Rollback Autodesk® AutoCAD® 2014 Succeeded 2014/2/26:18:27:48 Diego DIEGOS Rollback Autodesk Content Service Language Pack Succeeded 2014/2/26:18:27:53 Diego DIEGOS Rollback Autodesk Content Service Succeeded 2014/2/26:18:28:06 Diego DIEGOS Rollback Autodesk Material Library 2014 - Base Image Library Succeeded 2014/2/26:18:28:30 Diego DIEGOS Rollback Autodesk Material Library 2014 Succeeded 2014/2/26:18:28:31 Diego DIEGOS Rollback FARO LS 5.1.0.30630 (64bit) Succeeded 2014/2/26:18:28:31 Diego DIEGOS Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2014/2/26:18:28:32 Diego DIEGOS Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2014/2/26:18:28:32 Diego DIEGOS Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
Message 34 of 38
renjirorenz
Hi i am having the same problem and i kinda need to use maya now since i have an assignment due in 3 days and im no where near finished...
Here is my log file:
2014/5/27:12:35:53 User USER-PC === Setup started on USER-PC by User ===
2014/5/27:12:35:53 User USER-PC Path_Length: 151
2014/5/27:12:35:53 User USER-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/5/27:12:35:53 User USER-PC Launch
2014/5/27:12:35:53 User USER-PC CommandLine
2014/5/27:12:35:53 User USER-PC Current Directory C:\Users\User\AppData\Local\Temp\_AI2EFF.tmp
2014/5/27:12:36:24 User USER-PC === Setup ended ===
2014/5/27:12:36:08 User USER-PC === Setup started on USER-PC by User ===
2014/5/27:12:36:08 User USER-PC Path_Length: 151
2014/5/27:12:36:08 User USER-PC Current Directory C:\Users\User\AppData\Local\Temp\_AI2EFF.tmp
2014/5/27:12:36:08 User USER-PC Launch
2014/5/27:12:36:25 User USER-PC PageOpen LaunchDialog
2014/5/27:12:36:31 User USER-PC PageOpen LicenseDialog
2014/5/27:12:36:45 User USER-PC PageOpen ProductInfoDialog
2014/5/27:12:37:27 User USER-PC PageOpen ProductSelectionDialog2
2014/5/27:12:37:33 User USER-PC PageOpen FullProgressDialog
2014/5/27:12:37:33 User USER-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\User\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/5/27:12:39:37 User USER-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2014/5/27:12:39:37 User USER-PC Installing .NET Framework Runtime 4.0 KB2468871: "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe" /q /norestart
2014/5/27:12:51:09 User USER-PC Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
2014/5/27:12:51:16 User USER-PC PageOpen InstallCompleteDialog
2014/5/27:13:51:36 User USER-PC [Error: 1056] An instance of the service is already running.
2014/5/27:13:51:36 User USER-PC === Setup ended ===
2014/5/27:13:56:59 User USER-PC === Setup started on USER-PC by User ===
2014/5/27:13:56:59 User USER-PC Path_Length: 151
2014/5/27:13:56:59 User USER-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/5/27:13:56:59 User USER-PC Launch
2014/5/27:13:56:59 User USER-PC CommandLine
2014/5/27:13:56:59 User USER-PC Current Directory C:\Users\User\AppData\Local\Temp\_AI6F5A.tmp
2014/5/27:13:57:22 User USER-PC === Setup ended ===
2014/5/27:13:57:08 User USER-PC === Setup started on USER-PC by User ===
2014/5/27:13:57:08 User USER-PC Path_Length: 151
2014/5/27:13:57:08 User USER-PC Current Directory C:\Users\User\AppData\Local\Temp\_AI6F5A.tmp
2014/5/27:13:57:08 User USER-PC Launch
2014/5/27:13:57:21 User USER-PC PageOpen LaunchDialog
2014/5/27:14:26:24 User USER-PC PageOpen LicenseDialog
2014/5/27:14:26:35 User USER-PC PageOpen ProductSelectionDialog2
2014/5/27:14:26:43 User USER-PC PageOpen FullProgressDialog
2014/5/27:14:26:44 User USER-PC Installing Network License Manager: INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Maya 2014" SETUP_PACKAGECODE={44FFD99B-4877-4732-AA33-2FD3D7B622D2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Maya_2014_dlm\" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/27:14:26:49 User USER-PC Install Network License Manager Succeeded
2014/5/27:14:26:49 User USER-PC PageOpen InstallCompleteDialog
2014/5/27:14:27:23 User USER-PC === Setup ended ===
2014/5/27:14:32:04 User USER-PC === Setup started on USER-PC by User ===
2014/5/27:14:32:04 User USER-PC Path_Length: 151
2014/5/27:14:32:04 User USER-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/5/27:14:32:04 User USER-PC Launch
2014/5/27:14:32:04 User USER-PC CommandLine
2014/5/27:14:32:04 User USER-PC Current Directory C:\Users\User\AppData\Local\Temp\_AI8D46.tmp
2014/5/27:14:32:30 User USER-PC === Setup ended ===
2014/5/27:14:32:22 User USER-PC === Setup started on USER-PC by User ===
2014/5/27:14:32:22 User USER-PC Path_Length: 151
2014/5/27:14:32:22 User USER-PC Current Directory C:\Users\User\AppData\Local\Temp\_AI8D46.tmp
2014/5/27:14:32:22 User USER-PC Launch
2014/5/27:14:32:29 User USER-PC PageOpen LaunchDialog
2014/5/27:14:35:12 User USER-PC PageOpen LicenseDialog
2014/5/27:14:35:21 User USER-PC PageOpen ProductInfoDialog
2014/5/27:14:36:52 User USER-PC PageOpen ProductSelectionDialog2
2014/5/27:14:37:06 User USER-PC PageOpen FullProgressDialog
2014/5/27:14:37:06 User USER-PC Installing .NET Framework Runtime 4.0 KB2468871: "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe" /q /norestart
2014/5/27:14:43:53 User USER-PC Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
2014/5/27:14:43:54 User USER-PC PageOpen InstallCompleteDialog
2014/5/27:16:30:12 User USER-PC === Setup ended ===
2014/5/29:13:20:43 User USER-PC === Setup started on USER-PC by User ===
2014/5/29:13:20:43 User USER-PC Path_Length: 151
2014/5/29:13:20:43 User USER-PC Current Directory C:\Users\User\Desktop\Autodesk_Maya_2014_dlm
2014/5/29:13:20:43 User USER-PC Launch
2014/5/29:13:20:43 User USER-PC CommandLine
2014/5/29:13:20:43 User USER-PC Current Directory C:\Users\User\AppData\Local\Temp\_AIE295.tmp
2014/5/29:13:21:18 User USER-PC === Setup ended ===
2014/5/29:13:20:56 User USER-PC === Setup started on USER-PC by User ===
2014/5/29:13:20:56 User USER-PC Path_Length: 151
2014/5/29:13:20:56 User USER-PC Current Directory C:\Users\User\AppData\Local\Temp\_AIE295.tmp
2014/5/29:13:20:56 User USER-PC Launch
2014/5/29:13:21:12 User USER-PC PageOpen LaunchDialog
2014/5/29:13:21:17 User USER-PC PageOpen LicenseDialog
2014/5/29:13:21:22 User USER-PC PageOpen ProductInfoDialog
2014/5/29:13:22:51 User USER-PC PageOpen ProductSelectionDialog2
2014/5/29:13:23:43 User USER-PC PageOpen FullProgressDialog
2014/5/29:13:23:43 User USER-PC Installing .NET Framework Runtime 4.0 KB2468871: "C:\Users\User\Desktop\Autodesk_Maya_2014_dlm\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe" /q /norestart
2014/5/29:13:30:34 User USER-PC Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
2014/5/29:13:30:38 User USER-PC PageOpen InstallCompleteDialog
2014/5/29:13:34:37 User USER-PC [Error: 1056] An instance of the service is already running.
2014/5/29:13:34:37 User USER-PC === Setup ended ===
2014/5/29:13:46:54 User USER-PC === Setup started on USER-PC by User ===
2014/5/29:13:46:54 User USER-PC Path_Length: 151
2014/5/29:13:46:54 User USER-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/5/29:13:46:54 User USER-PC Launch
2014/5/29:13:46:54 User USER-PC CommandLine
2014/5/29:13:46:54 User USER-PC Current Directory C:\Users\User\AppData\Local\Temp\_AIDC7E.tmp
2014/5/29:13:47:27 User USER-PC === Setup ended ===
2014/5/29:13:47:14 User USER-PC === Setup started on USER-PC by User ===
2014/5/29:13:47:14 User USER-PC Path_Length: 151
2014/5/29:13:47:14 User USER-PC Current Directory C:\Users\User\AppData\Local\Temp\_AIDC7E.tmp
2014/5/29:13:47:14 User USER-PC Launch
2014/5/29:13:47:25 User USER-PC PageOpen LaunchDialog
2014/5/29:13:47:29 User USER-PC PageOpen LicenseDialog
2014/5/29:13:47:32 User USER-PC PageOpen ProductInfoDialog
2014/5/29:13:48:04 User USER-PC PageOpen ProductSelectionDialog2
2014/5/29:13:48:07 User USER-PC PageOpen FullProgressDialog
2014/5/29:13:48:07 User USER-PC Installing .NET Framework Runtime 4.0 KB2468871: "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe" /q /norestart
2014/5/29:13:53:20 User USER-PC Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
i hope you can help me fix this problem quickly 🙂
Message 35 of 38
DMnba
in reply to: renjirorenz
.Net Framework isn't my issue.  Instead, my install errors out after uninstalling the Visual C++ 2008 SP1 Resdistributable (x64) regardless of the fact that I uninstalled both the (x64) and (x86) prior to setup.  I'm running VMware Fusion on my mac to piggyback this Windows 7.  Here's the Error Log info.
ANY HELP, PLEASE?!
2014/8/8:15:38:53 mccormickd MACBOOKPRO1 Launch
2014/8/8:15:38:59 mccormickd MACBOOKPRO1 PageOpen LaunchDialog
2014/8/8:15:39:02 mccormickd MACBOOKPRO1 PageOpen LicenseDialog
2014/8/8:15:39:05 mccormickd MACBOOKPRO1 PageOpen ProductInfoDialog
2014/8/8:15:39:32 mccormickd MACBOOKPRO1 PageOpen ProductSelectionDialog2
2014/8/8:15:40:06 mccormickd MACBOOKPRO1 PageOpen FullProgressDialog
2014/8/8:15:40:06 mccormickd MACBOOKPRO1 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): \\spruce\INSTALL\AutoCAD2013\AutoCAD_2013_English_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2014/8/8:15:40:12 mccormickd MACBOOKPRO1 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/8/8:15:40:12 mccormickd MACBOOKPRO1 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): \\spruce\INSTALL\AutoCAD2013\AutoCAD_2013_English_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2014/8/8:15:40:16 mccormickd MACBOOKPRO1 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
Message 36 of 38
mclawson
my hard drive crashed and i need to re install autocad 2013 need help
Message 37 of 38
Mark.Lancaster
in reply to: mclawson
Do you still have your installation media?   If not..
Autodesk only maintains the current released product year and 3 legacy versions.  Legacy versions that are older than this guideline are considered obsoleted and no longer supported by Autodesk and thus there's no "live" download for these releases.  Please see this article for additional information.
Mark Lancaster
Message 38 of 38
mclawson
in reply to: Mark.Lancaster
It was a very rough experience. Autodesk is not the same company I remember from 20 years ago. No one had records of my $3000 purchase of Autocad 2013. Finally after couple of days of pulling my hair out they gave me the manager of my license. He had no record of my purchase either. Had to prove it to him. Purchased it 10/28/2015 from Not To Old To Be Sold now Vintage Software. Called three times and no one would talk to me so i could explain my problem. Finally after 10 emails I finally got a email with an access code and the words that my license was already active.
My hard drive crashed and had to reinstall on the new one and needless to say the experience was brutal and it should not be the customer, every customer comes first. Autodesk has become a behemeth mess.
Administrator Productivity
