Installation & Licensing
New Member
ameinking
Message 1 of 35 (28,439 Views)
Installation Failure AutoCAD 2013
28439 Views, 34 Replies
07-13-2012 11:52 AM
I have tried numerous times to install AutoCAD 2013 and it gets to the end it says INSTALLATION COMPLETE SOME PRODUCTS FAILED TO INSTALL and NOTHING has installed.PLEASE HELP I have homework due!
Yours is easy.
Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/3382347
Good Luck!
New Member
Gavin53
Message 2 of 35 (28,430 Views)
Re: Installation Failure AutoCAD 2013
07-13-2012 01:31 PM in reply to: ameinking
I had same problem with 2012, what's happening is you probably have a newer version of some required M$ component such as "Microsoft Visual C++ 2010 Redistributable". I has version 10.4.xxx Autodesk wanted 10.3.xxx but Windoze doesn't allow installing older version only newer. When this failed everything stops.
Autodesk installer should catch this and use the newer version or if M$ has their DLLs so screwed up that they can't use 10.4 instead of 10.3 at least report the error somewhere besides the installation log file wher I found it.
Work around:
Uninstall Microsoft Visual C++ 2010 Redistributable, and or Microsoft Visual C++ 2005 Redistributable (from the control panel) as needed and then AutoCAD will install. I don't know if it breaks if you then update your redist back to the latest and grat(ing)est version.
Good luck!
TravisNave
Message 3 of 35 (28,406 Views)
07-16-2012 10:10 AM in reply to: ameinking
Please include your installation log file and it should have more information on the reason for installation failure.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
maddielu
Message 4 of 35 (28,389 Views)
07-16-2012 12:46 PM in reply to: ameinking
I'm also having trouble installing AutoCAD 2013 on my computer. I'm running Windows 7 Pro 64-bit and I receive the following in the installation log file:
2012/7/16:15:28:16 maddie BURTON_FEELGOOD === Setup started on BURTON_FEELGOOD by maddie ===
2012/7/16:15:28:16 maddie BURTON_FEELGOOD Launch
2012/7/16:15:28:18 maddie BURTON_FEELGOOD PageOpen LaunchDialog
2012/7/16:15:29:40 maddie BURTON_FEELGOOD PageOpen LicenseDialog
2012/7/16:15:29:43 maddie BURTON_FEELGOOD PageOpen ProductInfoDialog
2012/7/16:15:30:12 maddie BURTON_FEELGOOD PageOpen ProductSelectionDialog2
2012/7/16:15:30:22 maddie BURTON_FEELGOOD PageOpen FullProgressDialog
2012/7/16:15:30:22 maddie BURTON_FEELGOOD Installing DirectX Runtime: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/7/16:15:31:03 maddie BURTON_FEELGOOD Install DirectX Runtime Succeeded
2012/7/16:15:31:03 maddie BURTON_FEELGOOD Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/16:15:31:26 maddie BURTON_FEELGOOD Install FaroSDK Succeeded
2012/7/16:15:31:26 maddie BURTON_FEELGOOD Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/16:15:31:50 maddie BURTON_FEELGOOD Install Autodesk Material Library 2013 Succeeded
2012/7/16:15:31:50 maddie BURTON_FEELGOOD Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/16:15:32:03 maddie BURTON_FEELGOOD Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/7/16:15:32:03 maddie BURTON_FEELGOOD Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/16:15:32:14 maddie BURTON_FEELGOOD Install Autodesk Content Service Succeeded
2012/7/16:15:32:14 maddie BURTON_FEELGOOD Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/16:15:32:22 maddie BURTON_FEELGOOD Install Autodesk Content Service Language Pack Succeeded
2012/7/16:15:32:23 maddie BURTON_FEELGOOD Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\maddie\AppData\Local\Temp\_AIBA2B.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/16:15:36:12 maddie BURTON_FEELGOOD Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/7/16:15:36:17 maddie BURTON_FEELGOOD Rollback Autodesk Content Service Language Pack Succeeded
2012/7/16:15:36:23 maddie BURTON_FEELGOOD Rollback Autodesk Content Service Succeeded
2012/7/16:15:36:32 maddie BURTON_FEELGOOD Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/7/16:15:36:47 maddie BURTON_FEELGOOD Rollback Autodesk Material Library 2013 Succeeded
2012/7/16:15:36:50 maddie BURTON_FEELGOOD Rollback FaroSDK Succeeded
2012/7/16:15:36:50 maddie BURTON_FEELGOOD Rollback DirectX Runtime Failed Failure is ignored, Result=1619
New Member
Com-Ex
Message 5 of 35 (28,358 Views)
07-17-2012 12:30 PM in reply to: maddielu
I too am having installation failures.  Installation log attached.  Need to get this up and running ASAP, so TIA for any help!
TravisNave
Message 6 of 35 (28,346 Views)
07-17-2012 01:38 PM in reply to: Com-Ex
Yours is easy.
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
New Member
maddielu
Message 7 of 35 (28,335 Views)
07-17-2012 05:44 PM in reply to: TravisNave
I uninstalled the C++ Redistributable and the .NET Runtime 4.0 and I'm still getting the following failed installation log:
2012/7/17:20:29:10 maddie BURTON_FEELGOOD === Setup started on BURTON_FEELGOOD by maddie ===
2012/7/17:20:29:10 maddie BURTON_FEELGOOD Launch
2012/7/17:20:29:22 maddie BURTON_FEELGOOD PageOpen LaunchDialog
2012/7/17:20:29:26 maddie BURTON_FEELGOOD PageOpen LicenseDialog
2012/7/17:20:29:28 maddie BURTON_FEELGOOD PageOpen ProductInfoDialog
2012/7/17:20:29:38 maddie BURTON_FEELGOOD PageOpen ProductSelectionDialog2
2012/7/17:20:29:44 maddie BURTON_FEELGOOD PageOpen FullProgressDialog
2012/7/17:20:29:44 maddie BURTON_FEELGOOD Installing .NET Framework Runtime 4.0: C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/7/17:20:31:54 maddie BURTON_FEELGOOD Install .NET Framework Runtime 4.0 Succeeded
2012/7/17:20:31:54 maddie BURTON_FEELGOOD Installing .NET Framework Runtime 4.0 KB2468871: C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2012/7/17:20:34:57 maddie BURTON_FEELGOOD Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2012/7/17:20:34:57 maddie BURTON_FEELGOOD Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\maddie\AppData\Local\Temp\vcredist_x86_2010.log
2012/7/17:20:35:05 maddie BURTON_FEELGOOD Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/7/17:20:35:05 maddie BURTON_FEELGOOD Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\maddie\AppData\Local\Temp\vcredist_x64_2010.log
2012/7/17:20:35:14 maddie BURTON_FEELGOOD Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2012/7/17:20:35:14 maddie BURTON_FEELGOOD Installing DirectX Runtime: C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/7/17:20:36:06 maddie BURTON_FEELGOOD Install DirectX Runtime Succeeded
2012/7/17:20:36:06 maddie BURTON_FEELGOOD Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/17:20:36:29 maddie BURTON_FEELGOOD Install FaroSDK Succeeded
2012/7/17:20:36:29 maddie BURTON_FEELGOOD Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/17:20:37:09 maddie BURTON_FEELGOOD Install Autodesk Material Library 2013 Succeeded
2012/7/17:20:37:09 maddie BURTON_FEELGOOD Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/17:20:37:24 maddie BURTON_FEELGOOD Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/7/17:20:37:24 maddie BURTON_FEELGOOD Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/17:20:37:41 maddie BURTON_FEELGOOD Install Autodesk Content Service Succeeded
2012/7/17:20:37:41 maddie BURTON_FEELGOOD Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/17:20:37:49 maddie BURTON_FEELGOOD Install Autodesk Content Service Language Pack Succeeded
2012/7/17:20:37:49 maddie BURTON_FEELGOOD Installing AutoCAD® 2013: TRANSFORMS="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\maddie\AppData\Local\Temp\_AIB901.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/17:20:41:46 maddie BURTON_FEELGOOD Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/7/17:20:41:52 maddie BURTON_FEELGOOD Rollback Autodesk Content Service Language Pack Succeeded
2012/7/17:20:41:57 maddie BURTON_FEELGOOD Rollback Autodesk Content Service Succeeded
2012/7/17:20:42:09 maddie BURTON_FEELGOOD Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/7/17:20:42:26 maddie BURTON_FEELGOOD Rollback Autodesk Material Library 2013 Succeeded
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback FaroSDK Succeeded
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1619
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
New Member
thecrackmaster
Message 8 of 35 (25,754 Views)
11-20-2012 01:53 PM in reply to: Gavin53
you're a saver. works for me now.
i just registered to say thanks!
New Member
staaldraad
Message 9 of 35 (25,017 Views)
12-01-2012 01:01 AM in reply to: ameinking
Can someone please help me. I'm having the same issue!
My Log file:
2012/12/1:10:52:41    johannes.burger    JC_B1    PageOpen    InstallCompleteDialog
2012/12/1:10:54:12    johannes.burger    JC_B1    === Setup ended ===
2012/12/1:10:54:19    johannes.burger    JC_B1    === Setup started on JC_B1 by johannes.burger ===
2012/12/1:10:54:19    johannes.burger    JC_B1    Launch
2012/12/1:10:54:27    johannes.burger    JC_B1    === Setup ended ===
2012/12/1:10:54:27    johannes.burger    JC_B1    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/12/1:10:54:27    johannes.burger    JC_B1    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/12/1:10:54:27    johannes.burger    JC_B1    PageOpen    LaunchDialog
2012/12/1:10:56:50    johannes.burger    JC_B1    PageOpen    LicenseDialog
2012/12/1:10:56:53    johannes.burger    JC_B1    PageOpen    ProductInfoDialog
2012/12/1:10:57:17    johannes.burger    JC_B1    PageOpen    ProductSelectionDialog2
2012/12/1:10:57:42    johannes.burger    JC_B1    PageOpen    FullProgressDialog
2012/12/1:10:57:42    johannes.burger    JC_B1    Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/1:10:58:41    johannes.burger    JC_B1    Install    DirectX® Runtime    Succeeded
2012/12/1:10:58:41    johannes.burger    JC_B1    Installing AutoCAD® 2013:  TRANSFORMS="E:\x64\en-us\acad\acad.mst;C:\Users\JOHANN~1.BUR\AppData\Local\Temp\_AI25B9.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/1:11:00:09    johannes.burger    JC_B1    Install    AutoCAD® 2013    Failed    Installation aborted, Result=1603
2012/12/1:11:00:09    johannes.burger    JC_B1    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
New Member
Terenceng
Message 10 of 35 (24,355 Views)
12-11-2012 07:09 AM in reply to: ameinking
I am facing this probelm loading Acad 2013...
2012/12/11:22:30:44    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:30:44    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:31:52    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:31:18    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:31:18    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:31:45    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:22:32:12    GB-Terence    TERENCENOTEBOOK    PageOpen    LicenseDialog
2012/12/11:22:32:29    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductInfoDialog
2012/12/11:22:33:11    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductSelectionDialog2
2012/12/11:22:33:16    GB-Terence    TERENCENOTEBOOK    PageOpen    FullProgressDialog
2012/12/11:22:33:17    GB-Terence    TERENCENOTEBOOK    Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2012/12/11:22:33:29    GB-Terence    TERENCENOTEBOOK    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
2012/12/11:22:34:04    GB-Terence    TERENCENOTEBOOK    PageOpen    InstallCompleteDialog
2012/12/11:22:34:45    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:35:52    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:35:52    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:36:00    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:35:55    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:35:55    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:35:57    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:22:36:17    GB-Terence    TERENCENOTEBOOK    PageOpen    BeginDeploymentDialog
2012/12/11:22:36:30    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:22:36:38    GB-Terence    TERENCENOTEBOOK    PageOpen    LicenseDialog
2012/12/11:22:36:38    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductSelectionDialog2
2012/12/11:22:36:52    GB-Terence    TERENCENOTEBOOK    PageOpen    FullProgressDialog
2012/12/11:22:36:52    GB-Terence    TERENCENOTEBOOK    Installing Network License Manager:  ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_AI24DD.tmp\Media.mst"
 2012/12/11:22:36:54    GB-Terence    TERENCENOTEBOOK    Install    Network License Manager    Succeeded
2012/12/11:22:36:54    GB-Terence    TERENCENOTEBOOK    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\GB-TER~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/11:22:37:04    GB-Terence    TERENCENOTEBOOK    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2012/12/11:22:37:04    GB-Terence    TERENCENOTEBOOK    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): E:\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\GB-TER~1\AppData\Local\Temp\vcredist_x64_2010.log
2012/12/11:22:37:10    GB-Terence    TERENCENOTEBOOK    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Succeeded
2012/12/11:22:37:10    GB-Terence    TERENCENOTEBOOK    Installing Autodesk CAD Manager Tools:   INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_AI24DD.tmp\Media.mst"
 2012/12/11:22:37:16    GB-Terence    TERENCENOTEBOOK    Install    Autodesk CAD Manager Tools    Succeeded
2012/12/11:22:37:16    GB-Terence    TERENCENOTEBOOK    Installing Autodesk Content Service:  TRANSFORMS="E:\x64\en-us\Tools\snap\ContentService.mst;C:\Users\GB-TER~1\AppData\Local\Temp\_AI24DD.tmp\x64\Tools\snap\ContentService-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/11:22:37:30    GB-Terence    TERENCENOTEBOOK    Install    Autodesk Content Service    Succeeded
2012/12/11:22:37:32    GB-Terence    TERENCENOTEBOOK    Installing Autodesk Content Service Language Pack:  TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_AI24DD.tmp\_laA6B0.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/11:22:37:35    GB-Terence    TERENCENOTEBOOK    Install    Autodesk Content Service Language Pack    Succeeded
2012/12/11:22:37:36    GB-Terence    TERENCENOTEBOOK    PageOpen    InstallCompleteDialog
2012/12/11:22:37:39    GB-Terence    TERENCENOTEBOOK    [Error: 1056] An instance of the service is already running.
2012/12/11:22:37:39    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:37:52    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:37:52    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:37:59    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:37:54    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:37:54    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:37:57    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:22:38:00    GB-Terence    TERENCENOTEBOOK    PageOpen    LicenseDialog
2012/12/11:22:38:08    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductInfoDialog
2012/12/11:22:38:24    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductSelectionDialog2
2012/12/11:22:38:31    GB-Terence    TERENCENOTEBOOK    PageOpen    FullProgressDialog
2012/12/11:22:38:31    GB-Terence    TERENCENOTEBOOK    Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_AIF865.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/11:22:40:26    GB-Terence    TERENCENOTEBOOK    Install    Autodesk® Design Review 2013    Succeeded
2012/12/11:22:40:26    GB-Terence    TERENCENOTEBOOK    Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2012/12/11:22:40:34    GB-Terence    TERENCENOTEBOOK    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
2012/12/11:22:40:42    GB-Terence    TERENCENOTEBOOK    Rollback    Autodesk® Design Review 2013    Succeeded
2012/12/11:22:40:42    GB-Terence    TERENCENOTEBOOK    PageOpen    InstallCompleteDialog
2012/12/11:22:42:42    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:49:44    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:49:44    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:49:51    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:49:47    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:49:47    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:49:49    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:22:49:54    GB-Terence    TERENCENOTEBOOK    PageOpen    LicenseDialog
2012/12/11:22:49:54    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductSelectionDialog2
2012/12/11:22:50:00    GB-Terence    TERENCENOTEBOOK    PageOpen    FullProgressDialog
2012/12/11:22:50:00    GB-Terence    TERENCENOTEBOOK    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\GB-TER~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/11:22:50:06    GB-Terence    TERENCENOTEBOOK    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2012/12/11:22:50:06    GB-Terence    TERENCENOTEBOOK    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): E:\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\GB-TER~1\AppData\Local\Temp\vcredist_x64_2010.log
2012/12/11:22:50:13    GB-Terence    TERENCENOTEBOOK    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Succeeded
2012/12/11:22:50:13    GB-Terence    TERENCENOTEBOOK    Installing Autodesk CAD Manager Tools:   INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_AID557.tmp\Media.mst"
 2012/12/11:22:50:15    GB-Terence    TERENCENOTEBOOK    Install    Autodesk CAD Manager Tools    Succeeded
2012/12/11:22:50:15    GB-Terence    TERENCENOTEBOOK    PageOpen    InstallCompleteDialog
2012/12/11:22:50:17    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:50:30    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:50:30    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:50:37    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:50:32    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:50:32    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:50:35    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:22:50:42    GB-Terence    TERENCENOTEBOOK    PageOpen    LicenseDialog
2012/12/11:22:50:53    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductInfoDialog
2012/12/11:22:51:12    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductSelectionDialog2
2012/12/11:22:51:25    GB-Terence    TERENCENOTEBOOK    PageOpen    FullProgressDialog
2012/12/11:22:51:25    GB-Terence    TERENCENOTEBOOK    Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_AI89E1.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/11:22:51:41    GB-Terence    TERENCENOTEBOOK    Install    Autodesk® Design Review 2013    Succeeded
2012/12/11:22:51:41    GB-Terence    TERENCENOTEBOOK    Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2012/12/11:22:51:51    GB-Terence    TERENCENOTEBOOK    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
2012/12/11:22:51:58    GB-Terence    TERENCENOTEBOOK    Rollback    Autodesk® Design Review 2013    Succeeded
2012/12/11:22:52:06    GB-Terence    TERENCENOTEBOOK    PageOpen    InstallCompleteDialog
2012/12/11:22:52:15    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:23:00:35    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:23:00:35    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:23:00:42    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:23:00:37    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:23:00:37    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:23:00:40    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:23:01:26    GB-Terence    TERENCENOTEBOOK    PageOpen    LicenseDialog
2012/12/11:23:01:42    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductInfoDialog
2012/12/11:23:01:55    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductSelectionDialog2
2012/12/11:23:02:05    GB-Terence    TERENCENOTEBOOK    PageOpen    FullProgressDialog
2012/12/11:23:02:05    GB-Terence    TERENCENOTEBOOK    Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2012/12/11:23:02:27    GB-Terence    TERENCENOTEBOOK    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
