Installation & Licensing
Message 1 of 9
lopes.aurelie
2495 Views, 8 Replies
Installation Failed
Hello everybody,
I'm a big problem, I can't installed 3DS Max 2013 (French 64bits student version) on my computer!
And the error log :
2012/5/24:15:41:17 Aurélie AURELIE === Setup started on AURELIE by Aurélie ===
2012/5/24:15:41:17 Aurélie AURELIE Launch
2012/5/24:15:41:18 Aurélie AURELIE PageOpen LaunchDialog
2012/5/24:15:41:19 Aurélie AURELIE PageOpen LicenseDialog
2012/5/24:15:41:22 Aurélie AURELIE PageOpen ProductInfoDialog
2012/5/24:15:41:45 Aurélie AURELIE PageOpen ProductSelectionDialog2
2012/5/24:15:43:01 Aurélie AURELIE PageOpen FullProgressDialog
2012/5/24:15:43:01 Aurélie AURELIE Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/5/24:15:43:40 Aurélie AURELIE Install DirectX® Runtime Succeeded
2012/5/24:15:43:40 Aurélie AURELIE Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=fr-fr ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/24:15:43:48 Aurélie AURELIE Install Autodesk Material Library 2013 Succeeded
2012/5/24:15:43:48 Aurélie AURELIE Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=fr-fr ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/24:15:43:53 Aurélie AURELIE Install Autodesk Material Library 2013 - Base Image Library Succeeded
2012/5/24:15:43:53 Aurélie AURELIE Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=fr-fr ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/24:15:44:05 Aurélie AURELIE Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2012/5/24:15:44:06 Aurélie AURELIE Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\AURLIE~1\AppData\Local\Temp\_AICC63.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=fr-fr ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/24:15:44:15 Aurélie AURELIE Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2012/5/24:15:44:22 Aurélie AURELIE Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2012/5/24:15:44:32 Aurélie AURELIE Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2012/5/24:15:44:47 Aurélie AURELIE Rollback Autodesk Material Library 2013 Succeeded
2012/5/24:15:44:47 Aurélie AURELIE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
But, DirectX is already installed on my computer, and C++ so!
If anyone can help me!
Thanks (& Sorry for me english, I'm french people).
8 REPLIES 8
Message 2 of 9
in reply to: lopes.aurelie
Nobody has respsonded to this thread. I am having this same exact issue. Can anyone out there help please?
Message 3 of 9
I am also experiencing the same issues. Autodesk Support Staff, are you out there?!
Message 4 of 9
And just for future reference, my previous 3ds Max version (2012) also did not work, but Maya 2012 did for some reason. One worked, one didnt, vice versa. So instead of going through the hassle to get it fixed I ended up buying a student version instead of upgrading for free to press my luck. I tried uninstalling the past versions 2010,2011, and 2012 for Maxm but yet they will all not uninstall. Whats the best solution? Reboot the computer?
   Louie
P.S. If anyone wants to use Teamviewer on my compute, feel free. This is all on a Windows desktop.
Message 5 of 9
UP! UP!
Can you reply please Autodesk Support Staff?
Message 6 of 9
Hi lopes.aurelie,
Have a look at this thread and see if the solutions there solve your installation issue please (the products are difrerent but the resolution should be the same).
Let us know!
Camilo Lemos
Message 7 of 9
Hi! Camilo.Lemos
I had seen this solutions but they don't solve my installation issue.
I use Windows 7 home premium and maybe 3DS Max is incompatible with him?
Thanks for your reply!
Message 8 of 9
UP!
Message 9 of 9
WTH is "UP!" ??
Administrator Productivity
