Hi
I've tried everything I can find in the guides and support and even teh youtube-video about NET.-frameworks. Still can't install the program. The installation proceeds as aspected and keeps going for a few minutes (with all my other programs shut down) and when it's done I get the message that following programs failed to install.
In the log file this is what i get:
2011/10/10:20:59:45ErikLIFEABUSER=== Setup started on LIFEABUSER by Erik ===
2011/10/10:20:59:45ErikLIFEABUSERLaunch 2011/10/10:20:59:56ErikLIFEABUSER=== Setup ended ===
2011/10/10:20:59:45ErikLIFEABUSERLaunch 2011/10/10:20:59:55ErikLIFEABUSERPageOpenLaunchDialog
2011/10/10:21:01:12ErikLIFEABUSERPageOpenLicenseDialog2011/10/10:21:01:17ErikLIFEABUSERPageOpenProductInfoDialog
2011/10/10:21:07:35ErikLIFEABUSERPageOpenProductSelectionDialog2
2011/10/10:21:07:54ErikLIFEABUSERPageOpenFullProgressDialog
2011/10/10:21:07:54ErikLIFEABUSERInstalling Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Erik\AppData\Local\Temp\vcredist_x86_2010.log2011/10/10:21:07:56ErikLIFEABUSERInstallMicrosoft Visual C++ 2010 Redistributable (x86)FailedInstallation aborted, Result=1603
Please help me. Need this for my schoolwork.
Edit: Added a print screen of the message as well.
Solved by ersj0017. Go to Solution.
