Installation & Licensing
Installation failed for Maya 2015 Windows 64-bit
2 REPLIES 2
1948 Views, 2 Replies
I was attempting to install (Maya 2015 - WIN 64 - EN) on a Windows 8.1 device but it stated that it failed.
Here is the instillation log file (see below).  I'm not sure what is going on.
Any help would be appreciated; thank you for your time. Smiley Happy
2014/5/15:22:27:30 Shepherd ATLANTIS === Setup started on ATLANTIS by Shepherd ===
2014/5/15:22:27:30 Shepherd ATLANTIS Path_Length: 143
2014/5/15:22:27:30 Shepherd ATLANTIS Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/5/15:22:27:30 Shepherd ATLANTIS Launch
2014/5/15:22:27:30 Shepherd ATLANTIS CommandLine
2014/5/15:22:27:30 Shepherd ATLANTIS Current Directory C:\Users\Shepherd\AppData\Local\Temp\_AID442.tmp
2014/5/15:22:31:49 Shepherd ATLANTIS === Setup ended ===
2014/5/15:22:27:31 Shepherd ATLANTIS === Setup started on ATLANTIS by Shepherd ===
2014/5/15:22:27:31 Shepherd ATLANTIS Path_Length: 143
2014/5/15:22:27:31 Shepherd ATLANTIS Current Directory C:\Users\Shepherd\AppData\Local\Temp\_AID442.tmp
2014/5/15:22:27:31 Shepherd ATLANTIS Launch
2014/5/15:22:31:50 Shepherd ATLANTIS === Setup ended ===
2014/5/15:22:34:37 Shepherd ATLANTIS === Setup started on ATLANTIS by Shepherd ===
2014/5/15:22:34:37 Shepherd ATLANTIS Path_Length: 143
2014/5/15:22:34:37 Shepherd ATLANTIS Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/5/15:22:34:37 Shepherd ATLANTIS Launch
2014/5/15:22:34:37 Shepherd ATLANTIS CommandLine /URL "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /skipPI /SN 900-47300411 /PK 657G1 /akamai
2014/5/15:22:34:37 Shepherd ATLANTIS Current Directory C:\Users\Shepherd\AppData\Local\Temp\_AI820C.tmp
2014/5/15:22:36:03 Shepherd ATLANTIS === Setup ended ===
2014/5/15:22:35:04 Shepherd ATLANTIS === Setup started on ATLANTIS by Shepherd ===
2014/5/15:22:35:04 Shepherd ATLANTIS Path_Length: 143
2014/5/15:22:35:04 Shepherd ATLANTIS Current Directory C:\Users\Shepherd\AppData\Local\Temp\_AI820C.tmp
2014/5/15:22:35:04 Shepherd ATLANTIS Launch
2014/5/15:22:35:06 Shepherd ATLANTIS Download Error Network is disconnected SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/5/15:22:35:06 Shepherd ATLANTIS Error downloading. Please Install Now again from the Autodesk website. 2014/5/15:22:37:15 Shepherd ATLANTIS [Error: 1056] An instance of the service is already running.
2014/5/15:22:37:15 Shepherd ATLANTIS === Setup ended ===
2014/5/15:22:53:32 Shepherd ATLANTIS === Setup started on ATLANTIS by Shepherd ===
2014/5/15:22:53:32 Shepherd ATLANTIS Path_Length: 143
2014/5/15:22:53:32 Shepherd ATLANTIS Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/5/15:22:53:32 Shepherd ATLANTIS Launch
2014/5/15:22:53:32 Shepherd ATLANTIS CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-47300411 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/5/15:22:53:32 Shepherd ATLANTIS Current Directory C:\Users\Shepherd\AppData\Local\Temp\_AICD1C.tmp
2014/5/15:22:53:42 Shepherd ATLANTIS === Setup ended ===
2014/5/15:22:53:35 Shepherd ATLANTIS === Setup started on ATLANTIS by Shepherd ===
2014/5/15:22:53:35 Shepherd ATLANTIS Path_Length: 143
2014/5/15:22:53:35 Shepherd ATLANTIS Current Directory C:\Users\Shepherd\AppData\Local\Temp\_AICD1C.tmp
2014/5/15:22:53:35 Shepherd ATLANTIS Launch
2014/5/15:22:53:36 Shepherd ATLANTIS Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/5/15:22:53:42 Shepherd ATLANTIS PageOpen LaunchDialog
2014/5/15:22:54:12 Shepherd ATLANTIS PageOpen LicenseDialog
2014/5/15:22:54:12 Shepherd ATLANTIS PageOpen ProductInfoDialog
2014/5/15:22:54:12 Shepherd ATLANTIS PageOpen ProductSelectionDialog2
2014/5/15:22:54:16 Shepherd ATLANTIS PageOpen FullProgressDialog
2014/5/15:22:54:16 Shepherd ATLANTIS Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/5/15:22:54:16 Shepherd ATLANTIS Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/5/15:22:54:27 Shepherd ATLANTIS Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/5/15:22:54:27 Shepherd ATLANTIS Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/5/15:22:54:27 Shepherd ATLANTIS Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/5/15:22:54:27 Shepherd ATLANTIS Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/5/15:22:54:27 Shepherd ATLANTIS Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/5/15:22:54:27 Shepherd ATLANTIS Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/5/15:22:54:44 Shepherd ATLANTIS Install DirectX® Runtime Succeeded
2014/5/15:22:54:44 Shepherd ATLANTIS Download Play MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/5/15:23:02:09 Shepherd ATLANTIS Download Aborted MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/5/15:23:02:09 Shepherd ATLANTIS Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/5/15:23:02:09 Shepherd ATLANTIS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/5/15:23:02:09 Shepherd ATLANTIS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/5/15:23:02:10 Shepherd ATLANTIS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2 REPLIES 2
emily.xu
Hi
The installation failed when trying to download Maya, you must use 'Install Now', maybe there is internet disconnection during the installation. I recommend to download the installation files to your local harddisk by our Virtual Agent, and then install from local.
Emily Xu
Product Support
jjallman
in reply to: emily.xu
I also failed to download Maya. I would like to point out that I have Mcafee which is godawful at playing nice with other programs. But I disabled the firewall and real-time scanning though. And it still didn't work. I tried the "download now" option and it started downloading. But it canceled out upon completion. Actually installing and running maya should not be a problem since i have mudbox 2015 already installed (i copied the install file from another computer using a flashdrive). Downloading at home and school results in the same thing so i'm not inclined to believe that it's an internet problem. especially since a classmate managed to download the mac version of maya right next to me.  Here are the logs from the "install now" option(well it's attached)
Administrator Productivity
