Installation & Licensing
Installation Fail for Inventor 2014
1 REPLY 1
joshf2012
270 Views, 1 Reply
I have tried to install Autodesk Inventor 2014 (64-bit) student download multiple times. Each time it gets to "Install Autodesk Material Library 2014 - Low Image Library" it fails. How can I fix this to install Inventor to my computer. I am running on a 64-bit Windows 8.1.
The installation log:
JOSHF-PC === Setup started on JOSHF-PC by Josh ===
2015/1/16:19:53:58 Josh JOSHF-PC Path_Length: 182
2015/1/16:19:53:58 Josh JOSHF-PC Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2015/1/16:19:53:58 Josh JOSHF-PC Launch
2015/1/16:19:53:58 Josh JOSHF-PC CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_Set... /SN 900-46382598 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2015/1/16:19:53:58 Josh JOSHF-PC Current Directory C:\Users\Josh\AppData\Local\Temp\_AI9095.tmp
2015/1/16:19:54:58 Josh JOSHF-PC === Setup ended ===
2015/1/16:19:54:00 Josh JOSHF-PC === Setup started on JOSHF-PC by Josh ===
2015/1/16:19:54:00 Josh JOSHF-PC Path_Length: 182
2015/1/16:19:54:00 Josh JOSHF-PC Current Directory C:\Users\Josh\AppData\Local\Temp\_AI9095.tmp
2015/1/16:19:54:00 Josh JOSHF-PC Launch
2015/1/16:19:54:03 Josh JOSHF-PC Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2015/1/16:19:54:57 Josh JOSHF-PC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2015/1/16:19:54:57 Josh JOSHF-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Josh\AppData\Local\Temp\_AI9095.tmp\Setup\InventorUI.dll
2015/1/16:19:54:57 Josh JOSHF-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/1/16:19:54:58 Josh JOSHF-PC PageOpen LaunchDialog
2015/1/16:19:55:15 Josh JOSHF-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2015/1/16:19:55:15 Josh JOSHF-PC Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2015/1/16:19:55:16 Josh JOSHF-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2015/1/16:19:55:37 Josh JOSHF-PC PageOpen LicenseDialog
2015/1/16:19:55:37 Josh JOSHF-PC PageOpen ProductInfoDialog
2015/1/16:19:55:37 Josh JOSHF-PC PageOpen InventorFlavorSelectionDialog
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==DefaultLanguage: en-us
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==InstallName: INVENTOR
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==ProductName: Autodesk Inventor 2014
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==DisplayName: Autodesk® Inventor® 2014
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==DeploymentName:
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==SetupTitle: Autodesk Inventor 2014
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==ConfigTransform:
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==ExeParams:
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==SupportLink:
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==InfotainmentLink:
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==MsiFileName: inventor.msi
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==AdminImageConfigName: Imgx64
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==AdminImageRoot:
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==GetBaseDeploymentName:
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==DeploymentLocation:
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==InstallDeploymentShortcut:
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==ModifyDeploymentShortcut:
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==SetupLockType: 2
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==SetupNetworkType: 1
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==SystemLocale: 1033
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==EvalMsiFilePath: C:\Users\Josh\AppData\Local\Temp\_AI9095.tmp\SetupRes\eval.msi
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==InstallLogPath: C:\Users\Josh\AppData\Local\Temp\Inventor2014Install.log
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==ConfigFile: C:\Users\Josh\AppData\Local\Temp\_AI9095.tmp\Setup.ini
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==SetupPath: C:\Users\Josh\AppData\Local\Temp\_AI9095.tmp\
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==NetworkLogPath:
2015/1/16:19:55:37 Josh JOSHF-PC Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2015/1/16:19:55:44 Josh JOSHF-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2015/1/16:19:55:44 Josh JOSHF-PC PageOpen ProductSelectionDialog2
2015/1/16:19:57:15 Josh JOSHF-PC PageOpen FullProgressDialog
2015/1/16:19:57:22 Josh JOSHF-PC Download Play CM http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CM.tar...
2015/1/16:19:57:55 Josh JOSHF-PC Download Complete CM http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CM.tar...
2015/1/16:19:57:55 Josh JOSHF-PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/16:19:58:39 Josh JOSHF-PC Install Autodesk Material Library 2014 Succeeded
2015/1/16:19:58:40 Josh JOSHF-PC Download Play CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILB....
2015/1/16:19:59:37 Josh JOSHF-PC Download Complete CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILB....
2015/1/16:19:59:37 Josh JOSHF-PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/16:19:59:50 Josh JOSHF-PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2015/1/16:19:59:51 Josh JOSHF-PC Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2015/1/16:19:59:58 Josh JOSHF-PC Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2015/1/16:19:59:58 Josh JOSHF-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2015/1/16:20:00:07 Josh JOSHF-PC Install DirectX® Runtime Succeeded
2015/1/16:20:00:08 Josh JOSHF-PC Download Play CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2015/1/16:20:02:59 Josh JOSHF-PC Download Aborted CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2015/1/16:20:02:59 Josh JOSHF-PC Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2015/1/16:20:03:00 Josh JOSHF-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/1/16:20:03:00 Josh JOSHF-PC PageOpen InstallCompleteDialog
2015/1/16:20:19:33 Josh JOSHF-PC === Setup ended ===
2015/1/17:10:49:18 Josh JOSHF-PC === Setup started on JOSHF-PC by Josh ===
2015/1/17:10:49:18 Josh JOSHF-PC Path_Length: 182
2015/1/17:10:49:18 Josh JOSHF-PC Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2015/1/17:10:49:18 Josh JOSHF-PC Launch
2015/1/17:10:49:18 Josh JOSHF-PC CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_Set... /SN 900-46382598 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2015/1/17:10:49:18 Josh JOSHF-PC Current Directory C:\Users\Josh\AppData\Local\Temp\_AIE5C5.tmp
2015/1/17:10:49:23 Josh JOSHF-PC === Setup ended ===
2015/1/17:10:49:20 Josh JOSHF-PC === Setup started on JOSHF-PC by Josh ===
2015/1/17:10:49:20 Josh JOSHF-PC Path_Length: 182
2015/1/17:10:49:20 Josh JOSHF-PC Current Directory C:\Users\Josh\AppData\Local\Temp\_AIE5C5.tmp
2015/1/17:10:49:20 Josh JOSHF-PC Launch
2015/1/17:10:49:20 Josh JOSHF-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/SETUP_...
2015/1/17:10:49:22 Josh JOSHF-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Josh\AppData\Local\Temp\_AIE5C5.tmp\Setup\InventorUI.dll
2015/1/17:10:49:22 Josh JOSHF-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/1/17:10:49:23 Josh JOSHF-PC PageOpen LaunchDialog
2015/1/17:10:50:03 Josh JOSHF-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2015/1/17:10:50:03 Josh JOSHF-PC Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2015/1/17:10:50:03 Josh JOSHF-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2015/1/17:10:51:06 Josh JOSHF-PC PageOpen LicenseDialog
2015/1/17:10:51:06 Josh JOSHF-PC PageOpen ProductInfoDialog
2015/1/17:10:51:06 Josh JOSHF-PC PageOpen InventorFlavorSelectionDialog
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==DefaultLanguage: en-us
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==InstallName: INVENTOR
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==ProductName: Autodesk Inventor 2014
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==DisplayName: Autodesk® Inventor® 2014
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==DeploymentName:
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==SetupTitle: Autodesk Inventor 2014
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==ConfigTransform:
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==ExeParams:
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==SupportLink:
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==InfotainmentLink:
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==MsiFileName: inventor.msi
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==AdminImageConfigName: Imgx64
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==AdminImageRoot:
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==GetBaseDeploymentName:
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==DeploymentLocation:
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==InstallDeploymentShortcut:
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==ModifyDeploymentShortcut:
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==SetupLockType: 2
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==SetupNetworkType: 1
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==SystemLocale: 1033
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==EvalMsiFilePath: C:\Users\Josh\AppData\Local\Temp\_AIE5C5.tmp\SetupRes\eval.msi
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==InstallLogPath: C:\Users\Josh\AppData\Local\Temp\Inventor2014Install.log
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==ConfigFile: C:\Users\Josh\AppData\Local\Temp\_AIE5C5.tmp\Setup.ini
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==SetupPath: C:\Users\Josh\AppData\Local\Temp\_AIE5C5.tmp\
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==NetworkLogPath:
2015/1/17:10:51:06 Josh JOSHF-PC Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2015/1/17:10:53:47 Josh JOSHF-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2015/1/17:10:53:47 Josh JOSHF-PC PageOpen ProductSelectionDialog2
2015/1/17:10:54:09 Josh JOSHF-PC PageOpen FullProgressDialog
2015/1/17:10:54:09 Josh JOSHF-PC Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/DIRECT...
2015/1/17:10:54:09 Josh JOSHF-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2015/1/17:10:54:54 Josh JOSHF-PC Install DirectX® Runtime Succeeded
2015/1/17:10:54:56 Josh JOSHF-PC Download Play CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2015/1/17:10:56:57 Josh JOSHF-PC Download Aborted CMILL http://edutrial.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{7FDF206A-082A-42B8-8851-9672168B18D7}/CMILL....
2015/1/17:10:56:57 Josh JOSHF-PC Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2015/1/17:10:56:58 Josh JOSHF-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Try to make the explaination a bit simple. I'm not a complete pro with computers.
Thanks for your help!
1 REPLY 1
dembkod
in reply to: joshf2012
joshf2012
Hello.  Change your method of install. Download the software completely first and then install. I would use the virtual agent:
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
You want to eliminate the download as being any type of cause.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
