Installation & Licensing
New Member
dmitrybrodsky
Message 1 of 2 (329 Views)
Installation error
329 Views, 1 Replies
03-12-2013 09:04 AM
Hello i can't install 3ds max on windows 8
this is massege that i get:
2013/3/12:05:30:57 user1 USER === Setup started on USER by user1 ===
2013/3/12:05:30:57 user1 USER Launch
2013/3/12:05:30:58 user1 USER === Setup ended ===
2013/3/12:05:30:58 user1 USER PageOpen LaunchDialog
2013/3/12:05:30:59 user1 USER PageOpen LicenseDialog
2013/3/12:05:31:13 user1 USER PageOpen ProductInfoDialog
2013/3/12:05:31:30 user1 USER PageOpen ProductSelectionDialog2
2013/3/12:05:31:37 user1 USER PageOpen FullProgressDialog
2013/3/12:05:31:37 user1 USER Installing DirectX® Runtime: D:\Downloads\3dsmax2013_x32\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/12:05:32:01 user1 USER Install DirectX® Runtime Succeeded
2013/3/12:05:32:01 user1 USER Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:05:32:06 user1 USER Install Autodesk Material Library 2013 Succeeded
2013/3/12:05:32:06 user1 USER Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:05:32:10 user1 USER Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/3/12:05:32:10 user1 USER Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:05:32:21 user1 USER Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/3/12:05:32:22 user1 USER Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\user1\AppData\Local\Temp\_AI2640.tmp\x86\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" INSTALLDIR="C:\Program Files (x86)\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:05:32:32 user1 USER Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/3/12:05:32:36 user1 USER Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/3/12:05:32:39 user1 USER Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/3/12:05:32:44 user1 USER Rollback Autodesk Material Library 2013 Succeeded
2013/3/12:05:32:44 user1 USER Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/3/12:05:32:46 user1 USER PageOpen InstallCompleteDialog
2013/3/12:05:33:31 user1 USER === Setup ended ===
2013/3/12:17:44:49 user1 USER === Setup started on USER by user1 ===
2013/3/12:17:44:49 user1 USER Launch
2013/3/12:17:44:52 user1 USER === Setup ended ===
2013/3/12:17:44:50 user1 USER === Setup started on USER by user1 ===
2013/3/12:17:44:50 user1 USER Launch
2013/3/12:17:44:52 user1 USER PageOpen LaunchDialog
2013/3/12:17:44:54 user1 USER PageOpen LicenseDialog
2013/3/12:17:44:57 user1 USER PageOpen ProductInfoDialog
2013/3/12:17:45:15 user1 USER PageOpen ProductSelectionDialog2
2013/3/12:17:45:22 user1 USER PageOpen FullProgressDialog
2013/3/12:17:45:22 user1 USER Installing .NET Framework Runtime 2.0: D:\Downloads\3dsmax2013_x32\3rdParty\NET\2\wcu\dotNetFramework\NetFx20SP1_x64.exe /q:a /c:"install.exe /q"
2013/3/12:17:45:22 user1 USER Install .NET Framework Runtime 2.0 Failed Failure is ignored, Result=1603
2013/3/12:17:45:22 user1 USER Installing DirectX® Runtime: D:\Downloads\3dsmax2013_x32\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/12:17:45:47 user1 USER Install DirectX® Runtime Succeeded
2013/3/12:17:45:47 user1 USER Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:17:45:54 user1 USER Install Autodesk Material Library 2013 Succeeded
2013/3/12:17:45:54 user1 USER Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:17:45:57 user1 USER Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/3/12:17:45:57 user1 USER Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:17:46:10 user1 USER Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/3/12:17:46:11 user1 USER Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\user1\AppData\Local\Temp\_AIC3CD.tmp\x86\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" INSTALLDIR="C:\Program Files (x86)\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:17:46:21 user1 USER Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/3/12:17:46:25 user1 USER Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/3/12:17:46:28 user1 USER Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/3/12:17:46:34 user1 USER Rollback Autodesk Material Library 2013 Succeeded
2013/3/12:17:46:34 user1 USER Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/3/12:17:46:36 user1 USER PageOpen InstallCompleteDialog
2013/3/12:17:48:39 user1 USER === Setup ended ===
2013/3/12:17:48:48 user1 USER === Setup started on USER by user1 ===
2013/3/12:17:48:48 user1 USER Launch
2013/3/12:17:48:49 user1 USER === Setup ended ===
2013/3/12:17:48:49 user1 USER PageOpen LaunchDialog
2013/3/12:17:48:51 user1 USER PageOpen LicenseDialog
2013/3/12:17:48:54 user1 USER PageOpen ProductInfoDialog
2013/3/12:17:49:13 user1 USER PageOpen ProductSelectionDialog2
2013/3/12:17:49:22 user1 USER PageOpen FullProgressDialog
2013/3/12:17:49:22 user1 USER Installing DirectX® Runtime: D:\Downloads\3dsmax2013_x32\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/12:17:49:42 user1 USER Install DirectX® Runtime Succeeded
2013/3/12:17:49:42 user1 USER Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:17:49:48 user1 USER Install Autodesk Material Library 2013 Succeeded
2013/3/12:17:49:48 user1 USER Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:17:49:51 user1 USER Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/3/12:17:49:51 user1 USER Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:17:50:03 user1 USER Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/3/12:17:50:03 user1 USER Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\user1\AppData\Local\Temp\_AI687A.tmp\x86\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" INSTALLDIR="C:\Program Files (x86)\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:17:50:13 user1 USER Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/3/12:17:50:17 user1 USER Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/3/12:17:50:20 user1 USER Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/3/12:17:50:26 user1 USER Rollback Autodesk Material Library 2013 Succeeded
2013/3/12:17:50:26 user1 USER Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/3/12:17:50:27 user1 USER PageOpen InstallCompleteDialog
2013/3/12:17:52:19 user1 USER === Setup ended ===
2013/3/12:17:55:13 user1 USER === Setup started on USER by user1 ===
2013/3/12:17:55:13 user1 USER Launch
2013/3/12:17:55:15 user1 USER === Setup ended ===
2013/3/12:17:55:14 user1 USER === Setup started on USER by user1 ===
2013/3/12:17:55:14 user1 USER Launch
2013/3/12:17:55:14 user1 USER PageOpen LaunchDialog
2013/3/12:17:55:16 user1 USER PageOpen LicenseDialog
2013/3/12:17:55:18 user1 USER PageOpen ProductInfoDialog
2013/3/12:17:55:37 user1 USER PageOpen ProductSelectionDialog2
2013/3/12:17:56:20 user1 USER PageOpen FullProgressDialog
2013/3/12:17:56:20 user1 USER Installing DirectX® Runtime: D:\Downloads\3dsmax2013_x32\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/12:17:56:40 user1 USER Install DirectX® Runtime Succeeded
2013/3/12:17:56:40 user1 USER Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:17:56:45 user1 USER Install Autodesk Material Library 2013 Succeeded
2013/3/12:17:56:45 user1 USER Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:17:56:48 user1 USER Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/3/12:17:56:48 user1 USER Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:17:56:59 user1 USER Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/3/12:17:57:00 user1 USER Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\user1\AppData\Local\Temp\_AI498B.tmp\x86\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\Downloads\3dsmax2013_x32\" INSTALLDIR="C:\Program Files (x86)\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:17:57:09 user1 USER Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/3/12:17:57:13 user1 USER Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/3/12:17:57:17 user1 USER Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/3/12:17:57:22 user1 USER Rollback Autodesk Material Library 2013 Succeeded
2013/3/12:17:57:22 user1 USER Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
*Expert Elite*
TravisNave
Message 2 of 2 (327 Views)
Re: Installation error
03-12-2013 09:21 AM in reply to: dmitrybrodsky
You might try the 64-bit version if available.  It appears you are installing the 32-bit version from the looks of the log file.
Windows 8 is still fairly new, so installation errors aren't as obvious.  You will want to make sure you have local admin rights and UAC is off, as a start.  Also disable any real-time antivirus during the installation.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Announcements
Need installation help?
