I have downloaded Autodesk Inventor 2011 and opened the 3 parts after the download to begin installation. Afterward a Autodesk Inventor 2011 window comes up with some choices on the left; I select install products and click next. The next screen says select products you want to install. I click next and then immediately afterward error messages come up.
The first error message says:
Error 1606. Could not access network location\Autodesk\ACADM2011\Acadm\Tutorial\
After clicking ok to that box another error message comes up:
Fatal error during installation. #19797: failed to run AdskExecuteSequence
Any suggestions???
Hi ty_man102006,
You might post your question or search for those errors over here:
I hope this helps.
Curtis
I searched for the errors. Out of the list of search results the first option seems to be the besst option as I have Vista. It claims to show you how to resolve it but I cannot understand how to fix it.
