I'm trying to install AutoCAD on Windows 7 64-bit. I've shut all background programs off and even tried to install 32 bit. I keep getting an error:
CRC failed in x86\acad\Program Files\Root\Inventor Server\Bin\JtTk56.dll
Unexpected end of archive
If its from DVD/USB please try to copy the install files locally. (c:\)
If you it's from a download, please try another download without Antivirus or any other security software enabled, may be using another browser.
I'm having this same problem I uninstalled AVG, I turned off my firewalls, I used mozilla and I tried internet explorer. I still can't download it please help!! I have superantispyware thats it for spyware could that affect it?
Is there any solution for such a problem?
Autodesk_3ds_Max_Entertainment_Creation_Suite_Premium_2012_English_Win_32bit.exe: CRC failed in x86\Softimage\Data1.cab.The file is corrupt
3rdParty\DirectX\Dec2005_d3dx9_28_x86.cab. The file is corrupt
3rdParty\DirectX\DEC2006_d3dx10_00_x86.cab. The file is corrupt
3rdParty\DirectX\DEC2006_d3dx9_32_x86.cab. The file is corrupt
3rdParty\DirectX\DEC2006_XACT_x86.cab. The file is corrupt
3rdParty\DirectX\dxnt.cab. The file is corrupt
3rdParty\DirectX\dxupdate.cab. The file is corrupt
x86\max\ETransmitGlob.cab. The file is corrupt
3rdParty\DirectX\Feb2005_d3dx9_24_x86.cab. The file is corrupt
3rdParty\DirectX\Feb2006_d3dx9_29_x86.cab. The file is corrupt
3rdParty\DirectX\Feb2006_XACT_x86.cab. The file is corrupt
3rdParty\DirectX\FEB2007_XACT_x86.cab. The file is corrupt
3rdParty\DirectX\Feb2010_X3DAudio_x86.cab. The file is corrupt
3rdParty\DirectX\Feb2010_XAudio_x86.cab. The file is corrupt
x86\max\IGES_SAT_STEP_ALIASCommon.cab. The file is corrupt
x86\max\IGES_SAT_STEPTranslator.cab. The file is corrupt
x86\max\InventorServerAM.cab. The file is corrupt
x86\max\InventorServerFW.cab. The file is corrupt
x86\max\InventorServerFWLoc.cab. The file is corrupt
x86\max\InventorServerPM.cab. The file is corrupt
x86\max\InventorServerPMLoc.cab. The file is corrupt
3rdParty\DirectX\Jun2005_d3dx9_26_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2006_XACT_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2007_d3dx10_34_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2007_d3dx9_34_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2007_XACT_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2008_d3dx10_38_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2008_X3DAudio_x86.cab. The file is corrupt
3rdParty\DirectX\JUN2008_XAudio_x86.cab. The file is corrupt
3rdParty\DirectX\Jun2010_D3DCompiler_43_x86.cab. The file is corrupt
3rdParty\DirectX\Jun2010_d3dcsx_43_x86.cab. The file is corrupt
3rdParty\DirectX\Jun2010_d3dx10_43_x86.cab. The file is corrupt
3rdParty\DirectX\Jun2010_d3dx11_43_x86.cab. The file is corrupt !
3rdParty\DirectX\Jun2010_XAudio_x86.cab. The file is corrupt
x86\max\LiveUpdate.cab. The file is corrupt
x86\max\LTU_x86_release.cab. The file is corrupt
x86\Mudbox\LTU_x86_release.msm.cab. The file is corrupt
3rdParty\DirectX\Mar2008_d3dx10_37_x86.cab. The file is corrupt
3rdParty\DirectX\Mar2008_X3DAudio_x86.cab. The file is corrupt
3rdParty\DirectX\Mar2008_XAudio_x86.cab. The file is corrupt
3rdParty\DirectX\Mar2009_d3dx10_41_x86.cab. The file is corrupt
If it's a downloaded file, please disable all the security softwares (Antivirus,Antispyware etc.)
use another browser to download.
if it's media please request for a replacement media, if copying the files locally doesn't work.
some more tips here
you should try to disable antispyware too.
Have you tried to download the trial version ?
with or without download manager ?
if you are not a student you could order for a replacement media.
I'm on my second DVD disk bundle from our reseller and having the same issue with Windows 7 32-bit and 64-bit. Tried CMD console and copying with Robocopy as well. Stops on dxnt.cab with CRC error 23, 0x00000017. No antivirus is installed, Windows Defender is disabled. Any other suggestions?
Please try to download the file or copy using an DVD reader (over the network)
This file should be intact on the DVD else we would have had lots of issues reported by customers.
No, I meant another DVD drive on another machine.
Or if you have an external DVD reader.
We need to isolate the issue with your DVD drive itself.
Tras haber descargado el archivo (1,96 Gb):
Autodesk_Robot_Structural_Analysis_Professional_2012_Multilingual_Win_32-64bit
intento descomprimirlo para comenzar la instalación pero aparece el siguiente error:
Error
Some installation files are corrupt.
Please download a fresh copy and retry the installation.
CRC failed in x64\RSA\RSA_FOLDER\System\Exe\Beam1.exe
Espero respuesta. Gracias.
@Anonymous wrote:Tras haber descargado el archivo (1,96 Gb):
Error
CRC failed in x64\RSA\RSA_FOLDER\System\Exe\Beam1.exeUnexpected end of archive
Problemas al descargar el software de Autodesk y / o errores de CRC se pueden evitar mediante el uso de otro navegador web, o utilizando el método de descarga navegador alternativo.
Para obtener información más detallada sobre este proceso, consulte el siguiente blog consejo aquí:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download-manager.html
Yo recomendaría que trate de descargar su producto con Matt, el asistente virtual siguiendo las instrucciones aquí:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
