Installation & Licensing
348 Views, 1 Reply
Installation error
To distribute applications from file servers to workstations, we use the Novell-delivered Application Launcher.
Recently stagnating the distribution of AutoCAD 2006 with the error "Unable to process registry setting HKEY_LOCAL_MACHINE \ SOFTWARE \ Classes \ exefile '.
Cause of the can't edit of that registerkey is the installation of "Security Update for Windows XP (KB970430)".
What is the result of the operation of AutoCAD 2006 if this key is not modified?
1 REPLY 1
TravisNave
It shouldn't need to write any changes to that key.  You might check the permissions settings on it.  However, if you get the option to ignore during installation, you might want to choose that and keep going.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
